Help building a gravel with 60mm/2.35" tires
Quoted: 54 Post(s)
Adding a few more off-the-shelf options:
Raleigh Stuntman
Soma Wolverine
Rawland Xsogn
I've ridden with the Schwalbe Big One 27.5 x 2.35" (predecessor to G-One Speed) on the road. It's definitely a fast-rolling tire. The ride quality with tires that large seems more sensitive to tire pressure than with narrower tires.
Raleigh Stuntman
Soma Wolverine
Rawland Xsogn
Unfortunately those 3 sugestions won't fit big tires!
Quoted: 54 Post(s)
Quoted: 54 Post(s)
That was a lot of info and qurstions, so ill just stick to #13 of your post.
Consider https://www.gevenalle.com/shifters/ for 3x11 shifting. I have them set up on a 2x11 gravel bike and love the setup. Flicking the shifters back and forth is easy and the Microshift bar ends are well made.
I just think at this price I could get Athena 3x11 ergos. I already have that groupset on my road bike, it would even make it easy to canibalize one of the bikes if I crash one of them and need it more than the other.
Or I could just use Tektro levers and bar ends to save some money... The only thing that would make me buy them is if they were crazy light, as I'm a weight wheenie! But they offer no weight info for the combo...
Don't you think I can just drill a common Tektro and bolt Microshift's on them to do basically the same?
Sunshine
Quoted: 10955 Post(s)
Liked 7,485 Times
I've seen them, they look interesting. Are the shifters Microshift?
They are microshift bar ends, yes.
Is 3x11 Campy even available new?
You are looking for an incredibly specific bike, mentioned multiple custom bikes, mentioned this bike may be custom, but saving a bit on shifters is the priority?
Just surprised.
Quoted: 54 Post(s)
What is your budget? Both frame/fork, and for components?
This shopping list of wants puts you in custom territory, simply on the geometry front alone. I can only think of one CF front fork that can fit 60mm tires, and it is 480 axle-crown length, so you're probably going to need a steel fork.
Fitting 60mm tires is also a problem on the chainline and gearing front.
Triples are dead WRT 11 speed indexed mechanical. Only if you use Di2 XT or XTR can you use triples with 11s. If that is beyond your budget, then you'll need to shop NOS 10s.
But I was thinking 2000 up to 3000 full bike.
My road bike costed about $3000 with Columbus Spirit custom frame and Futura fork, Athena 3x11 groupset, 2 wheelsets (training and light climber), two cassettes, 4 chains, 3 pair of tires... 6.8kg race ready and 7.3kg training. I did research each and every part in dozes of websites and bought everything with clearance prices... Including tubes, and then I gave them to the builder with the CAD already made. But that took me 1 and a half year from the day I started researching and buying parts....
The price above should include a second pair of stronger tires probably, but only one wheelset this time.
There are 26" forks that would fit a 29x60mm, quite a lot of options, I just don't know about their qualities...
3x11 is possible in a few ways besides Athena 3x11 road groupset. Any 10 and even 9 speed cranksets will work with 11 chain, and I could even get custom rings and a Lightness carbon crank. Bar end shifters can be fit to drop bars, or I can use friction bar end for the front and a Sram x1 right shifter. Any long cage rear der should work with a matching shifter, and there are plenty front der options, including mtb and 10s road (or athena triple front, but that's made specifically for a 52/39/30 ring combo). Yet I could use Jtek shiftmate for some extra options.
I still might go the cheapest route at the sacrifice of some extra 2kg on the bike, that would save me hundreds of dollars...
Quoted: 54 Post(s)
After the novel you wrote, the last thing i figured would be a motivator was saving $50 to $80 on shifters(compared to bar end plus tektro). My Gevenalle were $160 from UniversaCycles, not sure whats available internationally.
Just surprised.
Just surprised.
Athena 3x11 parts can still be found if you look for it. I bought mine 1 year ago for $160
If I wanted 3x11 shifting, I’d use SRAM Rival/Force 1 shifters plus a friction bar end front shifter, a SRAM GX (or 10-speed X9/X0) rear derailleur, and an X9 triple or Shimano triple front derailleur.
Quoted: 54 Post(s)
Btw, cool username! I just dont agree with that - one must have a cheap single speed to tie to a post while buying bread.
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
Reading your original post I was thinking a Salsa Fargo frame might work for you. But then I saw the part about your preference for a radically vertical seatpost and I've got nothing in my experience or reading to relate to it.
With a zero-setback seatpost and saddle moved forward on its rails I've turned a 71.5 degree seat tube into about the equivalent of 73.5 degree setup. A slack frame can be mitigated by these means to achieve an aggressive riding posture.
Quoted: 54 Post(s)
74 angle with zero setback and forward saddle probably gives me the same as 77 with the saddle back, so I should be fine. And I wont TT on such a bike anyway. Tuning handle bar pos by changing stems and spacers is always easy too.
Quoted: 722 Post(s)
Liked 353 Times
Whh the large tires?
Seem s tad over kill. I just bought 1.75's as I want more road speed as my current 2.0 are just to large for the task at hand.
My MTB has 2.35 tires and it is a full Hard tail XC race bike.
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
Did you try light slickish fat "road" tires like G-Ones? They ride nothing like 2.35 on your XC race bike
Quoted: 54 Post(s)
Sad old "news"
I found out today that drop bars were forbidden by UCI back in 2012 for mtb (and XCM) racing. This makes a bike with light parts and possibly custom light frame and carbon fork quite pointless.
I must now choose between a heavy tourer with not too low drops or a flat bar non-suspension bike for racing XCM. Can't have both in one.
There's really no point to make a bike that puts me in a better aero position if I cant race it. Even in Brazil races follow UCI rules! Low and narrow flat bars with extension could give me a low bullhorn-like bar, but then I wouldn't have tops to rest or climb. I have ridden a hybrid like that before, but only on asphalt. Gravel road racing isn't a thing around here eighter so this bike would be pointless!
I'm more prone for the tourer option now. Custom steel frame&fork and cheaper parts can give me what I want for that. And also save me lots of money. UCI just sucks.
Suddenly the FarGo looks nicer LoL
Quoted: 722 Post(s)
Liked 353 Times
Nope I bought sadly a cheap heavy 1.75 x 26 and I am happy but they are BEASTLY in weight....600 plus gams per tire.
But I am sure never to get a flattire EVER....that being said 1.5 x 26 may be OK now that I see the size
Sunshine
Liked 7,485 Times
It fits a wide tire, yup. The rest isnt exactly what the OP asked for, but there really isnt anything around that Ive seen which matches what the OP wants.
Did you create a profile just to post about a bike that doesnt match what someone asked about 16 months ago?
