Painted my 1977 frame
Bikes: 1977 Trek
Quoted: 34 Post(s)
Liked 22 Times
update to: https://www.bikeforums.net/classic-v...questions.html
I had a friend who does auto body work paint it. I'm pretty happy.
I have the decals but am nervous about putting them on.
I'm even more nervous about putting on the metal cable guides and stuff, but I'm going to ride it, it's not a museum piece.
By the way, is there any backing to use on those guides to keep them from scratching too much?
Downtube before:
Downtube after:
Looking at the photos, they look a little different in shade, but I'm happy with it. I gave him the DuPont codes, gave the frame to him still painted, and he said he mixed and accounted for some yellowing over the years and this is what he came up with. Again, I like it. I told him just get close and I'll be fine and I think he exceeded my expectations. And btw, he did all the sandblasting and paint removal and metal prep.
Downtube before:
Downtube after:
Likes For ts99:
Quoted: 3449 Post(s)
Liked 2,800 Times
Hope you paid him well, bikes are always more work than anticipated.
I have one coming up to do... looking/not looking forward to it.
Quoted: 4745 Post(s)
Liked 3,861 Times
Are you going to run cable guides for full length housing or stops for bare wire? Guides for full length don't really do very much and neatly trimmed tape stuck to the insides of the guides works. The stops for exposed cable see the full braking force and need to be bare metal digging into the paint. I'm guessing this was full length like my old Fuji Pro and the vast majority of the bikes raced in the mid-late '70s. We never used tape under, but then we had no idea we were riding bikes that were "vintage". To us, they were just bikes. We did all kinds of obscene things to them like racing and crashing.
Edit: beautiful paint job! I've used good electrical tape on steel clamps with OK results (as long as the clamp shifting isn't the end of the world). Do seek out good tape. Like duct tape the range of quality is big. I love the DT stop for the shifters. I ordered that for the custom of my username. The bike never did see Campy shifters, went to the top-mounted SunTours when they came out in the early ;80s and now spends its time as a fix gear. (Horizontal dropouts like your; just so I could. Never thought I would.)
Ben
Ben
Likes For Wileyone:
Quoted: 601 Post(s)
Liked 1,054 Times
If your worried about scratching your frame, go to the aircraft spruce website, pickup some 3M leading edge tape, cut to size, put it anywhere you are worried about frame abrasion. Apply using the wet method. Can also put it anywhere you think stone chips will be picked up, also makes great custom chain stay protector. Stuff is almost invisible once applied. Nice job on the frame by the way, love the color.
Tim
Tim
Quoted: 529 Post(s)
Liked 255 Times
On my bicycles, I have had them put it around the bar. It costs about $2. With a completed bicycle, it is not realistic to stick it over the entire bicycle. You could cover the entire frame.
You could look for something similar. The plastic is very similar, or maybe the same as plastic we have used to stick on book covers in Australia.
In Australia, there is also a product which you can spray on paint, and it forms a clear plastic or rubber layer. It can be used in places where the paint may get knocked a lot. For example, where a person's boots may touch paintwork when getting in to or out of trucks.
You could look for what is available in your country, and experiment with it.
If you come up with something good, share it so others can use it.
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
For applying decals, I use extended-release masking tape to mark off the area where the decals will go. Careful measuring at this step will go a long way to ensure the decals end up straight.
Edumacator
Quoted: 2385 Post(s)
Liked 2,931 Times
That is a cool metallic flake color thingy you have going on!
Quoted: 1324 Post(s)
Liked 927 Times
How about putting a thin layer of silicone under each clamp? I've done that with front derailleurs.
Cheers
Cheers
If it's something like an umbrella pump clamp that may be removed at some point then I'll protect the finish.
BTW great job ts99 on the full repaint on your Trek. I'm refurbishing a '79 710 in the same color. Paint is very nice except on the underside of the drive side chain stay.
I had the color scanned at a local auto paint supply and they made up an aerosol can for me. Haven't tried it yet but looks to be a good match. (test sample) Had I seen your earlier thread I would have known about the 44437 code but I'm confident the scanned color will be right for blending in a 40 year old finish.
Liked 927 Times
I don't see the need. I try to make sure that the clamped components are placed accurately so no fiddling is required. Paint can be slightly marred but unlikely broken.
Cheers
Quoted: 211 Post(s)
Liked 198 Times
LOVE the metal flake blue frame !!!!!!!!
You do not see many of these.
FIRST one for me with this size flaking !!!!!
Liked 927 Times
Cheers
BTW silicone is the most ill-used substance on the planet. Doesn't belong on boats or bicycles. Attracts dirt and becomes gunky boogers.
Bikes: a few that I can't recall
Quoted: 339 Post(s)
Liked 287 Times
I have had success using strips of 0.012 to 0.015 stainless, sourced from the hobby store, to protect between the clamp and the frame.
Leading edge tape is also known as "helicopter tape" if you want to search for sources.
I am starting to like the "green" masking tape over the blue masking tape for temporary use.
I don't care if anyone wants to get to 3100 posts or not.
Quoted: 1601 Post(s)
Liked 2,187 Times
@ts99 - if you already have seen this tread then never mind otherwise you may find it helpful - https://www.bikeforums.net/classic-v...ng-decals.html
Friendship is Magic
Bikes: old ones
Quoted: 26250 Post(s)
Liked 10,231 Times
A couple of things:
Getting the decals/stickers straight and centered in proper position is greatly facilitated by first inking off a set of center lines (in a cross pattern, one horizontal and one vertical) on the masking tape on the sticker's top surface. (Which is now present on most of the ones I have ordered lately.) You then apply masking tape around the tube you want to put the sticker on at each end of the decal position (use the decal to measure). Then use a ruler to ink the lines straight across onto the two pieces of masking tape at the place you want the decal centered. Line up the lines on your sticker and your masking tape as you apply, using the wet method with a couple of drops of Dawn in water (in a spray bottle).
All of this works much better, and your stickers are much better protected, if you do a final coat of Spraymax 2K Clear Glamour over everything after you have the decals applied, You need to mask off any chrome, but I don't see any on your frame.
If your friend is willing, he can do a clear final coat of some kind of epoxy hardened paint on your frame. Anyway, that's what I do on everything now. When properly hardened and cured, this clear coat is remarkably durable, and ought to help you with any issues you might have previously experienced with frame band clamps.
Likes For 3alarmer:
Liked 927 Times
Cheers
Señor Member
Quoted: 1491 Post(s)
Liked 1,072 Times
Here's what I use to protect the frame from metal contact. I use it more on the back of bottle cage clamps though.
Comes on different sizes and colors. Just paint a thin layer on the surface of the attaching part that will contact, let it dry, and you're golden.
