1969 Suburban
1969 Suburban
I have a Chicago made Schwinn Suburban 5-speed.When I go to look it up on the Schwinn website,all I see is other Schwinn Suburbans,just like mine but they have the different models like Collegiate,etc.I would like to know the value of my Suburban 5-spped.I know this isn't much help.Here is the stamp number:ME28248.I know what the M stands for.Not sure bout the E.I can send a pic of the bike to whoever respons back.Its all original except for the seat,rack.Email is kaiserpass07@gmail.com Serious only.
Forum Moderator
Quoted: 3059 Post(s)
Liked 6,377 Times
Thread approved and moved from Classic & Vintage to Classic & Vintage Appraisals.
The Schwinn Suburban was introduced in 1970, there was no Suburban in 1969. Schwinn stamped the serial numbers into the head tubes before they were welded into the frames so you can't always date these bikes by the serial number as it pre-dates the actual bike build by weeks, months or even years. Most likely you have a 1970 Suburban, which was the first year they were built. Unless it is in brand new mint condition it is worth anywhere from $25 to maybe $100.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 957 Times
I've bought a few Suburbans over the years, anywhere from $5 to $15; mens style only. Women's style has essentially no value, men's style not a lot. I've stopped buying them as the market has gotten a lot worse over the last several years. Really heavy bike with bottom of the barrel parts. Condition is everything, all those steel parts are rust magnets.
All original? That means cables, housings, tires, bearings, grease, chain, freewheel, brake pads, etc. are all almost 50 years old. Stuff wears out, rubber dry rots, brake pads get rock hard, grease dries out, and everything requires maintenance. Only a D-I-Y'r could make this work out as it will need a thorough rebuild and new consumables. In the bike world "all original" = needs a lot of service work.
Really only suitable value wise for someone that wants a Chicago Schwinn. While Schwinn made some fine bikes in Chicago, they made many more really heavy and really basic bikes. IMHO, its one reason Schwinn went bankrupt. They were too slow to improve their product, and once the Japanese entered the market, they were caught way behind. Then they decided to solve labor problems by closing their plant.
When I close my eyes and think about 1970 Schwinn Suburbans I see boat anchors. When the planet explodes, all the old Schwinn Suburbans will still be floating around in space for eternity. Lawn art is probably the best thing to do with it. Put baskets on it and plant a tree on it.
Suburban 5'speed
At least I know it's a 1970.Thank you Metacortex.Where did you find that info?I tried,but mothing.Alot of 1970 bikes,but no Suburban.
Why do people that have this kind of stuff think it's gold......
Also, it doesn't apply in this case, and would not for the most part on this site forum, but be careful about asking about evaluations on the net, or even at auction houses. They could completely be waaaaaay offfff!!!! I am talking about anything....
Your best information will come from your own time, and research.
It's rare to have a bike hanging in your garage that is worth hundreds of dollars that you have had for decades. Think about what it cost you new, and look at how it's made. Once you can evaluate a bike based on components, and frame without touching it then you will know!!!
Forum Moderator
Liked 6,377 Times
Quoted: 1589 Post(s)
Liked 2,486 Times
Those frames morphed into Schwinn's early mountain bikes. Great bikes to learn basic bike mechanics. You can buy a parts bike for about what you might pay for brake pads on another bike.
I have nothing but respect for the noble Schwinn Suburban. It's the only bike ever designed by American Engineers to be able to withstand being run over by a 1/2 ton pick up truck and still function normally. Schwinn Suburbans are the holy grail of indestructible bikes. After all the DeRosas, Paramounts and, Peugeots are all rusted out and gone to hell, the Suburbans will still be with us. Fo . ev . ah.
Back then Schwinn didn't start building a given model years bikes until well after the first of the year. However in advance of actually building bikes it did accumulate parts and manufacture frame parts such as dropouts, which were stamped with serial numbers before being welded into frames. As such the serial number does not actually date the bike, it only indicates the month and year the frame part was stamped. Also while the Suburban name was new in 1970, what was essentially the same bike had been offered in 1969 and earlier as the Varsity Tourist.
Suburban 5'speed
Mike J
Bikes: 1975 Peugeot PX-50L, 1971 Peugeot PX-10, 1974 Peugeot PX-8
Quoted: 392 Post(s)
Liked 6 Times
The Chicago serial numbers consist of a letter representing the month of manufacture, a number indicating the last digit of the year (1960 - 1964; 0=1960, 1=1961, etc.) or a letter indicating the year (1965 - 1979; A=1965, B=1966, etc.), followed by a sequential series of five or six digits (e.g. A367584 or CB77584). If letters were used for date codes, they skipped the letters "I" and "O" as they looked too much like numbers. Note: This scheme is for all Chicago built non-Paramount models excluding 1962-1963 Superiors and 1964-1969 Super Sports (whose serial numbers are located on the left rear axle hanger and consist of a single letter code for the month [again, skip "I" and "O"], the last digit of the year and a 3-digit sequential build number -- e.g. 'K6018' is the 18th frame built in October of 1966).
So, the M is for 12th month, December, the E is for 5th year between 1965 and 1969. Frame made in December 1969.
Mike J
Quoted: 392 Post(s)
Liked 6 Times
I think it means the frame was built in December 1969. If it has a headbdge with a 4-digit code, that would tell you the date the whole bike was assembled, not the date the frame was welded together. I don't believe they would have stamped a bunch of dropouts, and left them in a pile to put on whatever frame parts that came along. That doesn't make any sense. It's always been the case that the dropout date was the date the frame was put together, and the headbadge date was the date the parts were assembled onto the frame. I've never heard it any other way. Who knows.....
That is incorrect.When Schwinn built EF (electro-forged) frames it stamped the dropout or headtube with a serial number before that component was welded into a frame. Here is some information about the headtube stamps:https://thecabe.com/forum/threads/sc...tamping.86093/
As with the headtubes I also have bulletins from Schwinn that indicated the dropouts were also stamped before being welded to the frames. Bottom line: the serial number on EF (electro-forged) or FB (fillet brazed) Schwinn frames only indicates when that frame component (dropout or headtube) was stamped, before it was welded or brazed into a frame.The actual frames were built days, months, or in some cases even years later
I would wrap it in aluminum foil & soak it with gasoline. Then, light it on fire as I push it off a cliff in the desert.
Quoted: 57 Post(s)
Liked 41 Times
whiterhino22
1
10-13-18 04:56 AM
laylay0612
3
11-07-16 08:38 AM
rumrunn6
17
12-26-10 10:15 AM
