650c wheeled road bike
Quoted: 2700 Post(s)
Liked 486 Times
I just bought a new wheelset (most expensive bicycle related purchase ever at $400!) but unfortunately they are 650c. Ive been trying to get them on one of my road bikes, but the brakes won't reach the wheel and honestly its not even that close, I think my best option is getting a 650c bike? Where can I get one? They are fast wheels, so the bike needs to be aggressive. Some searching leads me to see that this is a niche thing for smaller people.
It has an “8/9/10 freehub” and I put a 9 on it, but I kind of want to put it on a single speed or maybe get a surly fixxer so I can use it on a 700c frame without trying to make/get an adaptor for the brakes. Would that be the easiest way to get it rolling?
Sunshine
Quoted: 10969 Post(s)
Liked 7,495 Times
You spent $400 on old used 650c wheels and didn't realize the size?
That's about as on point as it gets.
I have a 650c road bike inmy garage right now...it's been for my kids between the ages of 11 and 13 because it's small and that's about the only use for that wheel size.
It was hardly ever popular and enjoyed very limited application.
Here is what you do-
- ride the wheels and don't worry about brakes because if you're not first you're last.
- try to sell the wheels to someone else who doesn't know what they are looking at or for.
Side note- are the wheels drilled for Schrader tubes and inserts are being used to fit presta tubes?...or am I not seeing that correctly?
Likes For mstateglfr:
ignominious poltroon
Quoted: 2243 Post(s)
Liked 3,444 Times
Are you sure they aren't 650b? Those are the same as 27.5" mtn bike wheels.
I have 650b wheels as one of my wheel-sets for my all-road bike, which allows me to put on larger tires when I want to ride rough off-road trails. (Mine are disc brake wheels, so I can do this changeover very easily.)
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
Likes For Germany_chris:
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
Yep. A failed tri trend from the 90s. Hard to believe anyone would pay $400 for those.
Likes For shelbyfv:
Bikes: Way too many
Quoted: 900 Post(s)
Liked 607 Times
What was the tri trend; just that they are lower weight and will spin up marginally faster than a 700c wheel? The lower radius could presumably be overcome by a larger front cog.
As for Larry; it sounds like your options are (a) sell them and use the money for a bike that fits you properly or (b) buy an old 650b time trial bike, that should at least be an aggressive enough for you.
Likes For Herzlos:
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Likes For JohnDThompson:
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
Goofin'?
Larry is prolific, and creative; the goof that keeps on giving.
All best,
BC
Likes For BCDrums:
Quoted: 581 Post(s)
Liked 921 Times
Just install on an upside-down bike and keep it in the kitchen as a carrot cutter.
Just kidding, as I am sure you are. No serious person would buy a set of oddball wheels for $400 without checking the size.
Quoted: 8287 Post(s)
Liked 9,062 Times
Tri bikes in the past used these with their weird geometry, like some of the Quintana Roo bikes.
A lady I know who is 4'10" has a custom road frame with 26" wheels. She said she regrets not using 700c.
Likes For big john:
Liked 486 Times
I lost a decent amount of $$ in the stock market cant pick stocks to save my life and with inflation what it is, spinergy wheels seem like a good place to store value. They are only going to go up.
Likes For LarrySellerz:
Expired Member
Liked 5,441 Times
Loud Flushing Noise
And we were feeling sorry for Larry not having the $125 for the Sequoia century ride....
Rider. Wanderer. Creator.
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 394 Post(s)
Liked 782 Times
I'm 5'-8" and rode a Serotta Tri-Colorado with 650c wheels as my road bike for a decade. Great, supple ride, although there was some flex of the bottom bracket when standing and sprinting.
It's a shame that the trend didn't take off for shorter riders. 650c frames for shorter riders don't have funky geometry compromises that 700c bikes have, like toe overlap of the front wheel, little room in the main triangle for bottles, etc.
Likes For john m flores:
Likes For BCDrums:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
When someone's whole life philosophy seems to be "do first, think second", anything is believable.
Quoted: 1562 Post(s)
Liked 1,734 Times
There were a handful of regular sized road bikes made for 650c wheels. For example- one of the Paramount PDG series bikes was 650c wheeled:
The Nishiki NFS Altron/Alpha/Beta was sort of an early tri bike, which still had road bike seat tube angle. The Kestrel 500sci is another one.
Bikes: Way too many
Quoted: 900 Post(s)
Liked 607 Times
But I'm confused, I thought you only rode stuff you got for free/cheap, which is why you're using frames that are 3 sizes too small and seat posts that are over extended?
Wouldn't the $400 have been better spending buying a bike or frame that fit you properly?
Spinergy Rev-X wheels are prone to carbon delamination. You don't want to be riding them when they delaminate. Just a heads up.
Likes For bargainguy:
Liked 486 Times
https://www.ebay.com/itm/29565026174...Bk9SR9SblIz5YQ
If I was to get a bike like this to put the wheels on, is the "52" frame size in the listing directly translatable to regular bikes? Thats the only "size" dimension that means anything to me, and it might be different for those weird looking bikes. Hate the cockpit but its a flashy bike... normally I ride a 58
OK, silly question for a silly thread. If the main impediment to making this work is brake engagement, can you simply fabricate some kind of extensions for the calipers? Either a bracket to mount the calipers lower or extensions for the caliper arms. No ideas for the cassette and skewer thing though.
Expired Member
Liked 5,441 Times
No. Though there are calipers with longer reach. You can use them for 700 wheels on 27" frames and 650b wheels on 700 frames. None are long enough for 650c wheels on 700 frames. If Larry wants to use these wheels, he could dive for a 650c fork. He doesn't need a rear brake.
Liked 486 Times
Jen is right, my partner at work could fabricate a part for it pretty easily. But its not worth the time lol I cant ask him to do that, we are too busy, also the reach would be hella long. He could make it but it would be janky and idk if id trust it, going a bit too far even for me. But yeah he could make the extender easily that was my first thought
Expired Member
Liked 5,441 Times
Go for it!
Likes For shelbyfv:
Likes For urbanknight:
Sunshine
Liked 7,495 Times
