Chainring Dilemma
Former Hoarder
Chainring Dilemma
So, I'm working to build a gravel bike using a Niner MTB frame. I have a Shimano SLX 2X (675) crank and want to run it with 44t and 28t chainrings. The SLX is a 110/64 BCD.
The larger ring (44) doesn't have recessed holes in the rear for the bolt nuts to sit flush with the face of the ring. The result is these nuts are impeding the chain on the smaller ring. (Note in the photo that the small ring is reversed, making the gap far too wide.)
Any suggestions?
I can't seem to locate any 44 rings that are recessed in the rear...only the front.
Thanks....
55/Rad
Any suggestions?
Thanks....
55/Rad
Quoted: 4172 Post(s)
Liked 3,791 Times
Use a 44t ring that's made to be a middle one so it's ramps and lift pins are correct WRT the counter bores for the nuts to fit flush. This might require a different crank/bolt pattern. Andy
AndrewRStewart
AndrewRStewart
Former Hoarder
Quoted: 336 Post(s)
Liked 309 Times
36 is about the biggest 104BCD ring that you can find as a middle.
If You are looking for something on a budget, I would go to the Community Cycling Center on Alberta and see if they have a older road triple crankset. You can take off the ridiculous 54t outer and use the crank as-is and it should be about the gearing that you are looking for.
The other option is a mountain double that you can find in a 28-38, but you will probably only find new.
SO.. maybe you actually need a 110 - 74 crank, after all, if a 104/64 BCD 44t is only manufactured as an outer chainring..
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
Quoted: 18319 Post(s)
Liked 4,488 Times
Hmmm... tough to find the right tool to do a good flat bottom counterbore.
One might be able to modify one of these to do a 10mm x 12mm counterbore. (verify size).
https://www.snappytools.com/product/...ed-twist-drill
One might be able to do it with a 12mm endmill without a guide, but then it would have to be centered perfectly.
12 0MM Carbide End Mill 4 Flute Metric
Use depth limiter on drill press/mill, or set table to limit depth.
Liked 4,488 Times
Ok, looking at that some more:
These are your cranks?
I see the issue with using the outer ring in the middle ring position.
I thought your rings were without a recess, but it is on the wrong side.
I have thought about whether it would be possible to counterbore a recess into the rings, but the remaining material could get mighty thin.
You might be able to grind off part of the bolt heads so they wouldn't interfere, or use a slightly larger small ring.
Looking at rings. You might try a "Flat" ring that should be reversible.
For example the Vuelta Flat rings.
https://www.ebay.com/itm/Vuelta-Mtn-...k/372593545351
Vuelta Flat Mountain Chainring - $12.95 - Bike Parts 360
Unfortunately I'm not seeing photos of both sides.
Or, try a different crankset.
Bikes: 1974 PX-10E sold, 1977 Witcomb stolen, 1980 Roberts 1 speed, 1987 Cyclops 3 x 6 friction triple crank, 2010 Masi Commuter 1 speed, 2017 Ribble 525 2 x 10 with Ergos
Quoted: 58 Post(s)
Liked 25 Times
If you can move to a 110/74 crankset (typical road triple), then Spa Cycles in the UK will have several choices of suitable middle chainrings. They have TA, two or three grades of Stronglight, and their own house brand in 110mm and 74mm BCDs. Here's the house brand, CNC'ed Zicral 44T middles in black or silver:
https://www.spacycles.co.uk/m2b0s210...l-Middle-Inner
I think Zicral is 7071-T something, and I suspect the supplier is Stronglight. They can fix you up with TA as well, and they are the best rings, period.
