What is the Poor Man's Rivendell?
#126
That would depend on what you mean by bicycle. If you mean the complete bike, then the parts do come from all over. If you mean the frame, then that would not be true. Some of their frames are made overseas and some are made here. Their custom frames are made by Mark Nobilette and their more expensive frames are made by Waterford, in Wisconsin.
As for a poor man's Rivendell, I haven't found anything. I have not seen such relaxed geometries on any newer bike. For example, a 48 Sam Hilborne has a 71.5 seattube angle. The closest I've seen is my Miyata that has a something around a 72 degree angle. That is rare for bikes and especially rare for smaller frames. Today, it would be hard to find a 50cm bike with anything less than a 74.5 degree seattube angle. Specialized doesn't make anything less than a 75.5 seattube angle for their small bikes. This is just way too steep for my comfort. Even the Surly LHT 50cm frame with 26" wheels has a 74 degree angle.
I am much more comfortable on a Rivendell designed frame than anything else I've tried, a close second is my Miyata and Trek 520.
Im not looking to really correct you as much as just not having misinfo out there that people who dont check will pickup on.
The Miyata and the 520 are fine bikes but so is the LHT. And of course it goes without saying for the Riv's.
#127
ddez, you are not correcting me. Read what I wrote. I did not mention the 60cm bicycle. I mentioned the 50cm LHT. I don't know about the newer Trek 520's, I haven't checked. I am talking about my 520 in a 19" frame. It has a 72.7 degree seat tube angle. According to Surly, their 50cm frame has a 74 degree seat tube angle. https://surlybikes.com/frames/long_haul_trucker_frame/ You can disagree with me as much as you want, but the facts are there. The larger LHT's have a seat tube angle between 73 and 72 degrees. The smallest LHT frame has a seat tube angle of 75 degrees. They are not the same.
If you can find information about the LHT's seat tube angle that says they are the same with the small frames as with the taller frames, I would like to see it. I would have to wonder why Surly says otherwise though.
I think the LHT is a great bike in the larger sizes. I don't like it in my size.
#128
Im guessing the newer Treks geometry have changed from old ones.
Anyway I guess no harm done,thats why they make so darned many different bikes i guess,each to his own or maybe to confuse.Lol.
#129
Old Crank
Bikes: Bianchi Eros; Motobecane Grand Touring; Nashbar Fra-may;Motobecane Grand Jubilee;Bianchi Advantage; Puegout UO-8;Specialized Mtn Bike.
Poor Man's Riv is a state of mind: the Riv fit. A bad fit on a pricey frame does not work. I bought a Nashbar Road "Frame" a few years ago for about $60 with sale/coupon. Even though it is not a Riv, I built it with a Riv fit in mind. The frame was the right size (not undersized), higher handlebars over saddle (dirt drop stem/mustache bars), 34/46 compact crank with 12-32 in back for ease up steep hills, and B17 for my butt comfort. The fit was like a Riv, and it is the most comfortable bike I have. Un Riv parts of the frame you sacrifice for the Poor Man Budget (one must make compromises): carbon fork (however, the headtube was 1 inch and I was able to get a threaded carbon fork), carbon seat post, aluminum frame, Neuvation wheels (upgrade from poor Nashbars budget wheels...), Nashbar cassette (no freewheel), tight frame so hard to fender, not eyelets for racks/fenders, Nashbar tires, short reach Nashbar brakes. Riv addon or like Riv addons: Ritchey compact crank from Riv with low Q (crank and wheels cost more then frame...). wide gearing, Baggins saddlebag, Brooks saddle, Silver Shifters bar end, friction shifting, NOS front Suntour FD ($10), Mustache bars, cloth bar tape, Shimano brake lever from Riv., traditional frame geometry. Overall, the bike is not harsh to ride despite the aluminum naysayers. Maybe it is the carbon parts smoothing the ride along with the fit. Of course, it Riv prophesy come true, I will be riding someday and the caron will suddenly snap and the aluminim will fatigue into a doomsday situation... What a way to go, at least I will die happy on my bike...
#130
What if you are poor because you own a Riv?
Ok, just kidding. But I'm only a graphic designer who appreciates a certain type of bicycle aesthetic, ride quality and principals. Not "rich", that's for sure.
This is my second Riv.
I'm just getting to this thread and I'll ignore most of the typical riv vs the world comments, except for one or two.
The OP was asking about a poor man's riv and there were a lot of good suggestions.
Here's some more inspirational pics you can wade through.
https://www.cyclofiend.com/cc/
One thing I can say though is that I've built up a bunch of bikes at the same time that I've had either of my Rivendells, and none RIDE like my Rivs. Including a Steel Wool Tweed that was mentioned. I guess it's the mix of geometry and frame materials. But whatever it is, owning a riv for me is more than just about looks. Even though their hand-painted paint jobs are incredible. I don't think I've ever heard any Riv owner complain that they were disappointed in their purchase. What i HAVE seen is Riv owners end up buying a second. And a third.... and....
#131
Bikes: SteelWool Tweed
Steel Wool Tweed
Look up, Steel Wool Bikes.
I have one set up as a SS. Rack mounts, Fender mounts, Disk brake mounts, Canti mounts (BOO!) eccentric bottom bracket...
A little heavy but a plush ride for my daily 20km odd commute, each way.
#132
Bikes: 1993 Bridgestone XO-3, 1981 Trek 613, 1988 Fisher Montare, 1986 Univega Alpina Uno, 2010 Surly Long Haul trucker, 2004 Rivendell Quickbeam. 1970s Gitane Mixtie (60cm), 1994 Diamond Back Axis TT
Quoted: 61 Post(s)
Liked 34 Times
Also they are ugly
#135
Bikes: I hate bikes!
Quoted: 431 Post(s)
Liked 710 Times
Has anyone ever ridden a disk brake bike with road levers and drop bars that stops worth a s**t? Is is possible to adjust the brakes so there is not an inch of loose travel in the brake lever before they engage? I helped a friend put together a Salsa set up this way. I sent her to the bike shop for final adjustments because I couldn't get them to feel "right" to me. They came back exactly as I set them up.
Also they are ugly
Also they are ugly
[IMG][/IMG]
#136
CRIKEY!!!!!!!
Bikes: several
Quoted: 1589 Post(s)
Liked 687 Times
Hey, beautiful as many bikes in this thread are, it's not all about shiny chrome and dainty paint jobs when it comes to old steel.
I rescued her from big rubbish night oblivion and rebirthed her with whatever I happened to have in the shed. She's definitely a workhorse not a showpony, but she earns her oats and never complains at the abuse and neglect she suffers, even in my hands.
I have no idea what this old girl's history is but her chipped paint and fading decals bear silent witness to a long and hard utilitarial life, and I respect that far too much to ever strip and re-paint her. Perhaps she suffered the elements on a back porch while hearing her owner cheering on his favorite TDF rider and admiring his mighty thoroughbred bike. But like the loyal steed that she is she got her master to work on time the very next morning, quietly leaning against the lamp post she was hurriedly chained to which left yet another mark on her paint, making sure she was ready to get him back home again in the evening in time for him to enjoy the next tour stage.
If only our old bikes could talk....
#137
J3L 2404
Bikes: 2007 Jamis Nova
One day, I'll have both a Rivendell and a Tobias Berg. One day.
#139
My poor mans riv is a 1991 Bridgestone RB-T picked up recently for $250. Got it from the original owner who says she rode it about 10-15 times before medical issues forced her to stop riding it. The bike is in near-new condition - trolling craigs list pays off for those who wait!
#140
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 196 Post(s)
Liked 6 Times
This is an old thread but since it keeps reviving, I'll nominate another bike -- the Gunnar Sport. Although a little more expensive than Somas and Salsas, Gunnars are made in the USA by Waterford. The Sport has a great geometry like the old Japanese sport touring bikes that Rivendell loves to emulate. It has room for fenders and tires up to 32 mm as well as braze-ons for fenders, racks, water bottles, pump peg, etc. I am leaning toward getting a Gunnar Sport for my next commuter bike as the stock geometry is perfect for me and it has all of the features I want in a commuter.
https://gunnarbikes.com/site/bikes/sport/
#141
Fat Guy on a Little Bike
Bikes: Two wheeled ones
Quoted: 1254 Post(s)
Liked 345 Times
#142
Liked 345 Times
I rode Scott's bike, which was set up much the same way your's was, and I was amazed at how well the brakes worked. I'd never felt good braking from road levers and disc brakes until that bike.
#143
j/k. But seriously, the gunnar is $750 for just the frame.
Riv's Sam Hillborne is $1250 for the frame AND fork and headset. And you get the pretty lugs and paint job and Riv's geometry if that's what you like.
So the gunnar is a great bike, but if what you really want is a Riv, you don't need to spend much more at all to get it. If it was me, I'd spend a little more on the frame now, and upgrade components later if you need to save some cash somewhere.
#144
Bikes: Redline R750, 1974 Raleigh International
Here is a Bridgestone Kabuki that I would think could be made into a touring bike pretty easily.
https://cgi.ebay.com/Bridgestone-Kabu...?pt=Road_Bikes
#145
Liked 345 Times
Says the poor man.
It's all taste...personally I think Rivendell is selling their name more than they are bikes. I'd buy the Gunnar...but that's why there's chocolate and strawberry. Isn't that $1,250 riv made in Taiwan? I'd rather have the $750 Waterford made frame personally.
#146
Quoted: 196 Post(s)
Liked 6 Times
Says the poor man.
#147
The Gunnar would still be less expensive -- current prices are $800 for the frame, $275 for the fork (w/ options as cheap as $120). If you bought a headset equivalent to what Riv puts on their bikes, the Gunnar would be at least $100 less than the Sam Hillborne. Plus you could paint the Gunnar a range of colors, and their frames come in many more sizes. Finally, the Riv geometry is just whack, IMHO. The top tubes are extremely long, even considering the slack seat tube angle, and their sizes are very limited. I'm not a Rivendell basher, but I do not believe they are offering a good value for the money these days.
#148
Liked 345 Times
#149
lol, what thread are you in? No one ever said Riv was a better value than some of these cheap alternatives.
But for an extra $100, it's a no brainer to take it over the gunnar, when you are looking for a Riv-ish bike. Hence the thread title.
Honestly though, both bikes are too expensive for this thread so it's really a non-issue.
Now when you've actually owned a Riv, then you can come back and talk to me about what they're selling and what it's worth.
#150
Mordor.. if you can afford the high real estate prices in Rivendale , you live in the urban tenements .
Think UJB ... Ubiquitous Japanese Bikes from the 80's .. many were lugged construction, then .
but may not have used investment cast lugs with filigree edges ..
So if you really wanted a RBW bike but couldn't afford it? then what you Do build up, by definition is one. Po' Guy Riv.
