1990 Cannondale ST600 mid-fork boss?
Bikes: 1985 Cannondale SR500, 1990 Cannondale ST600, 1993 Cannondale M700
Quoted: 171 Post(s)
Liked 278 Times
Just decided to add a front rack to this 90 ST600. What is up with the bosses?
My other bikes just have a threaded boss on the outer portion of the fork. These go all the way through the fork. They are completely unthreaded, and stick out about a 1/4” on the inside of the fork leg.
The 1990 catalog shows the ST1000, ST600 and ST400 all have forks with low rider bosses:
https://vintagecannondale.com/year/1990/1990.pdf
Only the ST1000 included both racks. Photo of the ST1000 shows the low rider front rack mounted, with the top of the rack mounted at the boss.
I'm wondering if there was some alternate system for mounting the rack, where the boss didn't need to be threaded.
Likes For bargainguy:
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
Just use a thru-bolt and nyloc nut.
Likes For rccardr:
Likes For Chuckk:
Quoted: 4417 Post(s)
Liked 1,569 Times
It will never strip out, and is less likely to rust. I'm for it.
Likes For Kontact:
Bikes: Aluminum and Steel
Quoted: 105 Post(s)
Liked 379 Times
Sorry for the thread drift. But, where would one find a front pannier rack like Chuckk has? I’ve looked on ebay and have come up empty.
riverdrifter how about a full bike picture? I too would like to add a front rack to my 90 ST400.
“Ride like the wind boy! Ride like the wind…”
-The Voice inside my head, circa 1982
Likes For IdahoBrett:
only here for the "LIKES"
Quoted: 1644 Post(s)
Liked 2,241 Times
Likes For hazetguy:
Quoted: 105 Post(s)
Liked 379 Times
Thanks. Wrong search term on my part. Those will do. Appreciate the links! Sorry OP for the drift…
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 533 Post(s)
Liked 1,007 Times
Those mounts were made for a lowrider pannier rack. Cannondale had their own version and Blackburn made a similar one. I bought a NIB set by accident when I didn't fully read the writing on the box. A couple years later I bought a Cannondale ST400. I haven't used the racks, except to put them on for a trial fit. The hardware included the fork bushings, in case you wanted to drill and braze them onto your own fork.
Blackburn CL-1 instructions
Likes For Pompiere:
Quoted: 171 Post(s)
Liked 278 Times
^^^ Okay, I see how the original racks attached now. That makes sense. Thanks!
Quoted: 171 Post(s)
Liked 278 Times
The bottom photo is the most current. It’s time for a rack, so I can stop strapping stuff all over it. 😀
Likes For riverdrifter:
Groupetto Dragon-Ass
Quoted: 415 Post(s)
Liked 787 Times
where would one find a front pannier rack like Chuckk has?.
Mine is Blackburn, but has a fixed bottom mount and only a single top bar.
It makes me think that maybe mine was purpose built for one of the manufacturers that cut way back on their tourers then.
Touring was supposed to be "the next big thing" but got blown out of the water by mountain bikes.
Merida had been a contract builder up to that point, and all of a sudden they had to market all the touring bikes they had been stuck with.
Likes For Chuckk:
Likes For Chuckk:
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,869 Times
I found a Salsa Down Under rack locally to use with my 1989 ST400. The reviews were bad, but I got it for $20. It worked well for the one mini tour I used it on.
The more useful thing I can add to this thread is that I had to use a pan-head bolt, inserted from the inside, to give me a level of clearance from the spokes that seemed reasonable to me. It could be that the later forks had a bit more clearance?
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 171 Post(s)
Liked 278 Times
Quoted: 1873 Post(s)
Liked 692 Times
Curious why you all would prefer to use a front rack instead of a rear rack? Seems like it would affect handling a lot less on the rear rack.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Bikes: Yes
Liked 3,869 Times
It depends on the geometry, but with the right amount of trail you don't feel the bags low and on the front at all.
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 171 Post(s)
Liked 278 Times
If I was going on long tour, I’d definitely put a back rack on. My trips are mostly just single overnighters, and a lot of riding around town. My bike has to, unfortunately, go on a car rack sometimes too. A small front rack is all I need.
