My first set of Compass tires, $162.00 waste of money
Quoted: 18369 Post(s)
Liked 4,507 Times
Tubeless Standards, see Post #14
SEAL THE DEAL
To The Point - UST Rims and Tires
It sounds like it is time for Tubeless tire and rim manufacturers to sit down around a big table and start hashing out a universal standard.
We're now nearly 20 years into this tubeless thing, and patents will begin to expire soon.
UST seems to be pretty specific about the locking mechanism.
The WTB ST i25 tubeless ready rims (not STP) seem to indicate a UST compatible design.
WTB ST Rims
I can't find any notes on Compass of the actual standards they are attempting to follow.
I bought a pair of once-mounted Bon Jon Pass tires. It is hard to tell for sure, but it appears as if they have a fairly square bead, so they may well be UST compliant, although in theory true UST shouldn't require sealant.
I have a pair of Schwalbe One Pro tires. The bead seems much rounder, so I'm thinking Stans BST.
Anyway, if Compass is, in fact, using UST or similar, then it should have been fine, as long as the beads were properly seated. But, they should take the next step and certify their tires.
Bikes: Wahoo of Theseus, others
Quoted: 428 Post(s)
Liked 67 Times
What if you had died from the blowout, then they would owe your family millions.
No big surprise they refuse to pay for rims, no one is going to and no one is liable unless negligence is proven in court. If someone is to blame why didn't your bike store notice the tire has an obvious defect?
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Personally, with a tire like that, I set it up with a tube, ride it for a week or two to ensure it stretches, seats, and takes its shape properly. Then I remount it using a skinnystripper to seal the tire into a psuedo "tubeless" tire so it can't blow off or burp. That has worked for me on iffy tires, but maybe I'm lucky. Ultimately I think it depends a lot on the diameter of the tire and the wheel (which are NOT standard).
Bikes: 1988 Pinarello Veneto, 1983 Trek 720, 1991 Bridgestone MB1, 2010 Kona Bandwagon fixie,1991 Bridgestone RB1,. Schwinn cruiser
I have to be fair and update that later today Compass contacted me through email and has agreed to pay for the damage. The LBS owner told me they talked to him and then agreed to pay. Seems fair to me and surprised me.
Is the ride quality worth it?
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
That is very surprising and speaks well of the company.
I have been a critic of Jan Heine/Compass but have to give credit where it is due.
Kudos as well to the LBS who advocated on your behalf. Sounds like you have a good shop behind you.
Likes For TimothyH:
Quoted: 7348 Post(s)
Liked 2,461 Times
That's a good story. I had a good image of the company in my mind, and this restored it. I enjoy Jan Heine's blog, and I pay for a subscription to Bicycle Quarterly. I haven't bought any of his products, though.
I've had some DIY experience running tubeless sometimes with non-approved and improvised products and although I love tubeless and will always use it I think any new tubeless setup should be considered sketchy until it's been tested and inspected carefully especially if it was done by someone else. There are so many variables involved like the elasticity of the tire bead, leaky valve seals, shape of the rim, the type of sealant and whether there's some dry sealant at the edges. I'm glad it wasn't your front tire and that Compass came thru eventually. I think the manufacturer is reputable and makes quality products. I wouldn't want Panaracer to quit making tubeless-compatible tires for us so it behoves us to be cautious with new tires.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
@rpthomas, do you know if the shop tried airing your tires up to the max rating to test the fit before you got them?
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I created a thread to explain it:
https://www.bikeforums.net/cyclocros...l#post20334985
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,103 Times
Compass tires may have a tubeless bead but they obviously omit any of the other features that make tubeless work well.
Liked 941 Times
Tubeless seems like more trouble than it's worth. Especially considering how nice quality tires and tubes ride. Plus, no messy sealants.
Likes For AlmostTrick:
Liked 4,507 Times
This. The tire manufacturer can try to make their tires with careful design and tight QC, but they don't have control over which rims, tape, sealant, etc it gets installed with.
There are a couple of different rim and bead standards. Specifically UST (square bead) and BST (Stans round bead).
If one creates spec standards on rim design, and the rims adhere to the specs, and the tire manufacturers make their tires to work with those specs, then there is no longer a huge compatibility issue.
Unfortunately, possibly for patent. trademark, or other reasons, very few manufacturers are adhering to the specs. So, it becomes a free-for-all, and "tubeless ready" may not, in fact, be "tubeless compatible".
While the OP's rims may, in fact, be UST compatible, Compass doesn't specifically list their tires as being UST compatible.
Liked 4,507 Times
OH,
Reminds me of doing support for engineers at my previous job.
An Engineer came to me and told me her boss wanted her to look up pool heaters and gave her a link that was being blocked by the company's net nanny.
It turns out the Engineer forgot a very important dash in the website name.
www.hotbox.com link blocked by the work net nanny.
www.hot-box.com Intended link for pool heaters.
Liked 4,507 Times
I have a mini tour heading through the desert and goathead territory, off the beaten path, and thus where cars haven't blown everything off the road.
While I may be able to use tubes, tire liners, sealants, and etc, the tubeless just seems to make sense. At least before heading off down the road.
Liked 941 Times
OH,
Liked 2,568 Times
Not exactly. As mentioned by @TimothyH, and a few notes in my previous post #30
I'll expect the whole industry to adopt one standard around the same time the country goes to single-payer healthcare.
- Soli Deo Gloria -
Liked 736 Times
Guitar Ted suspects that some tire manufacturers are hesitant to claim their tire is one standard or the other as it will limit sales.
These are probably splitting the difference between the UST and BST specs and trying to make tires which work with either type of rim.
Threads like this are the result.
Liked 4,507 Times
Nope,
As far as I can tell, they may work together, somewhat like putting duct tape on a vintage rim and popping on a tubeless tire may work, but there is no guarantee it will stay in place.
For safety's sake (and to prevent issues like this blowoff), one would expect companies to develop and adhere to standards.
It would be like getting Ford and Chevy tubeless rims, and Firestone and Michelin tubeless tires, and not quite knowing if one would work with the other. Yes, I know there are a plethora of tire sizes, but with few exceptions, the rim interface and bead lock are pretty universal.
The bicycle industry has too many standards.... or non-standards. But, say 1 1/8" stems and 31.8mm handlebars are pretty universal now. Yep, there are some older standards, but the 1 1/8 & 31.8 are taking over. Hopefully in the future there will be less need to worry about 25.6, 26.0, or 26.4 bars. Or 22.2 or 22.0 or 21.15 quills
Liked 2,461 Times
Engineers' joke: the great thing about standards is that there are so many to choose from!
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
It is really a bummer all I am reading about issues with Compass tubeless.
I am on my 3rd set of Compass Tires. Stampede Pass, then Bon Jon Pass, and now Barlow Pass. All extralight.
I have looooooved them all. IMO they live up to every once of their hype and then some.
For my last wheelset, I got them built with WTB KOM i21 rims, so I could try tubeless, and I got the Barlow Pass tires planning to run them tubeless. I got them last fall, but just never got around to setting them up.
I planned to set them up this weekend, but when I googled info on setting up Compass tubeless, I read nothing but problems. And then an hour later this theead pops up.
Guess I’ll stick with tubes for now.
Been running tubeless on my MTB for many years with zero issues and easy setup with a floor pump every time.
Liked 415 Times
Yeah, I have too many bikes to run them all tubless. Its pretty much required for anything I'm going to run at low pressure on a rough surface - to prevent pinch flats. Tires these days are so good, it is rare I get an actual puncture on a good tire.
Yeah back in the early days of the net, a co-worker went to the white house web site. But he typed in whitehouse.com. He wasn't expecting what came up. Now that site is blocked at work. It should be whitehouse.gov
and my implementation of standards is better than yours - I have the customization to prove it!
Liked 2,568 Times
Discussions about standards aside, it seems like one should be able to determine whether a combination of parts in hand will work without excessive danger.
A somewhat snug fit of the tire bead is desired here, if you are able to push a deflated but still mounted tire bead off the bead seat and into the well without any resistance, it's probably not tight enough for tubeless, right? So you could install the recommended amount of rim tape (usually two layers) to the bare rim, install the tire with a regular tube, and inflate/deflate. Test pushing the tire bead away from the edge of the rim, and if it's too loosey-goosey, add another layer of rim tape as recommended by Jan/Compass. Once you're satisfied with the fit of the bead you can try setting it up tubeless. Put in the eye protection and earplugs, and take the pressure up to the manufacturer's recommended max. Assuming that works, go a little beyond, looking for evidence that the tire is creeping. Sort of like finding out how far you can push a set of old straight-sided rims, really.
This is all with the caveat that I haven't actually played around with tubeless, myself. Not against it, just haven't gotten around to it yet.
Liked 2,461 Times
@chas58, good one.
Non omnino gravis
I had a 700x35 Panaracer Gravelking SK do the exact same thing, only I was doing about 20mph and my hoop ended up costing me about $90 to replace. Panaracer replaced the tire no questions asked, and I never even thought to bother them about the rim-- these are the costs of cycling. Lost a 700x35 Hutchinson Overide to a pair of drywall screws just a few months later. These things happen. I've had four tire failures (all different brands, no less) just this year.
I have probably around 1,000 miles on tubeless Gravelkings since-- just because one tire was defective doesn't mean they'll all be. I wouldn't boycott Compass because they initially didn't want to pay for the damaged rim. I wouldn't buy from them in the first place, because an $82 tire is just madness. The tires on my car didn't cost $82 each, and they're 245mm wide and last 30,000 miles.
