Bike compass?
Bike compass?
Has anyone come across a simple bike compass that works well? I'm looking for something to attach to the handlebars to help in navigating unfamiliar areas. Thanks in advance.
Quoted: 18883 Post(s)
Liked 10,646 Times
https://www.amazon.com/StemCAPtain-H.../dp/B00BO5882C
I know there are flat ones too, and I would prefer flat over a bubble. But if you can't find anything else, there's an option.
Quoted: 3452 Post(s)
Liked 1,452 Times
I found that the stem bolts had enough steel that my compass was off by quite a bit. Steerer tube and star nut are also steel.
I carry a hand held compass that I can pull out of my handlebar bag and use if I left my GPS at home.
Quoted: 4244 Post(s)
Liked 1,348 Times
I'm not sure if any magnetic compass one could consider using attached to the bicycle would generally work (not talking about "working well").
There would need to be some way of eliminating the confounding affect of ferromagnetic metal.
GPS can indicate heading if you are moving. There are cheap GPS units available.
Most people would not find direction/heading, by itself, very useful.
A GPS that also displays a map might be more useful.
Phones have a compass app. If the sun’s out it’s pretty easy to keep track of direction by looking at shadows.
Quoted: 4559 Post(s)
Liked 2,802 Times
I just used a cheap ball in liquid compass combined with a bell on one of my bikes. Off the bike it matched my good orienteering compacss.
But even on my aluminum bike there was enough steel to throw off the accuracy of a conventional compass. I would have needed to switch to non-steel bolts, lockrings on the headsets, etc., to get better accuracy. Not worth the trouble.
That's one reason why I stopped relying on older tech -- compasses and maps -- and finally switched to smartphones for navigation. If I was touring in unfamiliar areas, sure, I'd carry older orienteering gear as a backup. But for most of what I do a smartphone is better. And there are other specialized GPS devices as well.
Thanks for all the replies. This is for the bike I keep in Thailand. I do keep a phone mounted to the handlebars and it does have a compass app, but it has a 5 minute timeout to save battery, and can be hard to see in bright sunlight, and I thought it would be nice to have compass headings at a glance. Some of the rural roads can be confusing over there, and a lot of the smaller ones aren't on Google at all, even paved ones. (And during the seasons I'm there, it's often very overcast or cloudy with no direct sunlight.) But sounds like this just might not be a good idea due to steel parts, as you all pointed out. Thanks again.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
To make a compass work I found that I needed to put it on a nonmagnetic mount that was sticking out very far away from handlebars. Even then the readings could not be fully trusted. One way out is to use a compass on a wristwatch strap, particularly on the side of the watch and take the hand off the handlebars for a reading.
Quoted: 318 Post(s)
Liked 149 Times
I carry a backpacking compass in my fanny pack. The lanyard's long enough I can throw it around my neck and use it that way.
I've only needed it twice. The second time I needed it I had it.
Liked 1,452 Times
There are also compasses available with a wrist band if you wanted to wear just the compass on your wrist.
Quoted: 7345 Post(s)
Liked 2,452 Times
Great ideas, @Tourist in MSN.
