Back braces
Quoted: 4559 Post(s)
Liked 2,802 Times
Tried 'em. The compression can feel good. And they're handy for holding ice and heat packs. But otherwise they do little or nothing, far short of the hype and claims by vendors who are mostly fleecing Medicare/Medicaid.
As an OSHA safety inspector years ago we used to see employees wearing back belts. Made no difference to us, OSHA didn't recognize them as legitimate safety equipment because NIOSH and other studies showed no benefits.
There are some custom braces that, like neck braces, can provide needed support after some types of surgery, or folks with serious spinal problems. But we can't buy those from Walgreens or through those late night TV Medicare/Medicaid hustlers.
Quoted: 11 Post(s)
Back brace
Quoted: 11 Post(s)
Back brace
Quoted: 957 Post(s)
Liked 1,619 Times
Most nights and days but not by choice...
My back brace, recliner, and massage chair all keep me off the drugs... But that's me.
The most effective back brace I have seen is just a the old wide leather weight belt with the big or multi buckle in front.
First you gotta find one (very hard). Then you soak the leather belt in a tub of hot water for 24 hours. Then you put it on tight and wear it around the house standing up and walking. After a few hours gently take it off without bending it and set it out in the sun to dry. After its dry oil it up and finish braking it in...
It will last you for years.
Also... I've never been able to effectively ride with any of my braces on.
Quoted: 11 Post(s)
Back braces
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
I have used braces in both the lumbar and cervical areas. However, that was during recovery after surgeries. My orthopedic surgeon and the physical the****** wanted me to stop using the braces when they gave me releases from their care. They both said it does not help most people and can actually be a detriment if using them long term. It worked for me. Four spinal surgeries in 8 years, including mechanical disc at L5-S1 and fusion at C5-C6. I am still riding a road bike and have really increased the mileage the past few years. I do make concessions with the set up to minimize the stress on my spine and shoulders.
Quoted: 18354 Post(s)
Liked 4,502 Times
Are you having back issues?
My back has gotten much better over the last few years. Making two primary changes. Lots more riding my bike, and oddly sleeping on my side in a recliner. I'm still not quite sure what that does, but perhaps is forcing me into a certain position, and keeping me off of the stomach.
The back isn't perfect, but it is better.
Of course, as with knees, there can be multiple back issues, and what works for one person may not even be related to the next person's issues.
Quoted: 957 Post(s)
Liked 1,619 Times
BOY...! There's nothing like putting on the MOJO when you write something about back braces. That same day I wrote I did not use back braces when riding I had to put one on for a ride. But it was for my umbilical hernia not so much my back. If your not ridiing in hot weather you can try the elastic stretchable back supports with stays. Don't spend allot of money on them.
OK... We make do as we can. The thing is... We Ride!
So next time you see a Geezer puffing his way down the road at a crawl try to remember he's most likely more beat up than he looks, even if he looks bad. And we always keep the faith that there is eventually a down hill.
Back Braces
I rode with them off and on for a few years but finally pretty much solved the back problems with a microdisectomy and a few years later a multiple level Lumbar Fusion. At 77 I still cycle well but found the sections I used to think were flat on A Group rides were really 2 and 3% grades. About age 65 I started getting dropped when the group went over 25 - 30 mph on these grades. Needless to say I found B Group rides still keep me going.
just another gosling
Quoted: 3885 Post(s)
Liked 1,938 Times
My bike is the best doctor I ever had. The more I ride, the better my back feels. I have a fairly aggressive position, about 10 cm drop, and that's a necessary and good thing for the back. Too upright is punishing on it. I've also done strength work at my gym about 8 months/year since 1978, doing whole body work with a particular focus on back work. That's been very helpful over the decades.
IMO back braces weaken the back and pave the way for more problems as we age.
Results matter
Results matter
Likes For Carbonfiberboy:
