What is this and do I need it?
Bikes: Trek Domane SL 5
Quoted: 218 Post(s)
Liked 102 Times
The plastic cover/guard looking thing between my cassette and the spokes.
Bikes: SL8 Pro, TCR beater
Quoted: 988 Post(s)
Liked 584 Times
It's called a dork disc. It's meant to protect your chain from falling and damaging other components when it's on the biggest cog.
It's ugly and useless if your RD is adjusted properly.
Quoted: 218 Post(s)
Liked 102 Times
So if I accidentally shifted past the big ring, the chain would fall off? I'm a relative noob and don't keep track of which ring I'm in.
Quoted: 850 Post(s)
Liked 344 Times
This is colloquially known as a “dork disc”. Don’t know what the official term is. If your derailleur is improperly adjusted or gets knocked during a fall, this disc protects the derailleur from getting caught in the spokes. Saves you money and possibly skin.
This one is kind of small, so it might just be there to keep the chain from jamming itself between the cassette and spokes.
I’d recommend keeping it.
EDIT: Too slow
”Properly adjusted” entails setting the “limit screws”, which will prevent you from overshifting. You’ll feel a hard stop if you try.
EDIT: Too slow
Quoted: 218 Post(s)
Liked 102 Times
EDIT: Too slow
EDIT: Too slow
Thanks; I guess I'll keep it then.
Quoted: 6193 Post(s)
Liked 4,808 Times
If you are the type that doesn't fix anything till it's destroyed, then you need one. But if you don't find it aesthetically pleasing, and you or someone will investigate and find the cause of any chain or derailleur issues before it's a tragedy, then you don't need it.
Likes For Iride01:
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
supposedly it costs 2mph... this is from the source:
https://www.bikeforums.net/11975358-post2.html
Bikes: Trek Marlin 6 29r - Scattanti road bike w carbon fork - Trek 6500 - Univega Alpina 503 - Specialized Sworks M4 made in USA
Quoted: 90 Post(s)
Liked 103 Times
All my bikes still wear them. I have never had a complaint from other riders----yet. lol
Likes For Olefeller77:
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 336 Post(s)
Liked 227 Times
If you need to ask, you should keep it until you learn how to adjust your rear derailleur well enough that you don't need it anymore.
Likes For Wileyrat:
Quoted: 988 Post(s)
Liked 584 Times
No! There is a limit screw (dumb proof mechanism if you want). Try to downshift when your chain is on the lowest gear - it should be impossible mechanically speaking.
Bikes: Had an old Columbia in the 80's, here a used Schwinn hybrid, now a Cannondale Quick 3 and a Topstone 105..
Quoted: 249 Post(s)
Liked 306 Times
It is not going to hurt your riding and could help you. I would keep it but that is up to you.
Frank.
Frank.
Liked 4,808 Times
I had kids that liked to imitate dad and they thought they understood how to adjust their own bikes DR's. The dork disc probably saved me from having to buy them a couple more bikes.
mechanically sound
The least expensive way to shed a few grams from the bike is what I call it.
Quoted: 479 Post(s)
Liked 277 Times
Mechanical paradox...
- If you need to ask, you need it
- If you know how to remove it, you don't need it
A little more explanation of what the guys are saying... Derailleurs have a few adjustments. One category of these is the limit of travel - Low and High, e.g. how far up and down the cassette the derailleur can move. These are set with screws. Sort of a "set and forget" thing in that they shouldn't need adjustment again, once set properly. If they are set properly, the chain can't drop off the backside of that largest cog - into the spokes - because the limit screw prevents that much movement/travel of the derailleur.
95% of "us" remove these "dork discs" pretty much the day we bring the bike or wheel set home. But... it's really not a big deal. Lots of these guys also care whether your sunglass arms are under or over your helmet straps. ;-)
Likes For Zaskar:
Quoted: 283 Post(s)
Liked 262 Times
It protects your wheel spokes if your chain drops off the biggest cog into the gap between the spokes and the cogset. If you are climbing a hill with a lot of pressure on the pedals, chain drops off, and you really jam your chain in there, you can cause a good amount of damage to the wheel. Prob. called a "spoke protector" in a parts catalog. Just keep it there and forget about it. If you get to the Tour of Switzerland, have your chief mechanic double check your limit screws and take it off.
Quoted: 389 Post(s)
Liked 255 Times
I'm a dork, and I need a 10th post
Quoted: 5224 Post(s)
Liked 3,581 Times
Likes For rumrunn6:
Quoted: 218 Post(s)
Liked 102 Times
- If know how to remove it, you don't need it
Likes For sdmc530:
Likes For Zaskar:
Should Be More Popular
Quoted: 22595 Post(s)
Liked 8,925 Times
