What is this mysterious part called?
Is this piece (the little orange, broken one) called something specific? I'd like to see if I can replace it but have no idea what to search for? "Little orange brake lever part" has not yielded satisfactory results.
Thanks!!
Thanks!!
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Broken pivot pin for a brake lever with safety levers? You may just want to get a new brake, complete.
Hmmmm. I don't know. That is the "safety lever" that allows one to brake while riding the top of the bar. It's a pivot point. Ok. How about we call it
BRAKE SAFETY LEVER PIVOT AXLE?
Quoted: 1188 Post(s)
Liked 1,154 Times
It's broken, the chances of buying a new brake lever pivot shaft for an ancient Dia-Compe lever are zero. Find a similar used lever to cannibalise. They were common in the day. Try your local bike kitchen/ co-operative/ tip shop.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
Too bad you only have 7 posts. The Box of Crap usually has a set of those in there...
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Pivot pins did not come only in orange. Red was most commonly seen, but also in blue and green rarely. Co-op suggestion was the best idea for finding one, or you might have to buy an old bike at a yard sale to get the one part. Good luck!
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 685 Post(s)
Liked 370 Times
I have two or three sets of turkey lever brakes, diacomp, with the red dot. Can you PM yet? They're yours for the postage if you want.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
The specific part you need would be this one: Vintage NOS Bicycle Brake Lever Extension Anodized Stud in Gold | eBay
Note that for mid-1973 and earlier models a different non-machined design was used, which would *not* be correct for your '74 or later bike: Vintage NOS Bicycle Brake Lever Anodized Stud in Gold | eBay
Also note that while other manufacturers used different colors for these studs/pins/dots, Schwinn specifically used orange/gold anodizing on these on its 1969 and later models (before that they were red).
Quoted: 3811 Post(s)
Liked 6,715 Times
I have a drawer full of those parts in red. Glad to send one your way: lerner dot n at gmail dot com.
Eccentric Old Man
Quoted: 248 Post(s)
Liked 173 Times
Thanks all for the helpful replies! Based on the serial number, it looks like the frame was made in November of 1979. However I have read that often the bike is assembled and sold several months later so maybe it's a 1980.
It looks like I need 10 posts to use the private messenger, so I apologize for another throw-away post after this.
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
I also can send you one in GOLD (or orange if you like), LMK, entire lever or just the pivot pin just cover my postage which should be pretty low cost.
Quoted: 241 Post(s)
Dia Compe sells new brake levers for $40.
https://alexscycle.com/products/dia-...afety-levers-1
That would indicate a bike assembled on Wed. February 6th, 1980.
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
I, too, have a stash of similar parts.
If you do not care about the extension ("safety") levers or about keeping the bike original, this would be a good opportunity to consider upgrading to modern aero brake handles, which improve your braking leverage by about 10-15 percent. Otherwise, stick with the good ol' Weinmann handles when you find a replacement pivot or whole assembly (pretty easy either way), but make sure to replace your brake pads with KoolStop salmons.
