Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Help compare bike fit of 2 different bikes
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 12-05-19, 12:23 PM
Slowridr
Quoted: 32 Post(s)
Liked 4 Times in 4 Posts
Have a question on how the Smoothie size 58 compares to the Supersix size 56? I am most worried about reach and how different they are. I know the smoothie 58 is almost 1 cm longer in effective top tube. But does the seat angle and head tube angle play a role? Any other big differences. Im mostly concerned if the smoothie will be to long. I know the head tube is longer on the smoothie. What role will adding a headset play on that.
I am asking because I currently have a supersix, and have an opportunity to get a deal on the smoothing 58. Just wanted to make sure I can get roughly the same setup between the 2 sizes by playing around with the stem. The fact the head tube is longer on the smoothie is probably a good thing as I run spacers on my supersix.
Thanks
Slowridr is offline
Old 12-05-19, 04:21 PM
tangerineowl
Bikes: Curve Grovel v2 ti
Quoted: 257 Post(s)
Liked 91 Times in 75 Posts
Frames are very similar. No need to worry about reach; there's only 1mm diff.
Depending on where your seatpost currently clamps on the Supersix's rails, the worst that would happen is you'd have to get a zero-setback post to run on the Smoothie.
Like you mentioned, you're already running a few spacers on the Supersix, so you'd have minimal (perhaps 5mm) on the Smoothie.
Any further front end tweaks can also be sorted by using a lower stem.
There are headsets out there which have a lower stack height than normal, but I don't think you'd have to go there.
tangerineowl is offline
