Crankset for older bike
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
I'm planning to swap out a few components on my 1990's Bianchi Advantage, one which is the crankset. I was told my only option was a square taper one because of its age. Is this the case? Looking at some of the BB available, it seems to me that if I have the right BB shell width and thread I should be able to use an Octalink or Hollowtech?
Please help.
Thanks.
Please help.
Thanks.
Quoted: 18376 Post(s)
Liked 4,511 Times
If you replace the bottom bracket, you can get any crank. Although, I think Shimano is moving away from Road Octalink (still supports MTBs).
Your Hybrid may take the MTB parts anywy. Do you have 135mm rear dropouts?
Bikes: ...a few.
Liked 409 Times
I should mention that I'm planning to put road components on the bike, converting it to a cross bike.
Quoted: 2026 Post(s)
Liked 1,096 Times
Given a threaded bottom bracket, most likely English by the 1990's even on a Bianchi, you have a huge choice of bottom brackets and cranks. Almost any square taper, Octalink or Hollowtech II can be used. Square tapers are limited and Octalink is no longer well supported so HTII is the logical choice. Pick a crank you like and then the bottom bracket to match.
Bikes: ...a few.
Liked 409 Times
Bikes: mid 1980s De Rosa SL, 1985 Tommasini Super Prestige all Campy SR, 1992 Paramount PDG Series 7, 1997 Lemond Zurich, 1998 Trek Y-foil, 2006 Schwinn Super Sport GS, 2006 Specialized Hardrock Sport
Quoted: 59 Post(s)
No, they're really not limited, unless you need 11 speed gearing - which is pretty unlikely for a 1990s bike such as the OPs. There are TONS of square taper triple and double cranks that are optimized for 9-speed gearing and which will work fine with 10 speed gearing. And most of them are available really inexpensively. You can easily find square taper Campy double or race triple cranks for under $120 new, and under $100 clean used, and there are any number of compact cranksets available for much less. The fact that they are older product does not mean they are not very easily found. One can go on ebay and find literally dozens of square taper cranksets, including numerous triples. Maybe they're limited at your LBS, but there are tons of them out there.
Quoted: 1074 Post(s)
Liked 295 Times
Unless I absolutely HAD TO, I wouldn't replace a functioning square-taper BB/crankset with Octalink or Hollowtech even if I was given the parts. There's just not enough of an improvement, and often durability will become worse.
Quoted: 5888 Post(s)
Liked 3,471 Times
Square taper is a fine design and there are good choices out there for an older bike. I'd certainly stay away from octalink.
Bikes: ...a few.
Liked 409 Times
Currently the bike has a triple--48-38,..and I didn't bother to count the last. Triples are less abundant than doubles. My initial question was just to clarify whether or not I can expand my choices outside the square taper ones.
I already have 2/3x8 Sora shifters, so the only choice is whether I run a double or triple up front.
Bikes: S-Works Tarmac, Nashbar CX, Trek 2200 trainer bike, Salsa Casseroll commuter, old school FS MTB
Quoted: 31 Post(s)
As stated the used market (eBay for sure) is saturated with square taper cranks of all types. You can even get campy carbon in ST, and for a rather doable price. There's not much to be gained from a different BB type but weight savings, provided your cranks are good quality. I built my salsa with an older shimano crankset because I had it available and the silver color looks proper on a steel bike. It weighs more than the carbon crank on my go fast bike, but doesn't feel detrimentally softer. Do some looking, or hit up a well established LBS that's likely to have a bin of take off parts.
Bikes: ...a few.
Liked 409 Times
You're right about eBay. I haven't had very good experience with eBay with the last couple of parts I purchased from there, so this time I'm just sticking with local stuff that I can pick up.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Look for NOS and remember that eBay guarantees everything; your biggest problem will be making up your mind...
Today, I believe my jurisdiction ends here...
afraid of whales
Quoted: 347 Post(s)
Liked 5 Times
Lots of nice Hollowtech Tiagra for cheap on ebay, that's what I put on my 1978 frame. Square taper sucks to set up, Hollowtech is a breeze, never going back.
Bikes: ...a few.
Liked 409 Times
Here's another questions: Can I use cranks labelled 9-speed (or even 10-sp) with an 8-speed cassette? Or would the chain be too wide for the crank, and thus premature chain wear?
edit:
Seems Sora cranks are more expensive than the Tiagras. Curious.
Quoted: 59 Post(s)
You're right about Tiagra cranks on eBay. I just did a quick search. I was looking for Sora cranks, just because I have a set of 8-sp Sora shifters.
edit:
edit:
Liked 1,096 Times
Short answer - yes for a 9 speed crank. It's a little dicier with a 10 speed crank. In fact, i've actually found that 8 speed chains work very well in a 9 speed drivetrain overall, and I would recommend using an 8 speed chain with your 8 speed cassette if you choose to get a 9 speed crank, although 9 speed chains will also work fine.
Quoted: 1109 Post(s)
Liked 1,200 Times
I wonder why the criticism of Octalink? I've only owned one, a 9 speed Ultegra triple, but it's worked perfectly for, I think 12 years. Easy to install, easy to remove. Durable. Looks good.
Frankly, I kind of dislike the HollowtechII cranks. I think the non-drive side is ugly and clunky looking, and fussier to install than Octalink. It's not that I actually dislike it, or that looks are the most important thing, but it's just not my favorite.
I recently bought a used Campy Ultra Torque crank and really like the ease of installation (and subsequent removal) and it looks much better - to me - than a HTII crank.
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
I agree. If you don't screw up the spline fit, Octalink rocks. A little heavier, but very durable.
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Liked 1,200 Times
Actually, if you buy a 10-speed crank and want to use the "correct" chain, a 10-speed chain works just fine with an 8-speed cassette. My Surly Pacer beater/rain bike has a 10-speed HTII Tiagra triple crank and bottom bracket and a 10-speed Shimano CN-5600 chain with an 8-speed 13x26 Shimano cassette and an 8-speed indexed Shimano downtube shifter (on a Retroshift brake lever). It works very well and shifting is flawless.
They all shift fine. I think the rule of thumb is that any "higher" chain will work with any "lower" cassette, but not vice versa. The cassette spacing is set according to the width of the chain and a "lower" chain will be too thick and there won't be enough clearance between the sprockets. The inner spacing on all chains is the same, it's just the plate thickness - and therefore overall thickness - that gets thinner as you go up in "speeds". I don't think the cranks care at all about chains, or at least don't care within a generation (i.e. one up or down). The chainwheels don't care because all they feel is the inner width of the chain. Front shifting isn't as precise as rear shifting and therefore the overall width of the chain isn't as important.
Anyway, that's how I look at it.
Quoted: 59 Post(s)
My experience is similar. I've used 9 speed chains with 8,9 and 10 speed cranks and 8 and 9 speed cassettes. 8 speed crank-9 speed chain-9 speed cassette. 10 speed crank-9 speed chain-9 speed cassette. 10 speed crank-9 speed chain-8 speed cassette. And of course 9 speed crank-9 speed chain-9 speed cassette. On my 10 speed cassette, I only use 10 speed chain. But I'd also not hesitate to use a 10 speed chain on any of the above if I needed to (now that I think of it, I might be doing that right now.... I'll have to check.
Quoted: 273 Post(s)
Liked 10 Times
Best thing about square taper BBs is they usually have non-cartridge bearings that can be easily serviced.
Still, proper set-up is essential for any system...
