Tips and Tricks
Tips and Tricks
Old 08-06-05, 08:07 PM
Bikepacker67
Bikepacker67's Avatar
Bikes: LHT, Kona Smoke
Liked 3 Times in 3 Posts
Generic powdered juice mix, plus a pinch of salt and a pinch of salt substitute makes a CHEAP and effective Gatorade substitute.
A velcro strap about 8 inches long, can be used as a "parking brake" by wrapping it around your front brake lever and securing it to the bar. You can lean your loaded bike against any vertical surface, and it won't roll out from where you put it.
Cars are like wolves... they travel in packs.
No matter how desolate the road, when one car is seen in the rear view, you can bet, that two or three others are close behind. Never relax after the first one passes.
Add your own....
Bikepacker67 is offline
Likes For Bikepacker67:
Old 08-06-05, 09:15 PM
locky63red
Always empty the last bit of metho back out of your trangia in the bottle before you pack the stove away in your panniers.
locky63red is offline
Old 08-07-05, 05:07 AM
MichaelW
Quoted: 19 Post(s)
Liked 7 Times in 7 Posts
Pointy metal objects (such as mini tripods for a camera) should not be stored loose in a pannnier packet. They bounce up and down and wear a hole through the material.
MichaelW is offline
Old 08-07-05, 06:25 AM
onbike 1939
onbike 1939's Avatar
Bikes: Airnimal Chameleon; Ellis Briggs; Moulton TSR27 Moulton Esprit
Quoted: 3291 Post(s)
Liked 827 Times in 583 Posts
Add a small amount of water to the meths for your triangia. No more soot on the bottom of pans.
Mix oatmeal with brown sugar,dried fruit and powdered milk. When mixed with water hot or cold this makes a good breakfast or emergency food.
Use a small cut-down length of spoke with a hook formed at one end as a chain-lifter for when the chain de-rails.
Carry an over-long spoke when on tour. In the advent of a spoke breaking on the drive side, cut off the end, form a hook which can be hooked through the hub and threaded up to the rim. Tension and if overlong cut down to size so that it doesn't protude through the rim tape.
onbike 1939 is offline
Old 08-08-05, 11:03 AM
stokell
stokell's Avatar
Bikes: Custom built tourer, custom electric bike, beaters everywhere
For extra space in your panniers, use plastic compression bags (like the ones on TV that allow you to remove the air from the bag). Hold them in their compressed stand by wrapping with a velcro strip. My sleeping bag becomes the size of a 2 L plastic pop bottle and comes right back when the vacuum is released.
stokell is offline
Old 08-10-05, 06:30 AM
jharte
Long Live Long Rides
Bikes: 1988 Specialized Rockhopper Comp, converted for touring/commuting. 1984 Raleigh Team USA road bike.
The inside of a pop can is fairly reflective and makes a great night time lantern. Cut a square hole in the side, cut small holes or X around the outside edge (for the 'star' effect), insert candle. Hang from a tree by the tab using bungi cord. I've done this for years.
jharte is offline
Old 08-10-05, 06:56 AM
stokell
stokell's Avatar
You can give yourself a refreshing sponge bath almost anytime. Buy a refill size of unscented baby wipes. put them in baggies and add rubbing alcohol (optional) to each bag. They are great for quick cleanups after fixing the chain and other sanitary purposes too.
stokell is offline
Old 08-10-05, 11:49 AM
David in PA
Bikes: Cannondale C400
* If it seems that your front tire may have lost some air, stop immediately to check it without turning. I did not heed this advice once, and almost paid dearly for it. I knew the tire was getting low, but decided to keep pedaling in order to get to a convenience store. When I started to turn into the parking lot, the entire bike slid on the partially deflated tire, while the bike continued to turn in a tight arc which I could not stop nor control. The bike finally stopped moving on its own. I almost fell, and almost landed in the street. I somehow jumped off the bike and landed on my feet....lucky.
David in PA
David in PA is offline
Old 08-10-05, 05:42 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times in 329 Posts
Bring small luggage straps to attach to your handlebar bag and Carradice bag so that they are easier to carry around grocery stores, bus/train stations, on hikes, etc.
I spent 3 months in Australia with my handlebar bag tucked under my arm every time I left the bicycle for anything. It was uncomfortable and awkward to carry around like that. This year I clipped a luggage strap to the rings on the sides of my handlebar bag, and I can carry it over my shoulder quite comfortably.
Machka is offline
Old 08-10-05, 09:25 PM
acantor
Macro Geek
Bikes: True North tourer (www.truenorthcycles.com), 2004; Miyata 1000, 1985
Quoted: 43 Post(s)
Liked 12 Times in 7 Posts
* Instead of folding and refolding large maps to squeeze into a map case, cut the map into pieces with scissors, and only use the section you need. Smaller sections are easier to deal with, especially when it is breezy.
* Wrap a metre or two of duct tape (or electrical tape) around a film canister, pill box, or something similar. Tape is great for temporary repairs/spontaneous construction projects.
* Carry an old toothbrush for cleaning the chain.
* Before touring with an all-in-one tool like the Topeak Alien or Crank Brothers Multi, make sure you can effectively use the individual tools. I find some of these mini-behemoths too awkward to handle. My toolkit now contains only one multi-purpose tool, a Park Tool hex wrench set that I can use easily. Everything else is a single-purpose tool (needle nose pliers, tire irons, etc.)
acantor is offline
Old 08-11-05, 12:23 AM
Miles2go
Zen Master
Miles2go's Avatar
Bikes: Cervelo R5 - SuperSix
Quoted: 75 Post(s)
Liked 89 Times in 42 Posts
I shared the velcro strap around the brake lever trick with about 60 supported tourers on a tour of Maine several weeks ago. Been doing this for something like 12 years and I'm shocked that hardly anyone knows. It can even slow up an attempted theft enough to matter.
Number two...
Wash your clothes in the sink (bring something along to stop the drains), wring them out, place a dry towel on the floor, place a wrung out article of clothing on the towel, roll up completely, walk on rolled towel, unroll, hang garment, you have dry clothes by morning! I always ask for (and get) extra towels.
Number three...
Instead of trying to upload digital photos through your camera, buy a $20 card reader. They are recognized on all XP machines (in libraries) and upload photos much faster than through a camera.
Number four...
Get your butt outta bed early. It's great to have 30-40 miles in by noon. Then stop riding by two or three in the afternoon. This gives you time to actually experience where you'll be staying for the night. Also, even in relatively busy towns, there always seems to be a room available that early in the day.
Number five...
If you don't already have one, spend the $15.00 on one of these mirrors (A Must Have) if you don't already have one. If you have another mirror then buy this one anyway. Try it out for 15-30 days of riding, or just a few after you get it properly adjusted. You'll gladly give your other mirror away. This high quality device that moves with your head (big help) will become one of your favorite touring tools. A potential life saver and joy to use when riding with other tourers behind you. Totally clear, giggle free image that's large enough to really make a difference. I don't work for the company, but I do own two of these wonders.
Number six...
I'm not telling all...and besides, it's getting late.
Cheers
Miles2go is offline
Old 08-12-05, 11:29 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
A sarong is a wonderful thing! It is small and light so it doesn't take up much room or add to the weight of the load very much and yet ... it can be used as a piece of clothing, as a pillow, as a blanket, and as a towel. It's very versatile!
Machka is offline
Old 08-13-05, 10:06 AM
Mentor58
'Mizer Cats are INSANE
Mentor58's Avatar
Bikes: C-dale T800
I'll wear lycra shorts, I'll wear 'elf-shoes', I'll wear glasses that make me look like the terminator, but I'm not sure the world is ready for me in a sarong.
btw, Machka, I took a quick browse of your site, and really enjoyed it. Looking forward to looking at it more when I get done with my chores today.
Steve W
WHO has a happy cat in his lap right now.
Mentor58 is offline
Old 08-13-05, 12:41 PM
Miles2go
Zen Master
Miles2go's Avatar
Quoted: 75 Post(s)
You'd be OK in Burlington Vermont on Church Street. No kidding. It's a great place to people watch. Where else would you see a dude in his late 20s/early 30s walking around wearing a cape? Or a dress? Or...
Cheers
Miles2go is offline
Old 08-13-05, 01:54 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
Steve W
If your tour takes you into a tropical area you could probably get away with wearing the sarong!
And thanks.
Machka is offline
Old 08-13-05, 02:00 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
Another tip ...
Rather than buying bags of uncooked oatmeal to make breakfast with (which oddly seems to be a favorite among cycle-tourists), and going through all the hassle in the morning of starting up the stove, cooking the oatmeal, and then washing out the cooking tins with the oatmeal that has turned to glue stuck to them . . . buy bags of ready-to-eat granola with the fruit and nuts in it. It is a little bit more expensive, but so much less hassle. In the morning, all you need to do is to add some milk (if you want, you could eat it without), add any extra ingredients you might have, such as honey or more fruit ... and when you're done a quick rinse and the tins are clean.
Machka is offline
Old 08-13-05, 06:05 PM
Camel
Caffeinated.
Camel's Avatar
Bikes: Waterford 1900, Quintana Roo Borrego, Trek 8700zx, Bianchi Pista Concept
...If you still "need" your hot oatmeal, give instant a try. Just add boiling water to your bowl&stir. A little left over hot water is used to clean the bowl.
Camel is offline
Old 08-13-05, 08:53 PM
gregw
gregw's Avatar
OK I had to google "sarong" to figure this one out and I'm with Mentor58, I just don't have the legs for it.
gregw is offline
Old 08-13-05, 09:01 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
Check out the guy with the ukulele on this site ... he's wearing one! Maybe you'd need to carry a ukulele though ...
https://www.kismethawaii.com/
Machka is offline
Old 08-13-05, 09:12 PM
Rogerinchrist
Rogerinchrist's Avatar
Bikes: TREK-520 & 830
NOT gonna happen!
An old sock in the under seat wedge cramed with tools keeps them quite & keeps the hand clean when grabbing the chain for a flat fix.
Rogerinchrist is offline
Old 08-14-05, 06:06 AM
gregw
gregw's Avatar
This time I'll be a bit more clear, I'm not wearing a fruity towel and I don't play the Ukulele, sure I could strum it as good as the next guy, but I don't want to carry the extra weight. Ok Ok, if I had his hat, necklace and goatee to complete the ensemble, I would do it.
Ukulele is not a word you see in print very often, almost had to google that one too.
gregw is offline
Old 08-14-05, 09:36 AM
Mentor58
Mentor58's Avatar
Bikes: C-dale T800
A Space Blanket (aka Emergency Blanket) is a great thing to bring. Folds down to the size of a pack of smokes. tougher than a 2 dollar steak, I've used it as a wrapper over my sleeping bag when it got colder than I had planned, it's acted as an emergency rain shelter and sun shade. I've got an old military model, it's shiny mylar on one side, and OD Green on the other. Got some grommets around the outside edge, and it's a bit tougher than the very thin mylar ones, but still packs down pretty small.
Steve
Who thinks that a space blanket could even double as a sarong if the situtation required it
Mentor58 is offline
Old 08-14-05, 10:03 AM
RiotBoi
bificurated
RiotBoi's Avatar
Bikes: Cannondale 3.0 Criterium
I would reccomend Emer'gen-C as far as a drink mix/gatorade replacement its full of goodies. I liek the orange flavour best. Avoid raspberry.
https://www.vitacost.com/AlacerEmergenC-SuperOrange
RiotBoi is offline
Old 08-14-05, 10:16 AM
KrisPistofferson
Immoderator
KrisPistofferson's Avatar
Bikes: Gary Fisher Simple City 8, Litespeed Obed
I have always been an advocate of the thick rubber band,(like the kind that comes with broccoli and other vegetables,) wrapped 3X around the drops, behind the brake lever. Makes an excellent parking brake, when you loop it around the lever. Also has value as a minor, "WTF"-type theft deterrent, and is super-cheap.
As long as we're on the topic of oatmeal, which to me is the greatest touring food ever, I have tried these two options:
If you're not going up into Saskatchewan or getting too far from civilization, forget the stove and fuel and carry a travel coffee mug and a bag of instant oatmeal. Get hot water at any gas station and voila! OR
If that seems like relying on fate too much, take a lightweight thermos to store hot water in.
Just a couple ideas I've toyed with, but seriously, the rubber band RULES.
Originally Posted by Bikeforums
Your rights end where another poster's feelings begin.
KrisPistofferson is offline
Likes For KrisPistofferson:
Old 08-14-05, 10:58 AM
gregw
gregw's Avatar
Steve
Another good use for a space sarong is as hail storm cover. I have been trapped out in a hail storm with no cover in sight. In my case I used my tents ground cloth to drape over the bike and climb under. The hail was as big as ping-pong balls for a few seconds and this kept me from getting clobbered. And..... certainly everyone could agree that the shinny space blanket is a far more stylish sarong than a drab and dirty ground cloth!
gregw is offline
