Racer Tech Thread
#101
¯\_(ツ)_/¯
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
everyone I know with electronic talks mostly about the times it's failed them or they forgot the battery on the charger.
this is like powermeters, where word of mouth and anecdotes color it so much.
my arms look super weird to me today, and I missed a ton of spots.
#103
Quoted: 842 Post(s)
Liked 469 Times
So they say, I'd really like to test ride one, not around the lbs parking lot but on an actual 20-30 mile ride with the Cat 4 climb mixed in.
This is my concern about electric, and how slowly it seems to shift when sprinting. I'm not the most meticulous guy out there, I don't spend hours prepping my bike, I just ride it and clean when people start commenting 'Nice brown bike'.
Although when I'm suffering up a hill, and the guy ahead of me is pressing a button to shift, I wonder how much easier my life would be with that
Right now all I know is Campy 10 speed and going to Campy 11 is a major hassle unless you get an Italian brand.
#106
Bikes: Yes
Quoted: 9 Post(s)
To properly evaluate electronic shifting speed in a sprint you need to test a bike equipped with sprint shifters. Only the top of the line have them OEM. Maybe you can test ride a friends bike that has them.
#107
These Guys Eat Oreos
Bikes: Yes
Quoted: 13 Post(s)
¯\_(ツ)_/¯
Quoted: 967 Post(s)
my shaver ran out of battery about half way through. and the lighting in my shower is awful, and arms have a bunch of crevices I hadn't previously ever thought about.
#109
As far as shifting goes electronic rear derailleurs need the cassette ramps just like mechanical. I guess they can push the derailleur down as well, whereas mechanical relies on a spring (and it's weakest going into the smallest cog). However the ramps are good, the upper pulley is close to the cogs, so a mechanical rear works really well.
For the front there's no beating electronic. The acid test is going into a steep hill in the big ring and then shifting into the small ring as you run out of momentum. With a mechanical derailleur you'll fail that shift pretty frequently as the spring isn't strong enough to overcome the chain tension you create by desperately pushing the pedals so you don't fall over. It helps to have the lopped off teeth but it's pretty normal for the derailleur to simply fail to move over. With electronic that was the selling point they presented at the trade show. Push a big gear slowly, like 30 rpm, on a trainer, and shift at some random time to the small ring. Don't let up on the pedals. The chain drops at the lopped off teeth every time.
Of course no guarantee if you have non-round rings or a dying battery.
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
#110
My Bastognes (Ardennes rims basically, 23mm wide) are toast. Front is really toast, like one spoke has zero tension and the wheel is true (and I didn't true it or anything, I just noticed the wheel could sort of collapse to one side when I was sprinting out of the saddle), rear is getting there (I've had to true it to adjust for a bent rim and the spoke tension is uneven now).
My options are the same rim, the Ardennes+ or similar (25mm wide outside), or a wide carbon clincher rim. If I got a carbon clincher I wouldn't get a narrow one.
Same rim: lace over? Otherwise it's a known quantity. Brake barrel thing is only drawback.
Ardennes+ or other 25mm rim: closer to my Stingers in rim width, less brake barrel turns when I change wheels. Right now it's 5 full turns. Not sure if a wide base clincher tire will clear my stays. On the Stingers the tubulars are 23mm and rim width doesn't affect tubular tires. Clinchers it's different.
Carbon clincher 23mm: Same disadvantages as Ardennes but at a much lighter weight. 23mm aero, perhaps good spare race wheels, especially in raining or super windy conditions. Cost is a factor since they cost more than is comfortable for me to spend.
Carbon clincher 25mm: closer to Stinger in brake adjustment. Not sure if the actual tire will clear, but if it has the not-so-wide bead width it should be fine. Cost is a factor since they cost more than is comfortable for me to spend.
For now I'm riding the virtually unridden Jet 6 front (I got it spring 2010) and the slightly more used Jet 9 rear.
#111
Killing Rabbits
Quoted: 278 Post(s)
Liked 217 Times
I'm getting a slight tick like noise when I press down on the non-drive side crank arm. It's always at the same degree / position (9 to 10 o'clock).
I've checked my shoes, cleats, pedals and today got the shop to remove/clean/re-grease/repress the bb30 bearings. The mechanic said the bearings were fine but the junction was very dirty.
Tonight I test rode and the noise is exactly the same so I'm starting to wonder if the problem is bb30 creak after all. I would imagine the service would have made some difference if that was the problem. In the past when threaded bb's creaked I could create the noise on either side with sufficient force like stomping on the pedal when at bottom dead centre. In this case I can't make a noise with any amount of pressure to the drive side but can still make the non-drive side tick even with a single leg drill.
Ideas?
Ideas?
#112
Version 7.0
Bikes: Too Many
Quoted: 1340 Post(s)
Liked 2,482 Times
#113
Bikes: Yes
Quoted: 9 Post(s)
#115
Quoted: 693 Post(s)
with electronic, you hit the button and don't get that immediate feedback (which doesn't really DO anything). the actual shift happens as fast or faster w/ electronic (and is perfect)...but you just don't feel/hear the clammer of jamming the chain into the big ring.
for a while after first getting electronic i would have to look back to see if a rear shift had happened...it was so fast and quiet.
agree with shovel--satellite shifters rock and are a big benefit of di2. love it for the TT bike and love the sprint shifters in particular.
Originally Posted by shovelhd
Do you know how many races I have won on electronic?
#116
Bikes: Yes
Quoted: 9 Post(s)
Get off my lawn.
Another thing about electronic. It is extremely forgiving with chain alignment. It will shift wih a bent hangar. However you won't get the true electronic experience until the hangar is aligned correctly. That's when it shifts silently and perfectly, every single time.
#117
Quoted: 1851 Post(s)
Liked 679 Times
And if you want to stick with aluminum, you also could look at Velocity, Pacenti or Kinlin. All offer wide rim options. The Hed and Pacenti rims are pretty pricey, the Velocity and Kinlin are more affordable.
I had PowerTap wheelset built up with Kinlin rims. I rode them exclusively for five years. They held up great.
#118
As the other thread was locked regarding lock keo blades. I've struck my pedals several times in crits and you actually contact the pedal outside of the carbon spring unless you are doing something very strange (or there is a curb involved)
#119
Got the BB30 bearings. No race tonight but so exhausted from family stuff over the weekend that I don't know when I'll do them. Maybe Thursday. I also had to organize my tools a bit for fun ride support so I want to get that done for real. I'm thinking some kind of a flat, multi layer tool board that is pretty portable and unfolds or something to become an easily accessible kit.
Also bought a second set of 175 Cannondale SI crank arms. I've been swapping arms between bikes and so my backup bike isn't really a true backup bike (170 arms). This means I can put the black bike back together. I'll need to order another stem for that (already bought the bar). I have an SLR saddle to put on that one also, then my two bikes will be set up again.
#120
Quoted: 163 Post(s)
Someone remind me - I can't find it. I'm working on collecting parts to upgrade my bike to DA 11 speed electronic, but I think I saw somewhere that the DA cassette is no good. what's the best cassette to use? reasonable weight, great performance? Ultegra?
#121
Bikes: Yes
Quoted: 9 Post(s)
You can use 6800 Ultegra or 5800 105. Ultegra seems to shift better with Di2 for me. The DA9000 cassettes have carbon carriers which have had some failures. Shimano has made a running change in the design but the jury is still out on longevity. They are quietly replacing DA9000 cassettes without a recall.
#122
Quoted: 163 Post(s)
Thanks. there's a pile of DA Di2 and an ultegra chain and cassette sitting in a box in my garage now, installation is next week.
I'm going to have my frame drilled to get the front half of the wiring inside. Anyone want to talk me out of that? I don't care about the warantee, just don't want it to uh... asplode. wow, finally a context in which to use that word.
#123
Quoted: 417 Post(s)
as far as torque wrenches go, anyone have experience with this:
Shimano PRO Torque Wrench
or would something from the hardware store do the job just as well?
