I don't want an adventure bike. Options?
#51
Quoted: 1216 Post(s)
Liked 185 Times
Sure - a couple mentioned in this thread: Soma Fog Cutter & Focus Parlane. Both are essentially fat-tire road bikes with what would be considered aggressive gravel geometry but sort of relaxed road geometry. This is mainly due to fitting tires bigger than 25s.
You may also want to look at the Endpoint Coffe Grinder or the Specialized Diverge Expert. There are lots of other models I'm just not familiar with them - Performance and REI have house models as well.
Most of these bikes will fit a 38 or 35 smooth tread tire - anything with knobs is probably going to be limited to 32s. This is inherent in the design compromises mentioned above. If you want fast and aggressive like a road bike you need shorter chainstays at or under 420mm - which barring some wacky seat tube antics - you are limited to 35/38s for most frames. 420+ and you're in gravel bike territory, not saying those frames aren't fast or can't be aggressive but I don't feel they're a match for something with shorter chainstays and wheelbase.
Did you mention what you currently ride? I think you mentioned elsewhere but I don't remember off the top of my head.
#52
Long wheelbase is far more aggressive: if you take a typical road bike to a road ride, it peacefully blends in, but if your bike has 470mm chainstays, people will start scratching their heads and asking questions about it.
#54
Bikes: Cervelo Prodigy
Quoted: 478 Post(s)
Liked 87 Times
I don't want an "Adventure bike". Nothing against them. Just not what I want.
I want a fast, aggressive road bike. The roads just happen to be mixed pavement and gravel.
Think Cervelo R3 or SuperSix EVO but for gravel, fast group rides on mixed surfaces.
I'm looking at the Salsa Warbird Carbon Ultegra. What other options are there?
What else is out there that isn't an "adventure" bike?
-Tim-
-Tim-
#55
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Right now I ride a 2002 Fuji Roubaix updated with modern 105 groupset, compact cranks, C24's and Rubino Pro Speed graphene. I also ride fixed gear on the road, a highly modified Bianch Pista.
What I'm taking away from this is that everything is a compromise. Short chainstays and limited tire width, more relaxed geometry with wider tires available.
Was trail running up @ Allatoona today, thinking about the reality of taking the thing on more gnarly roads. Not sure. Either way, this thread is really, really good.
Really appreciate everyone's posts more than you all know.
-Tim-
#56
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times
#58
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
Alright, this is some of why I posted, to learn a bit about adventure/gravel/road geometry. I'm not good at deciphering the geometry charts.
-Tim-
-Tim-
It's a interesting topic. The goal of riding gravel on a bike that holds speed like a fast road bike is the holy grail for gravel riding.
Using a race level Cyclocross on gravel can deliver speed on the flats and climbs, but the higher bottom bracket, smaller tires and short wheelbase on a true Cyclocross bike is a demanding experience on faster downhill sections at higher speed. Most riders moderate their speed rather than risk instability.
A second issue related to Cyclocross geometry is the ongoing input needed to maintain stability on loose-over-firm conditions common on gravel. It's easier to hold a line on a bike with slack angles and a longer wheelbase than on a classic Cyclocross frame.
I've been using a Carbon Fiber Cyclocross bike for several years. It's fast and response, but requires extra concentration and a little luck when the gravel is soft and the substrate is less than smooth, washboard is common in Missouri. I also have a steel "Monstercross" bike with 700x45 WTB Riddler tires. It's incredibly stable and predictable at 30mph while descending choppy loose over firm gravel. It's extra comfortable over longer distances.
Ideally, a faster gravel bike will be lighter and responsive, like a race-ready Cyclocross with but with more stable geometry and room for a 700x38 tire.
Searching among racing Cyclocross models with lower bottom bracket and room for a 700x38 should yield a result: fast and stable gravel rides with efficiently maintained speed.
#59
Quoted: 160 Post(s)
Liked 97 Times
First thing that came to mind was the Specialized Crux: 425mm Chainstay, 67-71 BB Drop depending on size, can run 40mm tires. That's an option.
#60
Thread Killer
Quoted: 3135 Post(s)
Liked 1,702 Times
Now I'm confused. What makes a bike "fast and aggressive" to you?
For me, 435mm chainstays and a 1040mm wheelbase with 35mm tires (as w/the Devinci) would not be in that category. I've found wheels and tires make the biggest difference in speed both in terms of distance covered and acceleration in relation to other riders. Frame geometry matters less but still important, you'll be sluggin' with cs/wb that long. I recommend chainstays 420mm and under, wheelbase between 990-1010 (M frame) and a comfortable saddle/bar drop with good 35mm tires - very fast and comfortable.
I will say, this ad copy from the Devinci site is one of the top 5 funniest things I've ever seen:
DUAL CORE FUSION
TWO CORES FOR A TRIFECTA
@Spoonrobot
Can you suggest a gravel bike with the geometry you recommend? Not trying to challenge but sincerely asking and trying to learn.
I'm less worried about wheels and tires since these can be upgraded as long as there is enough clearance.
-Tim-
-Tim-
I mean, it all depends on what you need, of course, specifically what kind of roads you ride and how much you weigh, and where you're ready to make sacrifices to the "fast, aggressive" thing.
Personally, I ride a "fast, aggressive" road bike for gravel, and mostly keep it on 30c rubber for that, sometimes 25c for spring training paved road rides. I come in at about 225lbs, and my gravel surfaces are mostly hardpacked or with a thin light coverage of small, natural stones. I also ride proper gravel roads, not singletrack, or double track, or fire cuts or any of that kind of stuff, just rural dirt roads as we call them around here.
My main concern is to have a fast, agile bike that's fun on both paved and dirt roads, something I can fender up for fast, wet spring club training rides on the road and not have feel like a truck, and use for a fast, weekly AM group dirt road ride in the summers, in the fall and winter for the same. Just today I did a 30mi snow packed gravel ride on the 30c tires, was doing 29mph at times on downhills without any issues. Sure, big tires are nice for stability, but they're antithetical when it comes to feeling spry and sporty, mostly.
My gravel rig is a '15 Kinesis Racelight 4S. With matching 73.5º HT and ST angles, 420mm stays, and a 1016mm wheelbase in the 60cm size, it's steeper and shorter than anything mentioned thus far (I think), and subsequently limited to a 30c (slick) max. But, it serves my needs exactly, and I can even get Crud RoadRoacer Mk.3 fenders on the 30c rubber:
Kinesis renamed this model for 2017 as the T3, in order to distinguish it from the Racelight 4S Disc, which has some frame design features which my caliper-braked R4S did not have, but the T3 and R4S caliper brake model are the same. EDIT: I just took a closer look at my 4S "caliper" (4SC) and the new T3, and I was incorrect that they are the same aside from brake type. In fact, they are substantially different. Top and down tubes on T3 do not have the external butting or shaping of the 4SC (or the 4SDisc for that matter). I will write to KinesisUK and ask after the nature of the changes.
Kinesis Racelight T3 Training Bike - Kinesis Bikes
Now, going back to everything said, my 30c do not make me decisively faster than my ride mates running 35c and 38c tires, but, I do think they give me a bit of a slight speed advantage on pavement, and if we were going full out, I'd want every advantage I can get. Whether there's an advantage there or not, what's also important to me is the feel of the bike, and it's good; road-going weight (i.e. with bottle cages, pedals, and 30c tires) is 19lbs, so that helps, too.
The English make lots of bikes like these, which they call "winter" or "audax" bikes, basically defined by the ability to wear larger, like 28c tires, and fenders for nasty weather, but to handle like a racer. For example, the Mason Definition is such a bike, are the Genesis Equilibrium and Condor Italia. And don't forget the Swiss: BMC Roadmachine 03 fits 32c tires. If you really do want larger tire capacity, I'd look at bikes like the Open U.P, which I think I mentioned earlier, the Enigma Ecroix, and the aforementioned 3T Exploro.
Sorry to run on. My point in all of this is that I strongly suggest the OP takes a good look at what they want, what they need, and what's possible, and make decisions based on that rather than what others think "gravel riding" means. Also, remember you don't really buy speed, but you do buy feel and versatility.
Best of luck!
#61
As far as "relaxedness" goes, chainstay length doesn't really do anything. Fit is dependent on the frame's front triangle. You could remove the seatstays and chainstays from a bike, and replace them with ones that put the rear wheel 10 feet behind the cranks, without affecting the positions of the saddle, cranks, and handlebars at all.
Long chainstays also don't doom a bike to sluggish handling.
How a bike feels to handle is mostly dependent on trail and bottom bracket drop. Look at track bikes; extremely short chainstays and wheelbases, but they frequently handle heavier than road bikes, which to my understanding is mostly due to the high bottom brackets.
How sharply a bike can corner on the road is mostly a matter of tire contact stability, which if anything will be better with the wider tires permitted by longer chainstays.
#62
Quoted: 478 Post(s)
Liked 87 Times
There's that close relationship between these two companies.
https://www.3tcycling.com/road/en/ge...tz-acquire-3t/
#63
Liked 185 Times
BB drop doesn't affect handling by itself. It changes other frame characteristics as it changes but to say it is a major determinant of handling is incorrect.
Track bikes could be perceived as sluggish or "handle heavy" because they have high trail - bb height does not affect this. High trail provides high speed stability which is needed on a banked surface. Track bike trail is usually 70mm+, road bike trail is usually 50-60mm. Now, at slower speeds high trail requires much more counter-steer than mid or low trail and turning the handlebars left/right feels harder and slower because the rider is lift/lowering the wheel so much more.
This is really obvious with mountain bikes, a modern 29er race hardtail is anything but sluggish and is going to have trail figures 75mm+. Turning is done by counter-steering and leaning the body opposite the turn while turning the bike deeper into the turn. You wouldn't try to turn a mountain bike like a road bike so it never occurs to most people to make the comparison and describe the bike in that way.
Geometry has a huge affect on how sharply a bike can corner. As trail changes the bike's lean angle changes as well - a high trail bike requires significantly more lean than a mid-trail bike and can easily exceed the grip of the tires at a slower speed than a mid-trail bike.
Dave Moulton's blog is a wealth of information but these posts are germane to this discussion:
Dave Moulton's Blog - Dave Moulton's Bike Blog - Trail, fork rake, and a little bit of history
Dave Moulton's Bike Blog: Squirrelly
Dave Moulton's Blog - Dave Moulton's Bike Blog - Bottom Bracket Height
This is a great post - I had forgotten about audax bikes.
#64
Quoted: 1872 Post(s)
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
#65
-Tim-
-Tim-
#66
Longer chainstays change the way a bike feels under acceleration, especially out of the saddle, and works with trail and fit to determine how fast a bike will want to turn left/right. Some riders, by virtue of their fit and how they turn their bike are less sensitive to cs length than others. Long chainstays and extremely long chainstays provide obvious additional frame compliance this comes at the expense of responsive to pedaling inputs and cornering ability. Now, for some people the difference between 415mm and 430mm is nothing and they don't notice - to others it is noticeable.
https://davesbikeblog.squarespace.com...f-history.html
In fact during normal cornering the front wheel turns very little, making this whole theory about the front of the bike going up and down irrelevant.
#67
I've been looking for the same thing as you are. A decent gravel bike that doesn't put me sitting up like a hybrid bike. The new Fuji Jari has caught my attention. I'm supposed to go test ride one as soon as my local Performance store gets one in stock.
#68
- Soli Deo Gloria -
Liked 736 Times
I wish I had titled this thread more along the lines of this.
Not sure that "adventure bike" was the right term or if it is really a matter of semantics but that's what I want, a more aggressive, sporty gravel bike with the option to go 40mm tires if I choose to ride on rougher stuff.
A few bikes in this thread have piqued my interest.
#69
#70
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
#72
Where di dyou find the Tamland 1 for $799.
#73
Quoted: 910 Post(s)
Liked 288 Times
Jackman won the 50 miles Red Dog Gravel Race in Missouri on a Fuji Jari last year.
#74
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I agree that if you are doing fast downhills, with turns that push your ability, a stable low gravel bike would be the way to go.
For me, that isn't my limiting factor. I need a bike that can thread a single track, or handle sharp changes in direction in an urban environment - one that can turn quick and hard. So, I choose a cyclocross bike:
I
- t feels snappy/lively, not "stable"
- It has a higher bottom bracket so I can power hard through a sharp turn without pedal strike,
- Reasonably short chain stays allow me to snake through urban or rural obstacles,
- reasonably steep head tube angle makes it responsive to steering inputs.
- Higher b
#75
Liked 415 Times
Who makes track bikes with 70mm+ of trail? Most of the big builders have it at pretty similar to their road bikes, sometimes very slightly higher. The only notable exception seems to be for the very small sizes, where it looks like the use of 700c wheels is making the geometry a mess (i.e. Specialized's Langster goes from 69mm in the smallest size to 50mm (!) in the largest).
