700C in a 650 fork question
Hi... anybody knows if a 700C wheel (tubular) will fit fine in a 650c fork? Just wondering if the clearance could be like 3 mms or so... I did my calculation and might fit fine but actually the experts are here... thanks in advance..
UM
UM
Cornucopia of Awesomeness
shouldn't even be close.
there's, like a 7 cm difference in diameter.
unless it's a fork built for massive knobby tires.
Quoted: 3450 Post(s)
Liked 420 Times
The radius of a 700c wheel is 25 mm greater than that of a 650c wheel. You wouldn't expect to see too many 650c forks with 25 mm extra tire clearance because it kind of defeats the purpose of using the smaller wheel in the first place.
Regards, Anthony
Regards, Anthony
HI i was just asking because i thought in put one of those 650 forks in a track frame, in that way I didnt have to deal with trying to get a track fork, stuff quite hard to find sometimes...
hateful little monkey
I doubt it'll work. My 650c bike has clearance for a 650x23 tire and no more, ever.
Now, if you've got your hands on a 650b fork, that's different. I doubt that's the case, though.
