Are flick-stands still being made?
#51
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
Another design is apparently used on some european city bikes to keep the front fork from rotating to the side. I have seen it mentioned in the utility bikes area as I recall. This is a setup with two springs running from a bracket on the fork steerer tube bottom to a bracket mounted on the down tube. Still allows normal steering but the springs are apparently strong enough to keep the fork from rotating much when the bike is on the sidestand or center stand.
A email to a Dutch dealer might turn it up as an add on device. I may try making something similar for my utility bike.
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
#53
Bikes: (3) 1970's Raleigh Sports, (1) 1968 Robin Hood 3 speed, 1974 Raleigh Grand Prix, 1976 Raleigh Grand Prix, 1969 Peugeot UO-18, 1971 Peugeot UO-08, 1980 Giant road bike, 1954 Humber, 1940ish Hercules Popular, 1963 Dunelt, 2007 Trek 3700 mountain bike
When I'm working on a bike in my work stand or have a bike on my car rack, I use what some may consider a bit strange to keep the front wheel from turning; a dog collar. My wife picked up a small sized nylon collar at either Dollar Tree or Dollar General for our dog. It's cheap at a buck, adjustable and has a plastic quick release buckle. It works like a champ.
#54
Great State of Varmint
Liked 15 Times
I recently picked-up a new-in-package Flick-Stand for mountain-bikes from back around 1984ish. With a small rubber-shim, it fit my vintage PUCH racer like a glove. And it's stronger and better designed - IMHO - than the one's made for regular bikes.
Cost: $5.00
(Don't bother. They were sold out inside 20 minutes.)
Cost: $5.00
#55
The Flickstand Alternative
Brilliant! A piece of double sided Velcro that goes around your handle bar and brake lever. Effectively locks your brake, and allows you to lean the bike against a stationary object, and it does not roll away. Won't lock the fork lke the a flickstand, but is pretty effective without that feature. Practically weightless, I Got a pair on Ebay. I got the ones with the Cue Clip Feature. For Double duty! I used to watch my Beautiful Merlin get bumped by other cyclists, and down she would go! NO MORE! The Flicksand was a great idea, and if you've got a classic bike with the proper tube diameter, and you can find one, it's great. The Down side is that unfortunately, it looks kind of silly and adds a little more weight to the bike. Buy one of these little Velcro Flickstand Thingies on the Bay or just make your own.
#56
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
Hello I had some flickstands for sale recently and I may be able to find some more. personally I use this little rubberband trick I was showed years ago.
Sugar "Kane" Kowalczyk
#57
Bikes: 1976 Raleigh Super Grand Prix
Still have one on my old Raleigh. One of the more clever bike gadgets: simple and effective, it keeps both the fork and the wheel from rotating, and I don't think it weighs more than 20 grams. I think it sold pretty well when most bikes had 1-1/8" steel downtubes, but you'd have to keep twenty sizes in stock today, or maybe re-design it with an adjustable strap.
#58
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Quoted: 5 Post(s)
Liked 7 Times
"I feel like my world was classier before I found cyclocross."
- Mandi M.
- Mandi M.
#59
Quoted: 2026 Post(s)
Liked 1,096 Times
Wow, this thread has more lives than a cat. Started in 2005, resurected in Sept. 2009 and now it's back again.
#60
Gear Hub fan
Last I checked both Clever Cycles and Wallbike import the Hebie Stabilizer. Not on their web sites so phone or email tem. This is a spring device which runs from the fork crown to the downtube. It prevents front wheel flop but will not prevent front wheel rotation. No noticeable effect on bike handling so you install it and forget it.
#61
Quoted: 7348 Post(s)
Liked 2,462 Times
I recently flipped a bike with a Flickstand. I should have taken it off and sold it separately!
#62
Bikes: 78 Gios Super Record, 74 Colnago Super, 54 Hetchins Vade Mecum, 50's Royal Nord Commander, 67 Atala Record, 80s Univega Italsport.
I sold my Miyata 1000 touring bike on ebay recently. It was kind-of a frankenbike built up with good stuff of all brands and eras. So I didn't keep the Campy 50th anniversary front hub, or the Nuovo Record rear derailleur, or the Super Record seat post in mint condition... one can find those all the time on ebay. But I did keep the flickstand, one of two that I own. My other bikes, vintage or not, use a heavy-duty rubber band or an old toe-strap at the downtube to the front wheel, but they're just not as efficient. I'm working on an improvement to the flickstand though. Patent pending...
#63
Liked 2,462 Times
I tried to align a flickstand on a bike I was working on last week. I was fixing it up for a neighbor. The plastic band broke. :-(
#64
Flickstand, By Rhode Gear , I don't think the company is in business by now..
Useless on a bike with Mudguards ..
Wide Rubber band from valve stem over down tube and back to valve stem works great and is cheap & simple..
#65
Quoted: 2323 Post(s)
Liked 4,983 Times
For those that have never seen one. Here's a shot of my 1985 Raleigh Team USA with the Flickstand engaged.
Steel is real...and comfy.
#66
Bikes: 2011 Specialized Secteur Elite Apex
Im getting into biking after a 35 year hiatus. I just ordered a bike and asked the LBS if they had flickstands. They looked at me kinda funny and sneered, "no!" I was really disappointed...
#67
Quoted: 195 Post(s)
Liked 207 Times
I can lean my bike's rear wheel -- and only the rear wheel -- against a tree, wall, or whatever, and it'll stand upright and not tip over. If I am being more careful then I just lean the whole bike against a wall, with the edge of the saddle and edge of the handlebar contacting the stationary object.
#68
Quoted: 623 Post(s)
Liked 396 Times
I used a Flickstand in the 80s They just don't work with fenders. Now I use a Click-Stand with the the elastic band that comes with it for the brake handle. I also use a steering stabilizer.
#69
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I use a strap that loops over the lever then around the bar fastening with velco. Locks the front brake and stabilises the bike when it's leaning against something.
#70
Quoted: 1062 Post(s)
Liked 665 Times
I gave mine to my son. He's got the only bike in the family fleet with the right tubing diameter, no fenders, etc.
For my own bikes, I've gone full kickstand.
#71
Bad example
Quoted: 823 Post(s)
Liked 205 Times
Zombie thread!
#74
Quoted: 1034 Post(s)
Liked 1,290 Times
Now that the zombie has awakened, there is also this: https://velo-orange.com/collections/...eel-stabilizer
