Ultegra 6800 Rear wheel service - Drive side nut came off
Old 03-18-19, 09:32 PM
jjfix
Hi All,
I was servicing my Ultegra 6800 Rear wheel and found a flat ring on the drive side round nut (there's groove for it) cracked in half and fell out. After that, when I used my two 5mm allen keys to remove the round nut on the non-drive side, the drive side loosened instead. So I wasn't able to pull the axle out from the drive side. Now I'm stuck with an axle I can't remove correctly to service the bearings.
I'm tempted to grab onto the threads of the drive side so I can remove the round nut on the non-drive side but that'll probably cause another problem and I'd still be missing the broken flat ring in groove. I need advice or maybe I bite the bullet and take to the LBS.
Thanks in advance for any help. JF
jjfix is offline
Old 03-19-19, 01:43 AM
jjfix
Almost fixed ... serviced for now
Okay, so I'm replying to my own message.
So, I noticed on the drive side i was able to stick a small flat head screwdriver and spin the cone. I backed it out some and the axle came loose. Next thing I know I'm cleaning and re-greasing the hub from the opposite side. Yes, the wrong side.
I guess i will see if I can get another axle assembly for a WH 6800 and I'm guessing it will come with the small retaining ring I'm missing. I couldn't find the specific axle for WH 6800 online so if someone has a good link, please reply. Thanks.
jjfix is offline
Old 03-19-19, 09:45 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
Loks like you have to buy the entire "guts".
https://www.sjscycles.co.uk/hub-spar...98030/?geoc=US
Bill Kapaun is offline
Old 03-19-19, 12:17 PM
Eggman84
Bikes: 2014 Bruce Gordon Rock&Road, 1995 Santana Visa Tandem, 1990 Trek 520, 2012 Surly LHT
Quoted: 211 Post(s)
Liked 43 Times in 35 Posts
You can find an expoded diagram of the WH-6800 hub at https://si.shimano.com/pdfs/ev/EV-WH-6800-R-3611B.pdf.
Eggman84 is offline
Old 03-25-19, 11:48 AM
jjfix
Thanks Bill - perfect. I'll make the order.
jjfix is offline
Old 03-25-19, 11:50 AM
jjfix
Thanks Karl. I've printed and will keep for referencing. It was time consuming to find the right piece by piece naming.
jjfix is offline
illdthedj
Singlespeed & Fixed Gear
16
04-04-19 11:49 AM
SteelBallSachs
Classic & Vintage
2
08-26-17 03:24 AM
J.Drop
Bicycle Mechanics
17
08-12-14 12:00 AM
Chesterton
Bicycle Mechanics
3
04-28-14 09:25 AM
merganser22
Bicycle Mechanics
3
08-06-12 02:48 AM
