Need Help: Alternative tire for Kenda 20x1.2 (32-406)
hello! i need your help especially in tires. I have a classic bicycle made from Japan ALVLAYZ 6061 Heat tech. Tires have different sizes, front tire is 16x1.2 and the rear tire is 20x1.2. So i need to change the rear tire but i can't find same brand and dimension with the stock one here in Dubai. Does anybody knows for an alternative tire or tire size for Kenda 20x1.2 (32-406). Thank you in advance for your help!
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,601 Times
What kind of bike is it for?
Quoted: 791 Post(s)
Liked 1,774 Times
Since it is a 32-406 something like this continental 20 x 1 3/8 should work if your looking to upgrade from the basic kenda's.
Wiggle | Continental Contact II Reflex City Road Tyre (20 Inch) | City Tyres
Quoted: 24 Post(s)
I looked up Schwalbe tires, and they have the correct wheel diameter 406, but the closest width is either 28 or 35. If there's room for a 35-406 tire both Marathon Pluss and Kojak (super slick threading) are available.
Industry guy
This is a good guide:
https://www.schwalbetires.com/tech_info/size_markings
This tire will most likely NOT fit the OP's bike. Fractional size 20" tires (20x1 3/8, 20x1 1/8, etc) typically have a bead diameter of 451 mm. Decimal size (20x1.5, 20x1.75, etc) have a 406mm bead.
The bike industry loves standards. That's why everybody has their own.
SP
OC, OR
Quoted: 791 Post(s)
Liked 1,774 Times
The op states the tire is listed sized as 32-406 which is decimal 20x1.2 and the continentals run about 35-406 which is just slightly wider than the kendas.
Yes, the Kendas already on the bike are 406's. The ETRTO standard for fractional 20 inchers is a 451mm bsd, and 406 for decimal. But leave it to Conti to do it their own way.
SP
OC, OR
Forum Moderator
Liked 6,601 Times
Thread moved from Appraisals to Classic and Vintage.
on by
Quoted: 927 Post(s)
Liked 690 Times
Good thread timing. I am also looking for 32-406 tire suggestions. I have significant tread separation on the two year-old stock Kenda Kwest 32-406 20" for my Bacchetta Giro 20. This could be a fluke. I've only had such tire failure twice in [what I'd consider] not a lot of miles (1500-2000). The other was on some Conti 700-23's. I've had Kendas on other bikes, and they've been fine tires.
Schwalbe lists a 32-406 (not sure if it's the Marathon model), but I'll be darned if I can locate an online seller.
If the OP wants the same 20" rear tire, I found an ebay seller who carries the same thing...Kenda Kwest 32-406. They do international shipping.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I have had good luck with Panaracer "Minits Tough" and absolutely terrible luck with Primo Comets. I heartily recommend trying the former and avoiding the latter.
Kenda KWEST HIGH Pressure 100 PSI 20" x 1.25 Bike Tire ISO 406 Recumbent Fast | eBay
on by
Quoted: 927 Post(s)
Liked 690 Times
Thanks for the input on the Minits. I decided to gamble on another Kenda Kwest since they're less than half the price of a Schwalbe, for example. Also didn't want to waste anymore time searching for an e-tailer with the size I wanted. So many seem to have 1.5" or bigger, or 1.125". Little to nothing in between. I've had problems with other reputable tire manufacturers like Conti and Michelin. My rationale is that a tire with more "meat", like a 35 or 38c, will/should last much longer than 23 or 25c. I've had exactly two sets of 38c on my 20+ year old hybrid (commuter), and easily 10,000+ miles.
