Whoa! Just calculated my on-ride accessories (inc. pedals) weigh nearly 2kg
I bought some portable luggage scales which are pretty handy for weighing bikes too. I was a bit schocked to see that my carbon commuter (Giant TCX) weighs almost exactly 11kg - a lot more than than advertised "base weight" of 9.2kg. I have a non-stock wheelset (Fulcrum Racing 5 vs Giant PX2), and possibly marginally lighter tires (32mm Vittoria Hyper), so I estimated the accessories to come in at about 2kg.
Here is my breakdown:
Pedals - Shimano M530 - 455g
Lights - Lezyne 800 lumen front c. 200g, Serfas rear 60-80g
Altura KLICKfix bracket 118gr (for bar bag - not included)
Topeak accessory bar 116g . (needed for light when bar bag is used)
Topeak top bag 150gr
Topeak large saddle bag c. 176gr
Topeak Hexus multi-tool c. 170gr
Topeak minipump 82gr
Schwalbe Innertube 28-40mm - 150g
2 x Bottle cages - c. 100g (bottles not included)
Bell - 20gr? (legal requirement)
Sigma bike computer + sensors - 50gr?
Garmin Edge 200 - 65gr
rear fender (SX Raceblade pro) - c. 200gr?
Total: c. 1950gr.
It certainly all adds up!
Some items I would consider absolutely necessary: pedals (duh!), spare inner tube, pump and basic tools (although maybe lightweight versions or a couple of allen keys would do)
Others are normally needed: lights (for added safety even in daylight), bottle cage (& water bottle), bell
And the rest is not essential or strictly necessary, but adds utility: bags (for food, spares, tools, phone, wallet, rain gear), fenders, computers.
I should stress that this is a commuter bike, so I'm not racing it, or going very long distances (about 28km round trip, although there are quite a few hills). I do need to keep the bags for carrying stuff, and if I got rid of them, I'd only have to use a back pack with the same total weight, but less comfort.
I'm curious whether anyone else had gone through the same exercise, and what your total accessory weight is?
If this were your bike, would you be looking for weight savings, and where from?
John
Total: c. 1950gr.
John
I had to double check that this wasn't posted in the touring forum.
Quoted: 1096 Post(s)
TCX? All's I know is, despite the carbon frame, my TCX it the heaviest bike I own. Next in line is aluminum fixed gear, then lightweight steel gran fondo bike. Of course the Helium is the lightest. I carried the Helium and the TXC upstairs yesterday at the same time - I think the TCX must be 8-10 lbs heavier than the Helium (had taken the latter for a ride and picked up the former at the shop on the way home). Those disc brakes, mega cassette, big tires, hefty tubless-ready wheels, Power Strap pedals, the fat ol' 38g CO2 cartridge in the spare kit, etc. all add up....
Quoted: 7628 Post(s)
Liked 3,448 Times
Including water I think I carry 6-7 lbs of gear ... and the water apparently weighs three pounds, so four pounds of gear. My pedals and bottle cages are pretty light too ..... of course light pedals are pricey and maybe not as durable but Nashbar makes 20-gram cages and sells them for $3-$6 or so. I try to always bring a couple powerbars and a gel or two, and as for tools ... multi-tool, chainbreak, three tire levers, sometimes a spoke wrench (only need it when I don't have it) and some spare quick links. And usually some glueless patches and a couple boots. And a seat bag and a top-bar bag for easy access to food (with my bad shoulders fishing for things in a jersey pocket can be painful and dangerous.) Also I like to run at least a real headlight and a blinkie up front (usually two headlights), and two tail lights .... if one dies, the other might keep me from dying, so .....
I know for tools I could risk it and go with a Y-allen key and a reversible screwdriver 90 percent of the time ... but I had a chain pop twice several days ago, so that chain break and spare links .....
I figure since I am not racing ... that's the Honest weight of a rideable bike.
We get mesmerized by numbers---15-lb bike, 16-lb bike.
Unless you have a caravan for support, you are not reliably and regularly riding a 15-lb bike, sorry. Even $15-k bikes can get flats or snap a cable. And those UCI race bikes look so clean ... because they don't carry any tools or lights or anything. And of course bikes are listed at "Showroom" weight. On the one hand it is to have a standard ... on another hand it is to get us all lusting after lighter bikes. Like four or eight ounces makes Any difference to anyone who doesn't race professionally.
I don't care how much the necessary gear weighs,. So long as I am not bringing stuff I never use and never have used ... i am bringing stuff that at one time or another I was absolutely thrilled to have.
Quoted: 18319 Post(s)
Liked 4,487 Times
Are you sure you need pedals?
You could certainly cut a lot of weight if you wished.
My XPedo R-Force, 170g (M530, 455g), savings 285g.
Cygolite Dice HL 150, 30g (Lezyne 800, 200g), savings 170g.
Cygolite Dice TL 50, 30g (Serfas rear, 80g), savings 50g.
King Titanium cages: 56g (pair) (above, 100g), savings 44g
Savings on those couple of items, 549g, or 1.2 pounds.
It becomes more important when the impact of not having the right piece of equipment to fix your bike becomes greater - e.g. being 50km from the nearest town, without cell-phone coverage.
Personally even having to walk more than a couple of km, or paying $30+ for a taxi is enough incentive for me to take everything I might need to finish my commute.
But I will start to consider my inventory for each route more carefully.
Liked 4,487 Times
Quoted: 18318 Post(s)
Liked 15,262 Times
Am I the only one a little creeped out by a product called "XPedo"?
Quoted: 1722 Post(s)
Liked 1,272 Times
I have my steel Guru down to 17 lb. 10 oz. with just pedals. After I add bottle cages, rear light, tool bag, Garmin,
etc. I'm riding it at 19 lbs even. My tool bag has 2 tire levers, tube, small patch kt and mini-pump and it comes in at a bit over 1 LB.
Quoted: 2952 Post(s)
Liked 3,106 Times
Pedals are accessories?
With a mighty wind
Quoted: 1072 Post(s)
Liked 841 Times
Tube, co2, mini tool, 1 lever, and sometimes a credit card. It's just under a pound.
I do wrap a few inches of gorilla tape around the co2 cartridge.
If I was doing unsupported gravel centuries I'd add a patch kit and mini pump to the mix.
If you do proper and regular maintenance, most of time you just ride.
Quoted: 5218 Post(s)
Liked 3,564 Times
shave your mustache, that should help ;-)
in all seriousness, that doesn't sound bad for a commuter. certainly not compared to the garage I carry
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I went kind of all-in on not caring on my commuter, adding a relatively heavy steel rack, aluminum fenders and a chain cover, up-sized headlight battery. Probably closer to 3 kg altogether. With my already pretty heavy single speed I figured that if weight was an issue, then a little more weight won't make it much worse. On the plus side, I can keep the heavy stuff off of my road bike now since it's all on the designated commuting bike.
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
My bikes weight at least 20-30 pounds each and my avatar is a bodybuilding aid...steel is definitely real.
Phat is where it's at.
Liked 3,448 Times
I could definitely cut the tools and food weight ... but that is the stuff you want when you don't have it. I could put some of it in my jersey pockets .... but it won't weigh any less.
Quoted: 551 Post(s)
Liked 276 Times
Why the Sigma bike computer and and Edge 200?
It makes sense in bike catalogs because almost nobody uses stock pedals on anything other than low-end bikes. Including the weight of a stock pedal would obfuscate the weight that the buyer is actually interested in.
But in terms of cyclists describing their bike weights, it rarely makes any sense to leave it out. Most people treat pedals as a long-term component on a bike.
I use the Sigma for cadence because the Garmin 200 doesn’t have sensors for that. I do use my commute as a training ride too, so have speed & cadence is useful. The Sigma also functions as an odometer for total distance records.
It’s also good to have backup system for distance & speed in case I forget to charge the Garmin, but this is not really necessary for a commute .
I was thinking of upgrading to a better Garmin / Wahoo, to replace the 2 units with a single one, but this would probably weight more!
It’s to get a common baseline for comparison. If you included pedals in the weight, which ones would you use? The lightest possible titanium ones or regular mid-price ones? It would add doubt to the real weight of the frame etc.
What is pretty certain is that any manufacturer who quotes weight will have stripped the bike down to the absolute minimum - probably leaving the air out of the tires :-)
Think of it like sales tax - just add the appropriate surcharge for the weight for your chosen pedals. My speedplay zeros (on my weekend bike) are only about 200gr, less than half the Shimano M530s on my commuter.
