Ask your small, random, track-related questions here
#3451
The Little Wing has a 58mm BB drop. I'm not sure how normal is defined today, but I suspect there might be different normals for sprint, omnium, and pursuit frames. My current omnium-style bikes have 51mm(XTRACK), 55mm(Argon18), and 58mm (Paramount) BB drops. In looking at the Dolan geometry, it looks to be totally out of whack for me; the differences in reach and stack are pretty big when compared to my current bikes. I don't see how I could be comfortable on a DF3/4, but I don't find narrow bars comfortable either, so maybe I'm just a dinosaur.
#3452
Ah! Forgive me...58mm not 68. But, that's still low.
The reach and stack use the BB as the zero point, so that doesn't matter. You can have great or awful stack and reach with the same BB drop. The only thing that matters for BB drop is the wheels. Basically, with a low BB drop, your entire body and cranks are lower to the ground.
The BB drop is equivalent to the spring ride height in a car. Everything in the car can be the same, and the springs lowered and the car will be lower to the ground...and scrape more. Trust me, I know...I have H&R coil-overs in my Audi
That being said, 58mm is higher that what their geometry states on their website (68mm). 58mm is still a "street" geometry and even on the street, you'd probably clip a pedal when cornering with longer cranks on a fixed gear.
With the shallow banking at TTown you won't have a problem. But, at Rock Hill, you might.
Lower is considered to be more aerodynamic. The Specialized Shiv TT bike has a drop of 72mm (and, yes, a Shiv was recently used on a 250m track during an Hour record attempt). Proper track bikes have higher BBs because of that point when you need to climb in a turn like in a match sprint or pulling off during a paceline or team pursuit. If the banking is 44 degrees and you take the bike vertical as you climb the turn, this is like cornering on the road at 44 degrees and having your inside pedal down. You won't see that cut up track during an Hour attempt
I understand both reach & stack and how BB drop impacts stack as much a head tube length. If the Dolan's BB was dropped 1 cm lower, then without change in the head tube length there would be 1 cm more of stack. As it is, the Dolan has 9 cm less stack than the Little Wing, which is too much of a position change for me.
The No. 22 website lists their track frames are having 58mm BB drop, while their road frame's BB drop ranges from 67 to 78mm. It might be old-school track geometry, but I believe it is still a proper track geometry and that's why I've ordered one.
Also, I've ridden my Argon18 (55mm drop) with 172.5mm cranks at Rock Hill and felt comfortable with my clearance moving up and down track, so the 165mm cranks that I plan for the No.22 will be just fine. In fact my No. 22 setup will only give up 2mm of ground clearance when compared to my current XTRACK setup.
#3453
I wasn't suggesting that you go with the complete Dolan geometry. The BB drop really has nothing to do with stack and reach. The BB drop only concerns your wheels, cranks, pedals, and the track. I just used Dolan as a reference point to show that modern track bikes use a 45mm BB drop.
BB drop has no affect on your comfort! It only adjust how high or low you and your cranks are with relation to the wheel axles.
It's simple geometry, if the BB is 1 cm higher, then the seat must move up 1 cm. If the seat moves up 1 cm then the handlebars must raise 1 cm. If the angles aren't parallel, then the top tube and/or stem lengths must change. This reduces the overall stability of the bike. Subsequently, the frame manufacturers that you list below all have lower stack heights because of their decreased BB drop.
BB drop of other track frames:
Serenity: 35mm
Fuji Track Elite: 45mm
LOOK 564P (open-mold): 45mm
Tiemeyer: 45mm (Most, if not all)
Dixie Flyer: 45mm
Hoy Fiorenzuola: 46mm
LOOK L96: 50mm
Felt TK1: 55mm
I suspect that the TK1 is so low because the track frame's design seems to be "hand-me-down" from the road TT frame and keeping with the "lower is more aero" theme (which is true).
Serenity: 35mm
Dixie Flyer: 45mm
LOOK L96: 50mm
Felt TK1: 55mm
Pinarello Pista Alu 51mm
Cipollini Speed Alto 51mm
Cinelli Mash 54mm
Argon18 Electron Pro 55mm
Bianchi Sei Giorni 55mm
Waterford Competition Track 55mm
Planet X Pro Carbon Elite 57mm
BMC TR01 58mm
BMC TR02 58mm
Cinelli Vigorelli 58mm
Bianchi Pista 58mm
Bianchi Classica 58mm
Fuji Track 58mm
Ritte 8055 58mm
All City Thunderdrome 58mm
Cinelli Super Corsa 60mm
Cipollini Speed Basso 63mm
I mean, it's your bike do what you want. I just figured since it seems that No. 22 may not have a lot of experience making bikes for track racing, you could offer some input on your custom rig.
When I had my custom Snyder made, I gave him the geo chart of my Tiemeyer and said, "Move the seat tube angle back 2 degrees and make the top tube 3cm longer." and kept the same 45mm BB drop.
The current Little Wing is the second generation of their track frame in their few years of existence, but they have decades of titanium frame building experience (read Serotta). With the exception of the seat tube center to top measurement, I already have a bike with the EXACT SAME GEOMETRY and I have firsthand experience training and racing on it. I wouldn't want them to change it a mm.
I never had any doubt.
#3454
Only chiming in here to say that 58mm BB drop may have indeed been standard for old-school track bikes. My Panasonic and many other NJS bikes have a similar BB drop, as they are designed primarily for use on 400m tracks. The steep 250 is a relatively recent phenomenon and is probably the reason for the move to higher BB's. So 58mm may not necessarily be "street", but is definitely "old fashioned".
#3455
Dude, you are sorta making my point with that list
Not one of those bikes are popular race bikes. Not one.
Yeah, the Fuji Track is a popular fleet bike for beginner classes, but that's it. The geometry was made street years ago because that's where Fuji made most of their sales of the basic Track model.
Anyway, I know which geometries that have earned me podium spots in the last two years and No. 22 is building exactly what I want. There's a lot to be said for riding a crisp handling COMFORTABLE and STABLE bike that also gets you onto the podium.
Luckily, I didn't buy a Cipollini. I probably would have chosen the Basso(63mm drop) over the Alto(51mm drop).
#3456
@carleton,
In post 3456, 55mm was considered to be medium-high drop, but 58mm is now street. Oh the difference the 3mm makes.
As I said, the No. 22 is the same geometry as my 40yr old Paramount, so yeah, it's old-school, but it works and it has worked for a very long time.
#3457
You get that I was agreeing with you, right?
#3459
Bikes: A little of each
Quoted: 23 Post(s)
fwiw, I like my TK1 (minus the track end problem), and I haven't had any issues with either of my 55mm bb drop bikes at FCV, or the small handful of 250m track I've raced on.
#3461
In the past two years, I stepped onto the podium with each of my current bikes: the Argon 18, the Pinarello, and the Paramount. It's more about the legs, heart, and lungs than the bike, but the bike should be something that you enjoy riding.
If you have $6,000 to spend on a track frame, more power to you. That's nuts. I'm sure when they set that price, someone in the meeting was like, "Somebody will buy it...watch."
(I also think the $10,000 LOOK L96 is grossly overpriced. Especially with the awful customer service.)
Wow, if that was your first post, this flame would have never started, but it's also good to let people know they don't need to chase every trend in the bicycle industry and there are plenty of options that are acceptable. I work with new riders and teach at the Try the Track and whatever bike they have is pretty much good enough. I never tell them their BB is too low or their bars are too wide. I just make sure their bikes are sound and they learn to ride safe. Everyone isn't automatically training for the worlds, so everyone doesn't need to emulate the pros.
My point is that, "Old school" geometry is considered old school for a reason. The reasons that BBs have gotten higher are not because of aesthetics, it's because in the 70's and 80's 333M and 400M tracks with 14 degree banks were world class standard tracks. Now 250m tracks with 44 degree banks are standard. And some go over 44 degrees. It's a safety concern...so why not?
Congrats, you finally joined the it's "old school" track geometry, just as I posted in my very first post about the geometry.
You have two options when you are match sprinting or simply turning up track on a 250:
- Worry about clipping a pedal.
- Worrying about winning your race.
You are very likely to race at 250m track as an active masters racer. In the past few years Masters Nationals has been held at Rock Hill and The Superdrome and it will be at ADT next year...all 250m tracks. Trust me, you do not want to snag a pedal and slide down a turn at the Superdrome. Sliding down 30ft of a surface similar to skateboard grip tape is not fun.
In the end I look forward to getting my No. 22 exactly how I want it and there isn't a track in the US that it would give me any pause to race upon. So with that bold statement, I will end my part in this conversation. Enjoy what you ride and I'll do the same.
#3462
Quoted: 26 Post(s)
Curious if anyone has an opinion on running front wheels with hollow axles/hex-bolt skewers (pictured) vs. the traditional solid axle/nut setup. Is there any performance or safety difference? Can I repurpose a road tubular front without issues?
#3463
USA Cycling rule 113(a) states for track races: "....... in pursuit and time trial events that are not championships or selection events......... quick releases,.........may be installed on the bicycle....." I see track riders using a QR skewer on their front wheel occasionally.
#3464
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
One note: The threads within lightweight aluminum nut will probably strip out on you if you have gorilla hands like me. If you get the nut from a standard non-lightweight steel skewer, the threads will also be steel and will not strip out.
You can find these at any local bike shop. They probably have the ends in a random parts drawer and will give you one for free if you are a regular. Nobody wants them. You just need the female end.
#3465
Elitist
Liked 92 Times
I'm not familiar with the hex-bolt skewer you show but if there is any torque applied to the axle I would be skeptical of using it (since you would be combining tensile and shear stresses ion the axle). Others may have more experience/knowledge.
I'm a big guy and I was doing sprints on a 36 degree track and didn't have any issues.
#3467
Bikes: Fuji Elite, 3Rensho track, Trek Madone 6.9, Specialized MTB, GT MTB, Cannondale Cad3 fixie
Quoted: 72 Post(s)
Used that setup on my Zipp front wheel with no problems for more year than I can remember using a steel nut.
#3468
Quoted: 43 Post(s)
Thanks! This wasn't what I was thinking of, but it's interesting and I'm looking forward to playing around with it.
I actually found what I was looking for, and the embarrassing thing is that it was a spreadsheet that I made based on a Coggan chart I found associating W/CDA ratios to pursuit times for 2k, 3k, and 4k distances. From there it's easy to put in your power, get your cda, and then pick your target time and produce the power required to hit your target time.
I like the spreadsheet better than the app because it's got a bunch of columns (and you can add more) so that you can easily enter a whole course profile if you want. It takes a little more tweaking to get your CdA out but it's more flexible than the app. Pm me if you want me to email it somewhere.
#3469
Quoted: 43 Post(s)
#3470
Bikes: Serotta steel track bike, Specialized MTB
Quoted: 99 Post(s)
I need help with golden cheetah program.
I cannot install the app.
so do I have to go to the setting and change something?
Or can anyone recommend me a simple program that works with srm headunit(PC7).
I only have cadence and speed sensor
#3471
Elitist
Liked 92 Times
Right-click on it then choose "Open".
This is a security measure from Apple since you downloaded the app from the web instead of the App Store. You only have to do this the first time.
This keeps unapproved apps from randomly running without your consent.
#3472
Quoted: 99 Post(s)
Go to your Applications folder and find the .app file (goldencheetah.app?)
I solved the problem!
Now, I just have to learn how to use golden cheetah.
#3473
Bikes: Bianchi Pista, Bianchi Vigorelli
First post here.
First, thanks to Carleton, Quinn, Babypuke, dunderhi...all the regular contributors. I've read this thread in its entirety and learned so much.
I have a lot of questions, so I'll start with this one:
I am in Tokyo; where can I find information about track racing/events for this area? I understand Babypuke was in Japan before, so perhaps he can chime in here. I've looked around, and found that the Izu velodrome holds races for amateurs about 4-5 times per year, and I've found some races open to the public on 1 or 2 of the keirin tracks. All in all though, that's less than 10 events per year, and some of them appear to be not that well attended.
I'm looking for info on more races, but also clubs that I should check out and well-organized practice sessions.
About me: I'm from a road background, so my primary events would be pursuits, scratch races, points races, and the like I believe.
Many thanks
Many thanks
#3475
Next Q:
I don't have a track bike, and I am not in a rush to get one - need to find ample opportunity to use one first, then try different setups on rentals as much as possible to determine fit.
One burning question though.
Several of the frames that have caught my attention have 58mm bb drops. One of the tracks I'd ride is a 250m steep-banked indoor: the Izu velodrome. Am I correct in assuming that frames with that bb drop should be avoided?
Thanks
Thanks
