Dry Mouth???
Dry Mouth???
Does anyone have any tips for eliminating/avoiding dry mouth/cotton mouth while riding. I always carry water bottles but while it solves the problem, it's temporary and interrupts the ride and breaks momentum.
Any tips will be appreciated!
Thanks!!
Thanks!!
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
As far as I can tell, you will never really be able to avoid it when riding in hot weather. To reduce or minimize it, be sure you're doing the following:
- Start hydrating before your ride. Like, hours before.
- During the ride, drink before you feel thirsty. Taking frequent little sips is better than big guzzles at longer intervals.
- Electrolytes need to be replenished as well. This will not prevent cotton mouth, but it's related to the topic. I like Gatorade Zero (not the original, sugary formula). There are also powders you can mix into your water. My favorite of these is Skratch.
Likes For Broctoon:
Quoted: 9656 Post(s)
Liked 6,366 Times
Dry mouth is a sign that you need hydration. Don't wait to feel thirsty to drink. Learn to drink while riding.
And, breath through your nose and keep your mouth closed.
Likes For Mojo31:
Quoted: 2281 Post(s)
Liked 1,710 Times
Try putting some lemon juice in your water. But what everyone else said, drink before you feel thirsty, try not to breathe through your mouth.
Likes For Milton Keynes:
Bikes: yes, i have one
Quoted: 1140 Post(s)
Liked 1,182 Times
living in reno it gets hot here. yesterday's ride was 102. drinking before riding makes no difference (for me). i drink about 6 cups of tea (12 oz) while at work and it makes no difference. it is also hard to not breath through my mouth. the dry heat just dries me out pretty quickly. i sip often during rides.
Likes For spelger:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2591 Post(s)
Liked 5,661 Times
“Kidneys maintain homeostasis in the bloodstream by regulating the balance between sodium and water in order to ensure bodily cells are likewise balanced. Caffeine hinders the resorption of sodium and water in the kidneys. Resorption refers to uptake into the bloodstream. Subsequently, the kidneys only have the option to withdraw water or sodium to maintain balance in the bloodstream and cells. Alternatively, caffeine prevents water depletion to the extent of causing dehydration, because caffeine is most often ingested in a liquid, such as coffee or soda, that contains water.”
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Grupetto Bob
Liked 5,661 Times
I have a countdown timer on my computer, which is available on several watches which reminds me to drink every 15 minutes. You might want to look into something like that. As the others have said, staying hydrated is key. The golden rule is to drink before you are thirsty and eat before you are hungry. You may also want to try chewing gum to stimulate your salivary glands unless you are going so hard that you risk inhaling it.
Likes For rsbob:
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,439 Times
I have chronic dry mouth issues, rx's being part of the cause, bowel and prostate issues, also. I almost always have water on hand to sip on. When biking, I occasionally pop a small piece of gum or candy into my mouth for immediate relief. Tiny piece of sugarless gum works best for me. That, of course, is in addition to the water or fluid mixture I drink, close to a quart per hour.
Likes For delbiker1:
Bikes: There is always room for one more.
Quoted: 185 Post(s)
Liked 391 Times
A trick I learned in the Army when we were in the field was to put a pebble in my mouth until we could stop for water. It works very well to prevent dry mouth.
Don
Don
Likes For GeezyRider:
Liked 1,182 Times
Unless you are drinking decaffeinated or herbal teas, you may be doing yourself a disservice. From Healthfully…
Likes For spelger:
Likes For mdarnton:
Quoted: 2333 Post(s)
Liked 2,097 Times
Breath thru your nose, you'll make more power at least until the first ventilatory threshold, it has to do with vasodilation and not blowing off your CO2, you'll deliver more oxygen. I get nose bleeds in 11% hot desert conditions
And, make sure you are consistently hydrated before and after the ride. No chance to keep up hydration levels perfectly during the ride
Likes For GhostRider62:
Bikes: Cannondale Topstone, Trek Dual Sport, State Bicycle Klunker
Quoted: 87 Post(s)
Liked 132 Times
Gum.
actually use to this a a lot in high school. I actually remember the wrestlers would use this to help shave weight. Not sure it really worked for that, but it did keep your mouth moist.
Likes For spelger:
Clark W. Griswold
Quoted: 4369 Post(s)
Liked 4,008 Times
I like the Ricola Mixed Berry flavor personally great for sore throats and such but also good for dry mouth. A hard candy could also work but the Ricola seems slightly better for you-ish.
However yes hydrate properly and attempt to keep your mouth closed if you can. That will go a long way.
Likes For veganbikes:
Quoted: 1821 Post(s)
Liked 1,697 Times
Learn to be able to drink while riding. The ride will not be interrupted or slowed down. If you can't manage a water bottle, buy a hydration pack
Likes For alcjphil:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I was about to suggest this. It's normal for newer riders to be uncomfortable riding while drinking, but that's exactly why the bottle cages are placed where they are. Start by leaving your valve open (unless you're on very bumpy terrain) and coasting while taking a drink on a straight section of road. Glance down for a fraction of a second to see where you're aiming for to put the bottle back, and keep a good grip on it until it's secure back in the cage. As you get more comfortable, you can try pedaling while doing it and not looking down as you get used to where to aim the bottle. It eventually gets to the point that you don't even break your rhythm.
It's like riding a bicycle
Likes For urbanknight:
Quoted: 365 Post(s)
Liked 419 Times
I don't know where you live, but the only times dry mouth bothers me is when humidity is low. When that happens I take more frequent, smaller in volume, drinks. (If you have chronic dry mouth, consult a Dr. or dentist, that can be a serious health issue.)
You should be able to drink from a cage mounted water bottle without interruption or break in momentum. If you can't, practice until you can. It's not like walking a high wire over the Grand Canyon, it's just reaching down, grabbing the bottle, taking a drink, putting it back, while pedaling. Most cyclists do it thousands of times a year. I try to take a drink every 10 min. during a ride.
As for breathing through your nose, as some are suggesting, that's just silly. Maybe up to aerobic zone efforts, depending, but when putting out any significant effort you'll be breathing through your mouth, your nose, and any other orifices you may have handy.
Likes For noimagination:
Bikes: 1990 Schwinn Curcit is my main bike
Quoted: 42 Post(s)
Liked 48 Times
Many of the common medications used by the "over 50" population will cause dry mouth.
Talk with you MD. Maybe you can switch the time of day you take the medication or switch the medication all together.
Likes For Lambkin55:
Quoted: 5224 Post(s)
Liked 3,585 Times
raisins or Mike & Ike's?
Likes For rumrunn6:
