Impressive Upshifts, Impossible Downshifts
Old 07-06-19, 06:07 PM
CyclesWithDogs
CyclesWithDogs's Avatar
I’m working on a Scott mountain bike owned by a very avid rider who has been riding many, many years. The drivetrain is a 3x9 Shimano Altus M370 setup.
My problem is with the downshifting out back. The upshifting (moving from a larger cog to a smaller one) is perfect — one click, one shift. But the downshifting (moving from a smaller cog to a larger one) is problematic. Specifically, shifting from the smallest cog to the next one is good, however after that each subsequent shift to the next larger cog begins with a click from the shifter followed by the chain trying to make the requested move — it makes a racket and jumps around — but never quite lands on the next larger cog to complete the downshift. The only way to make a downshift is to press the downshift thumb lever twice (ask for two downshifts) then, as the chain struggles to complete the second downshift — which will never happen anyway — click the upshift trigger once, thus canceling the request for the second downshift. (Whew!)
At first I thought it might be a bent derailleur hanger or derailleur cage, but the idler pulley and the guide pulley both appear to line up nicely with whatever cog they’re being asked to service. And remember, when they’re asked move from any cog to a smaller one, the indexed shift is completed flawlessly.
I’m now wondering if the problem is that the Shimano Altus SL-M370, having many miles on it, is just becoming worn out. I’m thinking that during the consistently perfect upshifts I’m witnessing, all the shifter has to do is relax and release one index-worth of shift cable tension and let the spring loaded RD do the rest. But conversely, during a downshift, the shifter has to increase shift cable tension in a tug-of-war effort to overcome the RD spring — a task I would argue is a more demanding one on the internal shifter components than an upshift.
I recently opened the cover of a Shimano ST-EF51 shifter (the only way to replace the shift cable on that model) and noticed just how much of the internal components were plastic. I’m thinking if the M370 shifter of focus here is similarly constructed, and has as many thousands upon thousands of shifts on it as it probably has, that some of these components are becoming fatigued and allowing enough flex and play as to make downshifting impossible.
Thoughts?
CyclesWithDogs is offline
Old 07-06-19, 06:37 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1786 Post(s)
Liked 1,259 Times in 868 Posts
I'm thinking you need to turn the barrel adjuster counter clockwise a "few" clicks.
Bill Kapaun is offline
Old 07-06-19, 07:28 PM
AnkleWork
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times in 83 Posts
How rapidly the symptom onset would be a valuable clue. Maybe check for a frayed cable or excess cable friction.
Those shifters can last many hundreds of thousands of shifts.
AnkleWork is offline
Old 07-06-19, 07:55 PM
fronesis
Quoted: 45 Post(s)
Liked 8 Times in 6 Posts
I’d start with new cables.
fronesis is offline
Old 07-06-19, 08:07 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
I agree with AnkleWork's suggestions and would additionally suggest that you disconnect the wire from the derailleur, keep tension in it and work the shifter to determine if it dependably and consistently feeds out and takes up the wire. Maybe clean and lube the shifter too.
It would be easy and not too expensive to just replace the wire and housings, which are wear items and could also be dirty, might make a huge improvement and would give you a chance to set up the shifting ab initio.
dsbrantjr is offline
Old 07-06-19, 08:13 PM
2manybikes
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times in 169 Posts
Yes, cables are the most likely thing. Much more likely than shifter or derailleur. A common problem.
2manybikes is offline
Old 07-06-19, 08:27 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4191 Post(s)
Liked 3,836 Times in 2,294 Posts
I'll add that a worn guide pulley bushing has some of the same effects of cable issues. The pulley should have side play with no significant rocking of the pulley off axis. Andy
AndrewRStewart
Andrew R Stewart is online now
Old 07-06-19, 10:56 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 643 Times in 364 Posts
The first thing that I'd do would be to twist the barrel adjuster 1/4 turn. If that doesn't solve it, I'd check the derailleur hanger alignment with a gauge. Alignment doesn't have to be very far off to cause all manner of wonky shifting symptoms.
Retro Grouch is offline
Old 07-07-19, 05:39 AM
dsaul
Quoted: 713 Post(s)
Liked 796 Times in 473 Posts
The impressive upshifts would tell me that I'm slightly overshifting in that direction and I'd add a little cable tension to improve shifting in the other direction.
dsaul is offline
Old 07-07-19, 05:46 AM
Marcus_Ti
FLIR Kitten to 0.05C
Marcus_Ti's Avatar
Quoted: 2349 Post(s)
Liked 406 Times in 254 Posts
How old/cracked/crappy is the cable housing? Like others, my first guess would be excess friction.
Marcus_Ti is offline
Old 07-07-19, 06:57 AM
mitchmellow62
Quoted: 94 Post(s)
Liked 56 Times in 41 Posts
If I interpret your description correctly, you have replaced the shifter cable. I'd start with the simplest first: check the cable routing for any problem and then adjust cable tension with the barrel adjuster. The cable is pulling the derailleur to the the next larger cog and so more tension is needed. Turn the barrel adjuster out/counter clockwise as Bill Kapaun recommended. If that doesn't work you can look at the possibilities that require more work.
mitchmellow62 is offline
Old 07-08-19, 04:50 AM
subgrade
Bikes: Focus Crater Lake
Quoted: 391 Post(s)
Liked 336 Times in 204 Posts
Also check the derailleur itself for play. If it has been used much, it might have developed a significant play in its bushings which also could cause the need to overshift to get to a larger cog.
subgrade is offline
Old 07-08-19, 05:59 AM
freeranger
freeranger's Avatar
Quoted: 426 Post(s)
Liked 694 Times in 433 Posts
Are brake cables being used for brakes and shifter cables used for the shifters? The windings are different. Just one more possibility.
freeranger is offline
Old 07-08-19, 07:24 AM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 526 Times in 349 Posts
How old is the chain and cassette?
jadocs is offline
jack k
Bicycle Mechanics
13
02-13-18 07:40 AM
bsker
Bicycle Mechanics
10
08-20-14 12:58 PM
Seanimal757
Bicycle Mechanics
4
04-05-13 03:24 PM
larwyn
Bicycle Mechanics
13
02-18-12 07:20 PM
akansaskid
Bicycle Mechanics
3
08-09-10 04:59 AM
