Official Trek DS owners thread
#1651
Quoted: 1579 Post(s)
Liked 1,187 Times
That is fantastic ... if I had an 'ideal' route/surface, what you have available is as close to it as I could imagine. A bit envious!
#1652
Quoted: 8 Post(s)
Trek Dual Sport 4 (2019)
Hello,
I'm new here and I need your help. I'm waiting for a new bike, but still don't know what model of fork is fitted. Could anybody can tell me what I can expect in ds4?
Thank you,
Irek.
Thank you,
Irek.
#1654
Bikes: More bikes than riders
Quoted: 1443 Post(s)
Liked 759 Times
Welcome, Irek. As noted on Trek's website, the DS4 comes with an SR Suntour NRX fork with remote lockout and 63mm of travel.
#1658
Liked 1,187 Times
The line "Left side" means that the left side (leg) contains either an air spring or a coil spring w/preload adjust. The right side (leg) contains Suntour's hydraulic damping/rebound cartridge.
Trek has specc'd the coil spring version of this fork for the 2019 DS4.
#1662
Liked 759 Times
The link works for me as well. The full URL is:
[url]https://www.srsuntour-cycling.com/components/fork/NRX-D-5895.html[url]
Edit: the forum software recognizes the URL and won't seem to let me paste it in full without converting it to a link. Copy and paste the text between the two [url] flags and it should work.
#1663
Quoted: 8 Post(s)
@badger1
I found this catalogue for 2019 and you 100% right
There are 2 forks disc NRX for trekking bikes
NRX-D-COIL RL DS 700C
They looks like good forks
Any users have any experience with DS4 ?
Any review about fork work culture
#1664
Bikes: Trek DS 8.4
Quoted: 23 Post(s)
My 2016 fork is a bit pony to be honest, it’s 2 years old and I’m not sure how hard it’s been riden but, I have excessive play in the fork, the travel is notchy and no LBS can service them. I’m looking to upgrade to Rockshox paragon disc shocks in the new year.
#1666
In 29x2.0, I recommend the Schwalbe Hurricane for a general all-purpose tire. It's not too heavy, but not too light, either. It's available pretty inexpensively. It has a smooth center tread for silent rolling on the road, and some light tread/side lugs for extra traction off road. I find it to be a very nice light-duty all surface tire. I have 19mm wide (internal width) rims, and they're exactly 51mm edge-to-edge (on the side lugs), inflated to about 50 psi. I'm running them on a Giant Roam, and really enjoy them.
#1669
Liked 759 Times
I hope they do; they're nice tires. I've got my Schwalbe Little Big Bens (40mm) back on my Roam due to the fenders I installed, and the Hurricane has a quieter roll (dead silent, in fact) due to the completely solid center rib. The Little Big Bens are certainly smooth tires, but they have a punctuated center tread section, so they produce a tiny bit of a buzz feel and noise.
#1670
Quoted: 8 Post(s)
Hi,
I'm after few ride and I have to tighten fork srew to maximum and now feels much better. Before was to soft, I'm very interested how much better is rock shock paragon air fork.
Also I think about second set of the tyres for off-road track's but I'm afraid what size will be the best. Needs some gap between frame and tyres for mud moving.
Happy New Year !
Happy New Year !
#1671
The Schwalbe Hurricane tires finally arrived after dark today Only had time to get one on as it's getting time for me to head to bed. Anyway they are the 29 x 2.0s, got the front changed out with no trouble nice fit actually. There's plenty of room on the sides and the top of the fork With some quick measurements the back is going to fit just fine also Don't know what I was thinking when I ordered them, thought they were going to only be 50 mm wide, they measure 57 mm at the widest with 48 psi of air.
Happy New Year to all. Jerry
#1672
Quoted: 8 Post(s)
Hi,
New year bring me a problem with my bike. My cassette is wooble and I need drop it to the bike shop to fix it.
Hope I got my bike with straight cassette.
#1673
Liked 759 Times
#1674
Happy new year, Jerry, and I'm glad to hear those tires will work on your bike. 57mm definitely sounds wide for those tires -- what is the width of your rims? My rims have a 19mm internal width and mine were about 48mm wide at the casing itself (not measuring at the side lugs), and about 51mm total width at the widest point of the side lug. They are marked 50-622 (meaning 50mm wide) and Schwalbes are usually pretty close to size...57mm is wider than I would expect for those.
I stand corrected I confused myself converting inches to mm. They're just under two inches at the lugs. For some reason I thought two inches was 58mm. The rims are 17 mm internal..... I think 😏
