Wider Tires in the Pro Peleton
Quoted: 786 Post(s)
Liked 520 Times
Interesting article on tire selection for Paris Roubaix at Cycling Tips:
Tyre trends: what the teams are using for Paris-Roubaix | CyclingTips
"We’ve seen 25mm become the new 23mm when it comes to tyres in regular road races, and now in the world of cobbles, 30mm seems to be the new 27mm. Tyres are becoming wider from what many mechanic have told me, though this is causing a few problems. Not all teams can accommodate this with the bikes and calipers they are issued by sponsors. That said, it’s a trend I’m sure we’ll slowly see grow in the peloton in years to come."
Looks like it's now safe to be a retro-grouch and a road fan.
Quoted: 659 Post(s)
Liked 595 Times
They have obviously been listening to our panel of experts at BF.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,601 Times
We are way ahead ... It'll be steel next
Quoted: 786 Post(s)
Liked 520 Times
I hope it means more options for nice 27s- 32s trickling down to the us non-racer market. Compass needs some more competition.
Quoted: 659 Post(s)
Liked 595 Times
Can a breakaway with a team of uprights be far off?
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
So why exactly has 25 become the new 23? Surely it isn't because they are faster. Maybe they just think they are faster.
Real cyclists use toe clips.
jimmuller
jimmuller
Quoted: 786 Post(s)
Liked 520 Times
Somebody should start a component/tire company called "Placebo."
Quoted: 3464 Post(s)
Liked 2,829 Times
The tight clearances of forks and bikes has it appears hit one end of the pendulum. Many race bikes have the brake calipers set to the minimum reach of the brake pads. Maybe soon an influencial mfg. will design so that they need to set the pads at near the longest reach of the caliper. You read it here first.
"new improved, better aero, More room for air, you will be faster, wind tunnel tested and race proven"
Quoted: 659 Post(s)
Liked 595 Times
So much for saving milligrams of weight.
the widespread use of carbon rims has helped negate the added weight of larger tires. Even Paris-Roubaix is exclusively run on carbon rims. I don't think anyone this year will run metal rims. Maybe one or two riders
In the classics, it's obviously better for wider tubulars where lower psi and pave are the norm. Better comfort and less chance of flatting.
25's are becoming more widespread because of the shape of the contact patch. There is a compromise between comfort/flatting/rolling resistance/weight/handling with 25s that is acceptable for racing.
It's also the trend now, and that trend may change with the wind.
racers often ride what they are paid to, and sellers of the parts, decide what the sponsored teams demonstrate.
Quoted: 378 Post(s)
Liked 1,409 Times
Had a nice conversation about this with the Continental rep at NAHBS. Even though bicycle tires are less than 1% of their market, they take it seriously, but have the added advantage of using trickle-down technology from their motorcycle racing tire development. Michelin did some early studies in this, as well, and the design of the wider 23/25/and up tires does not necessarily mean slower, especially with a 19-21mm rim.
Continental is quite comfortable telling us that their 700x25's have lower rolling competitive or better than their 23's. They'll also tell you that Velocity's A23 rim, coupled with a 23mm tire, provides what Velocity claims: an aero combination. What's come of putting the 25's on 23mm wide rims was not something they intended to market: silky smooth ride, great handling, and no loss of "speed." Per the Continental guy, this is something they now are looking at from a marketing standpoint, i.e. "why ride a narrow rim/narrow tire, and wince on the chipseal, when you can go 23/25 and not even notice?"
I was skeptical about this. drrobwave was constantly trying to get me to run some 700x25GP's, and I resisted. dookie recommended 25's on my A23 rims, so I tried it. (Bang forehead). Why didn't I try this earlier? I'm only getting 25's from now on. (But not the Armadillo's, etc...) What will be neat is when tires like the Continental Triathlon (a GP4000 without most of the tread) starts coming in 25's.
Liked 645 Times
Thank you. This makes perfect sense. From this answer I reason the difference between older days vs. now: With steel frames the tire's ability to absorb shock was less important because a lighter frame was more compliant anyway. With CF frames (and wheels) the frames can be very stiff while still very light, to the point where they are too stiff to ride easily or efficiently over long distances. So wider tires are used to compensate.
jimmuller
jimmuller
25s, carbon tubulars will make a steel bike perform better as well due to the contact patch shape (rolling resistance) and lighter weight over alloy rims.
Note that these are tied to wider rims to maximize aerodynamics and contact patch of wider tires.
Carbon rims are going to 23-25mm wide.
Most old wheels are in the 18-19mm width range.
Ride characteristics of carbon frames depends on the frame design. The advantage is compliance with bottom bracket stiffness and light weight that steel cannot match.
Wider tires are not making up for carbon frames.
This is simply a realization that wider tires are adding benefits without old school beliefs about narrow being a panacea for max speed problems.
Quoted: 3015 Post(s)
Liked 3,804 Times
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
+1 on that! ^^^^^^^
I did a lot of training on heavy wheels in the 90's, on wheels that I built from "obsolete" 22-25mm rims.
Seemingly no one was doing that on the rides back then, in L.A. and Silicon Valley, that I frequented, but I persisted for many reasons:
First: As my vintage-bike collection began to grow, I found that wider rims and tires could be run at pressures that were further under the blow-out pressure limits that aged tires would tolerate, and I have long since confirmed that this is the way to go for maximal tire life of my ever-aging tires (the rims and tires that could so often can be had for free).
Second: The lower pressure was more comfortable, the wider, softer tires could cross invisible scatterings of gravel with noticeably less effect on traction.
Third: The wider rims also gave the wheel/tire more lateral stiffness that could be felt, with seemingly no increase in harshness as would result from using higher pressures with narrower rims.
Fourth: The wider contact patch afforded by lower pressure meant the tread lasted longer.
Fifth: Wider contact patches are also safer in peloton (group) riding, since there is less tendency for the tire to track pavement seams that are obscured from view by the riders in front of you.
It was quite a surprise for wider modern rims to emerge as being more aerodynamic, not less! This really tips the scales, since the aero benefit can overcome the weight penalty.
I look forward to the rim/tire industry further developing the wider contact patch products.
I suspect that the pinch-flat-prone, fast-wearing, groove-tracking 20mm tires of the 1980's went a long way toward limiting people's perception of road bicycles as "useful" and "fun", and it also feels great to finally see my own strange choice of wider rims and tires vindicated within group-riding and racing fraternities.
Now, I wonder if steel frames will perhaps follow the same re-discovery among group-riding cyclists(?), although, unlike wide rims, steel frames never disappeared so completely.
Still see steel frames in the track events at the olympics and plenty of steel in cyclocross. Now just need to get steel back in the pro peleton. It would be awesome if Cinelli put pros on a steel lugged classics or cobbles bike.
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
FWIW, Michelin Pro4 Endurance tires in 700x25 measure 27mm wide on my Open Pro rims, and I've read that they measure 28mm wide on 23mm rims. I understand that the Pro4 Service Course versions measure about the same.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
I love my steel bike but I doubt it will ever become trendy in racing. Too heavy, even with the modern steel tubes available now.
Maybe for the sport/recreational guys.
I would love a good steel racing bike. Reasonably priced ones are hard to find though.
Liked 1,296 Times
The reason 23-25mm rims are more aero is the deep carbon shape of the rims. This aero improvement does not apply to box section rims.
I wasn't expecting steel frames to become race-competitive again, but that riders might find them to be a better choice for all other types of riding, including race-training, where it can be costly to rack up all of one's training miles on high-zoot bike, tires and wheels.
And of course box rims aren't going to be aero, only the deeper ones where greater width allows for a better aerodynamic shaping of the entire tire/rim profile.
Another surprising find is that traditional deep rims, with pointed shapes, are not only twitchy steering in crosswinds, but that they impose much greater drag in even a slight crosswind versus some of the more-modern deep rim designs.
The modern, wider/rounder-shaped rim profiles steer better and have much lower drag in crosswinds.
For all of my road training, at least my old-style box rims don't exaggerate crosswind's effects on steering. It's kinda funny that many racers use fancy wheels on training rides, some of these even being full carbon. But some riders seem to do all of their riding and racing on the same bike and same wheels, which at least has a certain simplicity to it.
Even V-shaped carbon wheels are faster than box section.
I've not experienced "twitchy" handling with the old style Zipp 404's, and those were decently deep profile.
They get pushed in strong crosswinds for sure, but meh, so what. All this is personal preference on what you want to ride.
I used Mavic SSC SL's, which are the farthest thing from aero. Super stiff though, and loved them.
Carbon for training and racing <shrug> people can do whatever they want.
I'm not a hater. People can enjoy however they want.
Steel is more expensive than carbon framesets at this point.
If high quality steel racing frames become more popular, sure I would pick one up.
But all the modern features and advantages are built into equally or cheaper priced carbon frames.
Liked 3,804 Times
