Why not cogs outside of drops?
There's time now
Quoted: 4123 Post(s)
Liked 168 Times
This may be a silly question, but why are no bicycles with cogs outside of the rear dropouts? I know carbon belt drives are a thing, and the frame has to have a break to use them. So why no cogs outside of the rear drop out?
Like outside the frame? Well, how would the chain run THROUGH the seatstay when you go from outside the dropout to inside?
Maybe a waxed chain might glide through the frame with all it's lubricity but a generic chain won't......
Just get a FD and a 2 speed hub with 12 gears if you want more.
Me? I actively search for lower gear count bikes so I don't have to double or triple shift.
At this rate I will be a sturmey archer guy.
Likes For slow rollin:
Quoted: 422 Post(s)
Liked 994 Times
Why not rims outside of tires while you’re at it?
In all seriousness, I can think of many drawbacks, but what benefits can you imagine from this setup?
Likes For icedmocha:
Thread Killer
Quoted: 3218 Post(s)
Liked 1,763 Times
There have been a few over the years, like this English:
Likes For chaadster:
Thread Killer
Liked 1,763 Times
And of course the greatest bike designer of all time, Mike Burrows, was probably the innovator:
Palmer
Quoted: 1702 Post(s)
Liked 1,887 Times
The late Mike Burrows again:
Likes For tcs:
Because then, instead of the hub rotating around a fixed axle, the axle has to rotate, which makes for a trickier dropout to support a bearing for that, which describes a typical "semi-floating" car or truck axle. Or, a fixed axle that is hollow and the driveshaft fits through it and transmits torque only, does not take bending loads; I just described a "full floating" truck axle. It can be done, just at greater cost.
Likes For Duragrouch:
Quoted: 1082 Post(s)
Liked 1,343 Times
Figure out exactly how to secure the wheel to the frame, while at the same time allowing the cogs on the outside of the frame to turn easily, and you're golden.
Sure, it could be done, but there would be a lot of compromises, and it would add complexity. And imagine the Q factor for cranks matched up to an outboard ten speed cassette.
Likes For RH Clark:
Quoted: 7702 Post(s)
Liked 3,615 Times
I am sure the OP could order a custom frame .... because belt drives represent such a small proportion of the market, making a variety of complex frames for belt-drive bikes doesn't make a lot of business sense.
Quoted: 4598 Post(s)
Liked 5,142 Times
https://www.veercycle.com/products/s...20worry%20free.
Likes For PeteHski:
Quoted: 6344 Post(s)
Liked 4,945 Times
Likely because the cogs outside the dropouts on a conventional bike will require a much wider chain line. And that would mean a much wider q-factor (pedals being further apart). Or there'd have to be additional drive train components to bring the q-factor back to reasonable spacing and then there'll be more loss of energy in the drivetrain that probably wouldn't be desired. Nor would the increased cost to manufacture the bicycle with those extra drive train components.
I don't see why there would have to be any increase in chain line. Just moving the stays inboard of the cassette would only increase the chain line by the width of the dropouts (so a few millimeters), but the hub could be narrowed to account for that so the chainlink would be the same.
Liked 4,945 Times
Changing the wheel will take some additional engineering too. And when we get things like this to outside the norm, then manufacturing costs will be high because so few will buy one. Even if it proved to be overwhelmingly superior in several aspects. So manufacturer's willing to make it will change their minds when they don't see a large market share going that way.
I think there have been some bikes with a single stay. However those concept bikes were also too outside the norm for enough people desiring them to make it worth manufacturing them. Perhaps some still are out there in a niche market.
Likes For Iride01:
Liked 3,107 Times
meh, just put the drive side on the left side....
-Oh Hey!
-Oh Hey!
Likes For MilhouseJ:
Quoted: 524 Post(s)
Liked 690 Times
Likes For wheelreason:
Liked 4,945 Times
