Chains
#101
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
Resurrecting an old thread rather than creating a new one...
Ordered what I thought was a blingy standard Izumi track chain...got an Izumi Jet Black through. Not seen much comment on them here. Interested to know what folks thoughts are on them if they have any previous?
I have an Izumi Eco chain and wanted to know if I could use a KMC or similar quick connector link on the chain vs the standard pin so I could remove it and swap with another length chain.
Not sure Izumi sells a quick connector link, so thus my question.
thanks all
thanks all
#103
Bikes: 2002 Seven Axiom
Quoted: 11 Post(s)
Noted
Thanks alot for the thought.
That is the ECO, which is an awesome chain.
I don't know and I wouldn't try it. Why? If it works, no big deal. If it doesn't, there could be drama. Not worth it to save $16 (the cost of a new Izumi ECO chain).
#104
Annoying Member
For what it's worth. I've stretched too many ECO chains to remember, and I can put out a couple watts on a good day. I tried the Model V with hesitance and LOVE the thing.
#105
I've used the motorcycle-type clip link from KMC with Japanese chains before, no problems. Eventually that tiny screw wears out if you take the chain off the bike frequently (I wax), often before the chain does.
#106
Quoted: 18 Post(s)
It might be worth noting that the D.I.D. has a screwpin master link as well. I personally like these more than quick links, so it's worth the extra $ to me...
Just throwing this out there for others who are considering the Izumi ECO.
#107
Quoted: 1851 Post(s)
Liked 679 Times
The KMC chain I currently have on my bike has a quick link for easy removal. Have any of you guys ever used those to swap chains between bikes? I've done it on my road bike without issue, despite warnings that the quick links should only be used once. It looks like I may be getting a new frame, and I'm unclear whether this is a good or bad idea on a track bike - assuming the length is correct.
#108
#109
Like the old Regina Oro, I like full bushing chain .. I have 3/32 cogs on the Rohloff the Sturmey, and the Sachs i9..
I got some NOS chain 3/32 full bushing, .. next chain will be 1/8" because that is what is I found, full bushing..
[bushingless types hot punch out the inner link plate forming a partial bushing from the metal punched in to make the hole. (derailleur chain)]
#110
Quoted: 4806 Post(s)
Liked 3,928 Times
I've settled on the Izume ~$30 chains (one step up from the Eco I believe). Love 'em. Yes, tey are noisy, but they strike me as very solid and reliable and the least likely to throw off. (Big concern going down major hills. I've come down both descents off Crater Lake, the fun ride into Ashland, OR, nearly all of Portland's west hills descents, likewise the Chelem descents south of Portland.)
I run the black chain on my winter/city/rain fix gear, silver on my custom ti fix gear and gold on my recently "remodeled" Peter Mooney, now also fix gear. I ride the black chains and drive trains into the ground as I never change cogs to change gears. The shiny chains get far more attention as I ride many cogs on those bikes (and they share cogs). Use the Izume quick-link on the silver and just drive the pins back in on the Mooney as it has multiple chainrings set very close and the quick-link is too wide. Both the silver and gold chains sport 1/2 links as required. (Small point that bugs me - when I went to look for chains for all three bikes last spring, no shops had those Izumes or could get them. I had to order them from the UK. Prices were decent and the service fast, but - why not here in the US? I've been buying those chains locally for years.)
Ben
Ben
#111
Elitist
Liked 92 Times
Ben
Ben
- It's readily available at many local bike shops.
- Comes in multiple colors.
- Is very quiet.
- Is inexpensive.
- Has a quick release instead of a screw pin.
- It takes 1,300kg/2,800lbs to break the K710
- It takes 950kg/2,000lbs to break the K710SL
- There are SIXTEEN variants of the K710/K710SL available (keep clicking next til you see them)
However, it may be slightly (impercievably) heavier than the Izumi ECO. Both are favorites of mine.
#112
Two chain questions:
I have a Izumi super tough chain - 9 months use (4 hrs per week) - works fine but it is quite noisy - noisier than most other bikes, why?? Is it a chain issue or is it something else? Have tried adjusting the chain tension but seemingly makes no difference.
Secondly, how much chain tension is considered “ideal”? Obviously should not be too tight or too loose; 2-3 cm of slack up and down seems to be what most people go with - is this sensible??
Thanks
Thanks
#113
Quoted: 70 Post(s)
Liked 5 Times
Noise could be related to the quality of your cogs and chainrings. Carbon frames and disc wheels result in more chain noise too.
I go loose enough that there is no point in the rotation of the cranks where the chain is taught with no slack but tight enough that it can't be forced off the chainring by pushing the chain laterally.
#114
I have always thought the Super Toughness was really noisy, too. I prefer the HKK if you want a Japanese chain. It's just as nice, a bit cheaper, and not as noisy.
#115
Elitist
Liked 92 Times
As the others have stated, it's simply a noisy chain.
The KMC K710 is the most quiet chain I've used...and least expensive...and strongest. Crazy.
...but heaviest, too.
#116
I built my bike up recently with an Izumi Standard track chain, but despite good lubrication and a straight chain line it was so noisy I actually found it a bit embarrasing when I was riding it on the track.
Based on recommendations here, have just switched to a KMC K710SL and the noise has completely gone, so another vote for the KMC 710 from me.
#117
Is it possibly just Izumi chains in general are noisy?
My ECO runs like a dream but there's no hiding it's noticeably noisier than the gold KMC it replaced
#118
Elitist
Liked 92 Times
Yes. Every Izumi I've used (V Supertoughness and ECO) has been noisy.
It's not a bad thing. It just is.
That noise is amplified by a rear disc, especially the Mavic Comete. Leading riders can hear you approach from behind.
#120
Idiot Emeritus
Yeah, but that's a NICE noise! (I like it, but I'm, well, me....)
"Can you add a signature line please? The lack of words makes me think you are being held hostage and being told to be quiet"
#121
Bikes: S-Works Venge Dura-Ace DI2, KTM Strada 4000, Fuji Norcom Straight 1.3 (TT), Fuji Track Elite, BMC Trackmachine TR02
Quoted: 100 Post(s)
My favorite chains:
- KMC K-710: This is a BMX freestyle chain that is over-built to withstand harsh BMX street riding. Strong, very quiet, but heavy and hard to remove links. I've broken chain-breakers trying to remove links. Best value.
- KMC K-710 SL: Same as above but lighter than the K710 via the cutouts in the plates. Costs maybe $5 more.
- Izumi ECO: This is my reference chain. My absolute favorite. Solid, strong, not heavy, fair amount of noise.
- D.I.D. NJS: Very similar to the Izumi ECO, but costs $15 more.
- Izumi V Supertoughness: Very similar to the ECO, has a nice screw pin master link, loudest of all of the above....but it's sorta bling. (not a great value at all)...and I'm OK with that Combined with a disc wheel, it actually sort of growls as you approach from behind during match sprints. I've had guys say, "I heard you approaching but I wasn't sure what was happening..."
There are lots of other great chains out there. I just stick to what I know personally.
I raced on the KMC 410H all last week and had no issues.
K-
#122
Elitist
Liked 92 Times
#123
Quoted: 100 Post(s)
I'd ask the folks at https://www.retro-gression.com
#124
The whole master link is not available for the Japanese chains, but the tiny screw and locknut is. That said, the KMC motorcycle-type circlip master link also works.
#125
Quoted: 70 Post(s)
Liked 5 Times
Just FYI chains don't stretch over time. Chains are subject to stretch when load is applied but it's not something that changes over time. What people commonly refer to as "chain stretch" is caused by wear on the rollers both outside where they contact the cog/chainrings and on the inside where they contact the bushing (or in the case of a bushingless chain, the inner plates).
At this point I feel 1/8" chains, like thread on cogs, are simply a tradition thing. Given improvements in steel quality and manufacturing a 3/32" or even narrower chain can likely be stronger than a 1/8" chain could be 30+ years ago. Mountain bikes use 11 and 12 speed drive trains these days and see all kinds of extreme torque.
