Broken Handle bars
Bikes: Surly steam roller, bear knukle,big block, fbm sword, litespeed swobo sanches
Broken Handle bars
So I was on my ride home looking to enjoy a nice Sumer like day in Denver.
Was going down a semi steep hill when all of the sudden, my Soma Sparrow handle bars broke.
needless to say after some road rash, a chewed up brooks Cambium as well as my Sidis, I still don't know what went wrong.
I do have a brake on my fixed gear bike. Stem was torqued to specs.
Any ideas on how to avoid this from happening again
Thanks.
Thanks.
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
Where did it break ? Anyway, townie bars are not designed to take a lot of force, so if you were somehow pushing hard on them that might have been a factor in the failure.
The handle bars broke at the edge of the stem
Quoted: 4802 Post(s)
Liked 3,922 Times
Questions: how many miles on them? Years? Crashes? Rough roads? Did you buy them new or used?
Those Sparrows are aluminum and are not heavy. All aluminum bars can be ridden to failure. The better ones just take a long time. The bars of older, lesser and heavier stock tend to break by bending at either the stem at the outboard edge of the sleeve. Newer, higher strength alloy bars tend to break as yours did.
My experience is that it is best to replace them while they are still in perfect working order.
Ben
Ben
Veteran Racer
Liked 764 Times
That is the point of highest stress in the bar and the sharp edge of the stem may have caused a small crack to form, causing the failure. Anyway, I'd suggest not using a wide bar like that on a fixed gear, where you will be applying a lot of force at the grips. I only use townie bars on my singlespeeds, where I just lightly rest my hands on the grips.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Just a thought...were the stem's handlebar clamp diameter and the bar [clamp area] diameter matched? If you clamped 26.0 handlebars into a 25.4 stem clamp, and torqued it down, you'd be cutting/etching into the handlebar. That could introduce a failure point...
The bars are about 8 months old. no crashes. I bought the bars new.
In terms of miles I commute about 250 miles a week.
The stem and bars are 26.0 mm
I think I may go to a 31.8 bar and stem .
Your cog is slipping.
Calamari Marionette Ph.D
I take a small fine bastard file to the bar clamp area of my stems and round the inner edges. I don't mean sharp edges, I mean the edges. There is plenty of clamping area and I don't need any corner or edge digging into the bar.
After a quick look
bars are 25.4 Thompson stem is 25.4
I contacted Soma and was asked to send pictures
Will do so tomorrow
Will let you all know the result
In the mean time I am riding some Nitto Rb018 bars
Will do so tomorrow
Veteran Racer
Liked 764 Times
Wait. Now you are using Nitto RB-018 bars with a 26.0mm clamping diameter with a Thomson 25.4mm stem ? If this is so, you are really flirting with disaster.
I got a new Thompson stem that is 26.0mm to fit the Nitto bars.
I am still thinking to go with the 31.8 stem and bar combination to avoid the failure again.
Veteran Racer
Liked 764 Times
Second, people were riding and racing on 25.4mm and 26.0mm bars for decades w/o any problems before 31.8mm became popular. This is not the reason why you had the original failure.
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
Bikes: 2009 Redline Monocog 29er (fixed); All-City Big Block
That is my problem, I still don't know what I did wrong or if the bars were somehow defective.
Thanks for your help
Successful alcoholic
Quoted: 21 Post(s)
Are you able to post a picture of your stem and bars? I'd be curious to have a look at this failure. I'm currently running a set of Sparrows with a Cinelli Grammo and a set of shims on my fixed commuter.
Extra Medium Member
New bars and only 8 months of use? No way this was a fatigue only failure, there must have been a defect with these bars. If you had to replace your bars basically twice a year, pretty sure business wouldn't be very good.
Droping the hamer since '86
ABQ
Pictures were sent to Soma.
No answer yet?
Will let you know what happens
No answer yet?
