Mounting under-BB-shell plastic guides
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 641 Times
On a bike where I think I should resort to passing shift cables under the shell, I keep seeing references to "Shimano Bottom Bracket Cable Guide SM-SP17" or equivalent: LINK But I see some come with no hardware, some come with a sheet metal screw (ugh!) and there are references to an M5 bolt. In some instances I've read of an insert that goes inside the shell (I presume designed to stay clear of bearing cups, etc.) And electing a particular model # during searches does not ensure a purchase means one will get anything other than no hardware or the sheet metal screw. OK, time to "make it right". I would imagine am M5 button-head bolt is not all that hard to find (of course, I'll end up with a bag of 25, and thus 24 left over ). So (a) what would the insert look like, is it possible to make one; I'd presume a nut is too small so now we're talking a scrap of metal shaped to fit, and then drilled/tapped, or (b) isn't the BB shell thick enough to drill and tap directly? Or, of course, if someone else makes a better one...
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Lost
BB shell is beefy enough to drill and tap, no problem. All the big box stores carry metric hardware in stainless steel, just go down to the local HD or Lowes and pick up a couple.
https://less-than-epic.blogspot.com/
Likes For AngryScientist:
Quoted: 7350 Post(s)
Liked 2,475 Times
It’s possible to get lucky and not even need a guide. I tried that on my Super Course, but it didn’t work out. So I drilled and tapped a hole. I was using a cartridge BB, and my bolt was too long, interfering with the BB. So I had to carefully cut the bolt down. Overall, it was pretty involved, but it worked out.
Just Pedaling
Bikes: YEP!
Quoted: 334 Post(s)
Liked 522 Times
Drill a hole and use a self tapping screw. I did it on an old Giant and it never gave me any problems. Use a thread lock or grease on the screw when you put it in to stay. Screws can be had individually at any hardware store (Ace, etc.) I got the plastic guide off the bay for >buck. The screw cost more because I went stainless. Good luck,
Likes For SpedFast:
Bikes: 80s Alan Super Record, 79' Somec Special, 90s Rossin(?) Columbus Ego Triathlon, previously: Bianchi SBX Reparto Corse (stolen) and so on...
Quoted: 391 Post(s)
Liked 813 Times
As others suggested, drill and tap. On my alu CAAD4, PO torn the piece out leaving a martian crater where the orig screw holes were, I drilled a small hole size of a needle just to guide and let a wood screw to make itself comfy.
Barbarian as hell, but it works, actually it just has to keep thing laterally stabile, since the cables are anyway holding it, but its strong engough anyway. No epoxy/etc.. was used.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
I buy mine from framebuildersupply.com. I do a lot of framework, so I order them 10 at a time. They sell them for $0.95 each, 10 for $8. They come with a screw. If you lose the screw, most any M5 screw will work just fine. Length is only critical if you're using a cartridge sealed bottom bracket, as you don't want the screw to hit the sleeve on the BB, so choose your length wisely.
Easy drill and tap into the bottom bracket, which are typically mild steel, as others have noted.
One thing to check, if you have a brazed on cable stop on the chain stay, make sure it's on the bottom of the stay. If it's braze onto the top you can't use one. It may seem obvious, but I've done stupider things in the past.
Quoted: 987 Post(s)
Liked 641 Times
I buy mine from framebuildersupply.com. They come with a screw. If you lose the screw, most any M5 screw will work just fine. Length is only critical if you're using a cartridge sealed bottom bracket, as you don't want the screw to hit the sleeve on the BB, so choose your length wisely. Easy drill and tap into the bottom bracket, which are typically mild steel.
Liked 5,802 Times
Once you install it, you don't see it. The screw works just fine, don't overthink it!
Lost
whatever you put down there, make it stainless. Thats the wettest part of the bike and steel screws get rusty fast down there.
Top Seeded Amateur
+1 on drill and tap.
Successfully completed on a 1973 Jeunet and a 1986 Peugeot PSN-10. The Peugeot already had a hole for the rivet so just needed tapping. Removed the rivet because a) I hate rivets and b) needed her completely stripped for the painter
Use an appropriate length stainless button head screw.
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
I like using threads, some BB shells have a plain hole cause the original plastic guide came with a "split plug" similar to a lot of automotive fittings for trim and shields (that typically fail, but that's another rant). If it's "missing" threads I add them, not trusting "self-tapping" screws or sheet-metal or wood threads.
YMMV
I find I almost always need to trim the length of the (always SS) bolt or machine screw, but I'm used to doing that.
I've found many Shimano guides came in purple (as well as black or blue) and always a bit mystified as to what the "other hole" was for: I always use the one that fits road bike shells (68 or 70mm) and cannot figure out why the second, unless for a VERY wide Mtn bike shell?
YMMV
Quoted: 987 Post(s)
Liked 641 Times
+1 on drill and tap. Successfully completed on a 1973 Jeunet and a 1986 Peugeot PSN-10. The Peugeot already had a hole for the rivet so just needed tapping. Removed the rivet because a) I hate rivets and b) needed her completely stripped for the painter Use an appropriate length stainless button head screw.
Liked 5,802 Times
Yeah, pretty rusty! But it's lasted 8 years with no issues. M5 stainless screws aren't rare, though. Pan or button head would be preferrable, but most anything will work.
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3200 Post(s)
Liked 1,844 Times
Quoted: 3811 Post(s)
Liked 6,713 Times
Huh, never bothered to check! Luckily I rode my 8 year old 650b conversion "Big Red" into work today, reached under and took a crappy pic:
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
I knew a Guerciotti like that. Only the other way around.
Some people have no business holding a brazing torch.
No, it's a pic of your basement
-Kurt
Top Seeded Amateur
I just had Mr. Cheaklas relocate the cable stop from the top to the bottom of chain stay on a '73 Jeunet as part of the restoration precisely for that reason.
Quoted: 987 Post(s)
Liked 641 Times
Unavailable? I am starting to believe you. OK, I got lazy/impatient and ordered one from Amazon... and got a due date further out than "two days". OK, but ten days later still in "label printed" status, not handed over to a carrier. Then I dug deeper, the "sold by" vendor has a horrible reputation, most customers experiencing the same thing as in they sold the item, printed a label, never shipped and never arrived. And the same seller name has a horrible reputation for doing the same thing on Ebay. OK, I ordered another one from another "sold by" yesterday. Shipped ASAP. This AM, already in transit from Baltimore MD which is 30 miles away, so I figure I'll have it in a day or two. I check again, and nine hours later it's in Davenport, FL... 900 miles away! I am starting to suspect either these parts simply do not exist, or someone does not want me to have one. And my project is stalled, I do not want to install the BB (so I can start checking on chain line, etc.) until I drill the shell and install this. Sheesh. Well, it gives me time to check my tap-n-die set and make sure I have M5x0.8mm, and also figure out what size pilot drilled is used before tapping.
When I lived in that area, I once had time-sensitive paperwork mailed using trackable Priority Mail bounce back-and-forth 3 or 4 times between Baltimore and DC before it finally got sent to the correct location - which was in Indiana. As I recall it took nearly 2 weeks for it to be delivered.
And it wasn't a labeling problem. I used one of their Flat Rate envelopes, with all addressing info clearly printed in the correct locations on the places indicated on said envelope.
My guess is that in your case one of the "stellar" USPS employees in Baltimore (who has enough seniority to be essentially guaranteed a job for life) threw the package into the wrong bin, thus putting it on the wrong truck.
If you don't feel like drilling and tapping, glue works. I have used both epoxy and hot glue a few times. A bolt is better, but there is minimal force from shifting on that plastic piece.
Quoted: 637 Post(s)
Liked 1,288 Times
Don't feel bad I ordered a threadless stem adapter form Nevada, I'm in Illinois. After a couple days I checked on it and it was at the USPS Distribution Center in Honolulu, Hawaii! Stranger yet I got it on time! I think by going to Hawaii first it bypassed the USPS "blackhole" at Hazelwood, Missouri.
Quoted: 2324 Post(s)
Liked 4,992 Times
Along the same lines I've used the 3M Auto Trim tape. It's a double sided foam tape that is more than strong enough for this kind of job. I used it to mount sensors/magnets on crank arms and chainstays also and it's held for years.
Steel is real...and comfy.
Originally Posted by ...Well, it gives me time to check my tap-n-die set and make sure I have M5x0.8mm, and [u
also figure out what size pilot drilled is used before tapping[/u].
Quoted: 987 Post(s)
Liked 641 Times
USPS in the Baltimore/DC area is legendarily bad. When I lived in that area, I once had time-sensitive paperwork mailed using trackable Priority Mail bounce back-and-forth 3 or 4 times between Baltimore and DC before it finally got sent to the correct location - which was in Indiana. As I recall it took nearly 2 weeks for it to be delivered. And it wasn't a labeling problem. I used one of their Flat Rate envelopes, with all addressing info clearly printed in the correct locations on the places indicated on said envelope. My guess is that in your case one of the "stellar" USPS employees in Baltimore (who has enough seniority to be essentially guaranteed a job for life) threw the package into the wrong bin, thus putting it on the wrong truck.
... after posting I did a search and 4.2mm seems to be correct and my drill index does not have that, of course. So, back to Amazon (ZERO chance of Home Depot or Lowe's having it in stock, the locations near here would surprise me if they had a hammer in stock) so that's on the way. Perhaps a pilot-pilot hole in 1/8" first, then bore it out (I have plenty of 1/8" in case I break one, but only one 4.2mm coming). Hopefully I will soon be able to post a photo of the installed guide!
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
I don't mean to be a McGyvoring heathen but a drop of contact cement would hold that in place for eternity.
Likes For clubman:
