2016 Giant ToughRoad SLR2
#526
Quoted: 18 Post(s)
your toughroad looks awesome. I would to know how you get this setup please. I got the 2016 Toughroad SLR2 that I’d like to convert into a 1x10 or 11. Thanks in advance.
#527
Gear List
It's a pretty similar setup to the XT setup above. I just need to pick up a few specialty tools such as a chain whip wrench, BB tool, etc to make the swap.
#528
The Toughroad SLR 2 is on sale everywhere here in the States for $850 down from $1,000. I currently ride a Giant Escape 2 as my daily commuter & touring bike which i love...but was thinking of nabbing the Toughroad for more adventure touring. Especially since i heard a rumor that they might be discontinued. Maybe thats what the price drop is about?
#529
I just checked the website, $850 is the official MSRP from giant. so the LBS should be able to give an even better deal. That makes the SLR 1 an even worse deal since that is not on sale. BTW: i don't like their naming scheme where the lower number is the "better" and more expensive bike.
#530
My assumption (based on absolutely no knowledge :-) or wish is they will update it to have TA and hopefully get rid of the D-shaped seatpost. This basically is a great flat bar gravel bike and someone may want to install a short dropper etc. and hopefully they get rid of that wedge seatpost thing and use a regular clamp. I hate it every time I adjust height.
what concerns me more about the d post is if touring in a foreign country or out in the boondocks, and your seat post gets damaged or stolen...good luck trying to find a replacement.
Also, the $850 price is not the regular price...it’s the sale price. Even says “on sale” on the offical Giant website. I think they are trying to clear out inventory. So maybe the rumors of it being discontinued are true, i dunno. Even my local bike shop has it for $850. Doubt i could get it for less. It’s already $150 off what it was just a few weeks ago.
#531
In winter I wear heavy boots and double-socks, so in winter I need to have the post a few mm higher.
#532
Quoted: 2975 Post(s)
Liked 1,180 Times
The difficulty isn't the allen key, it is to get that wedge loose that is a pain. Or taking the post out to re-lube etc. A clamp with allen bolt would be fine. This kind of prevents sharing the bike with family - I don't do that, but is a concern if someone comes to visit etc.
Matter of fact, it's one of the better ideas in the bike industry lately. The seat is on straight every single time. No need to try and eyeball it up with the top tube.
The likelihood of breaking the seat post or it being stolen is near zero. Not enough to justify not liking it.
#533
I'm looking at buying a 2017 Toughroad SLR1. Can someone tell me if the cables are routed through the bottom tube or are they just covered by the plastic mud guard?
#534
Bikes: More bikes than riders
Quoted: 1443 Post(s)
Liked 759 Times
The Roam bikes have the same downtube protector (that the Toughroad uses) and I think it's the best of both worlds. The cables are protected and stay clean and dry like with most internally-routed cables, but you can also easily remove the protector to service or replace the cables without the use of special tools (often required with internal routing). Everything goes through that downtube protector: both shift cables and the hydraulic brake line.
I think it's a terrific approach to cable routing.
(That said, I have removed the splash "wings" from mine, and use just the main protector/cable tray component.)
#536
Quoted: 13 Post(s)
Hello all, it’s been a while....question for those with more bike knowledge than I.
I noticed my 2016 SLR 2 rear brake is not holding pressure, I bought the brake fluid and bleed kit but it only lasts for a few days and I lose pressure again. Anyone else had a brake system failure ? And if so what did you buy to fix or replace the stocker?
Thanks!
Thanks!
#537
Liked 759 Times
I imagine there's a leak somewhere in your rear brake system -- or a LOT of air in the line. If you don't have an external leak, then I suspect you're not getting the system bled properly. Are you bleeding from the bottom up, pushing from the caliper end and catching fluid at the brake lever end? You may need to push a few syringe's worth of fluid through the system to get all the air out (if a lot of air is in the line).
#538
Quoted: 13 Post(s)
Thanks, I think I have a leak somewhere, I just need to pinpoint where. Are these components rebuildable I wonder or do I just have to buy the whole rear brake set?
#539
Liked 759 Times
In practice, it's often easier to simply replace the entire sealed thing. Fortunately, parts are available online pretty inexpensively.
Edit: another alternative is converting the brakes to mechanical disc brakes (cable-operated). Then there's no fluid to worry about -- it's just cables and cable housings. There are pros and cons to both...potential fluid leaks definitely being one of the disadvantages to hydraulic!
#541
This may have been answered in this thread, but I didn't readily find it.
I bought rear clip-on fenders. but like most they are made for round seatposts. I assume all are made for round seatposts. Since the Toughroad has a D-shaped bost, this doesn't really tighten and stay straight. In addition i have the carbon seatpost version, which may suffer from any rough scratches.
Anyone who has resolved this problem? Maybe a sort of segment of a circle shaped chim would make the post appear round.
#544
Absolutely. This bike has the capability to be completely badass like the Sirrus X Comp. Carbon frame, thru axles and not QR, 11 or 12 speed drive train, etc. Giant completely missed out on a specific demographic of buyers. Granted this demographic would be very select but it would be nice to have something that competes with the Sirrus X.
#545
I just saw this thread pop up in my subscribed threads....
Just a small update on my SLR1. Last week I turned 14,000 miles over on it. It’s still going strong! I only had to replace tires, chains, brake pads, front shifter cable and a pedal.
Here’s to the next 14k!
#546
Liked 1,180 Times
#547
Bikes: Jamis Quest
Interested in trying one of these as a do it all commuter and family ride bike that can go anywhere.
In stock form can you get full mudguards on as well as the rack or would you need to go down in tyre size?
cheers
cheers
#548
Liked 759 Times
#549
Nice. Congrats. The Toughroad SLR1 is my dream adventure touring bike. I was bummed to hear they discontinued the flatbar version here in the US. Only the SLR 2 and rumor is that next year it will be gone too. I may just have to cross the border into Canada to nab one this spring. Enjoy your next 14,000!
Likes For BikeTall:
#550
Thanks! Yes, it’s been a good bike! Since that picture, I have another 540 miles on it.
