Fat Stem
Quoted: 19 Post(s)
Fat Stem
I just put a Bell extra thick inner tube on my rear wheel. The stem is so fat that it won't go all the way through the hole in the rim. Most of it is sticking through but about a quarter inch is inside the rim. Will this cause any problems for me in the future?
This tube does weigh a lot but it is offset by leaving my tools and patch kit at home. My maximum distance away from home is seven miles in my town so I could walk home if necessary.
POWERCRANK addict
Did you get a presta or schraeder valved tube? Some rims are drilled to only accept presta valves.
NB always take everything on wiki-let's make crap up-pedia with a massive pinch of salt
https://en.wikipedia.org/wiki/Presta_valve
https://en.wikipedia.org/wiki/Schrader_valve
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
Quoted: 19 Post(s)
The rim on the bicycle is a 26" with Schrader valve stem holes. The tube stem is a Schrader. The tire is a 26 X 1.95.
Is it possible to go back to the store and see if they're all like that?
Quoted: 19 Post(s)
The tube is made with extra thick rubber on the bottom to add extra protection. It also has Slime in it. Perhaps the extra rubber is throughout the tube but more so on the bottom.
The rim tape hole is not blocking the valve stem.
Personally I don't know how having the stem not sticking out all the way would be harmful to the inner tube. Since this is the first time this has happened I don't know what could happen. That is why I asked here, because some people here might have experienced this.
The valve stem is maintaining its position. It can not be pushed down into the tire while the air is at the maximum recommended pressure.
Does the metal part of the valve stem go all the way to the tube? If it does then if there is wear around the stem it shouldn't cause a leak. I've never cut up a valve stem so I don't know the answer to that.
