Hair in the wrong place.
Location: Creede CO in summer & Okeechobee, FL or TX Gulf Coast in winter
Bikes: Zenetto Stealth road bike & Sundeal M7 MTN bike
Quoted: 90 Post(s)
Prepping for a century in Texas early May. I know from past long hot rides that hair in the seat contact area will be a major problem. Chamois Cream and such works pretty good but I sure would like a removal solution. Pretty sure normal cutting procedures will result in other problems. Any advice or ideas?
This will probably be my last century so I want it to be a great ride.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Electric Hair trimmer with #1 , i.e., 3mm blade.
Quoted: 18373 Post(s)
Liked 4,508 Times
Hmmm... the last thing you want is ingrown hair.
I don't use any creams, salves, or anything of the sort. I've started using padded shorts.
Personally I'd ignore the hair, and try to get enough saddle time that the buttocks won't be sore. Callouses?
Quoted: 4559 Post(s)
Liked 2,802 Times
Brazil Wax. Or Bro'zilian Waxing, as some folks joke. Painful but gets everything mowed to the roots. Never tried it myself but if I did I'd do it at least a week in advance of a long bike ride.
Life Feeds On Life
Bikes: Too many Motobecanes
Quoted: 4418 Post(s)
Liked 4,526 Times
No comment seriously though a good haircut in those areas makes a more comfortable ride.
64 YO here. On longer rides I've had the exact same issue and have lots of saddle time which doesn't lessen the problem. I decided one day to just shave the areas and see what happens. That was a few years ago. Had absolutely no problem with the shaving technique. My longest 1 day ride was 150 miles and was perfectly comfortable, at least the no hair part.....
Quoted: 18410 Post(s)
Liked 15,530 Times
Sounds like some manscaping is needed.
Quoted: 90 Post(s)
Quoted: 5224 Post(s)
Liked 3,581 Times
I once read some advice about shifting in my saddle, shifting my shorts & occasionally getting out of the saddle while riding to help prevent soreness & other issues from hair follicles. so far, this advice has helped a lot. I also do some man-scaping down there with a hair trimmer. I don't "shave" I reduce the length of the hairs. that seems to help too. plus it provides other, unrelated features & benefits ... good luck with your ride!
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
Hair removal cream for my legs in summer.
That's as far as I go, but where your legs start could be up to you.
Quoted: 1068 Post(s)
Liked 784 Times
