Hydraulic flush?
Hydraulic flush?
Old 03-18-19, 04:01 PM
Gladius
Gladius's Avatar
Bikes: '86 Centurion Elite RS '17 Trek Domane SLR6 Disc '16 Trek Boone 5 '15 Trek Fuel EX 9 '20 Trek Checkpoint SL6
Quoted: 25 Post(s)
Liked 3 Times in 3 Posts
Hydraulic flush?
Just had all brand new hydro brake levers, hoses, etc. installed. I didn't initially get new pads but have since; the brake levers now go full squish almost to the bars. I've bled my brakes before (I have the Shimano kit) but am not sure if the reservoirs simply need more fluid now (to get them to be stiffer/brake with less lever action). Do I just need to re-bleed them?
Gladius is offline
Old 03-19-19, 09:38 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Probably .. Do you you have the Service manual? it can be downloaded from the internet as a PDF ..
fietsbob is offline
Old 03-19-19, 10:11 AM
robertorolfo
robertorolfo's Avatar
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times in 113 Posts
The mechanic probably pushed the pistons all the way back in order to have enough room to install the new pads. Assuming there is enough fluid in the reservoir (there should be, unless they took some out or spilled some during this process), pumping the lever a few times should eventually push the pistons out far enough to make solid contact again, and firm up the lever.
robertorolfo is offline
Gyro_T
Bicycle Mechanics
4
01-29-18 12:18 AM
Rocket Mouse
Bicycle Mechanics
6
09-30-17 11:59 AM
rzldzl
Bicycle Mechanics
2
05-24-17 04:45 PM
davidonabike
Bicycle Mechanics
8
04-07-16 09:58 AM
thesergie
Bicycle Mechanics
9
04-23-12 12:58 PM
