Top Contact Winter II Premium
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
Any experience with Continental's Top Contact Winter II Premium Tires?
https://www.continental-tires.com/bi...inter2-premium
I've just ordered a set for my Priority 600. They look to be best thing going for a winter commuter tire for 650b.
I'd prefer something more studly, but there is just nothing else out there .
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times
I quite like them when it's not too icy.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
I have earlier versions of these tires and they are my main tires from late fall until early spring. I put on studded tires only when I absolutely have to, which ends up being between never and few weeks across the season.
Quoted: 539 Post(s)
Liked 44 Times
It's bizarre how they just don't seem to sell anything. I could find a 27.5" at 2.2" wide but that's it:
Tyres | Suomi Tyres
I can get find a schwalbe marathon winter in 24", but not 27.5".
Sorry no experience with the top contact.
Tyres | Suomi Tyres
Quoted: 685 Post(s)
Liked 55 Times
Tyres | Suomi Tyres
Tyres | Suomi Tyres
That's encouraging. I'm optimistic, and am keen to try them when they arrive.
Quoted: 840 Post(s)
Liked 336 Times
What's good about them is that you can ride them having them on just in case ice or snow might arrive - they do not hamper your ride like studded and/or knobby tires.
studded?
I have a 30 year old set of Suomi Nokian Mount & Ground W tires, 26"
back in 90, they shipped a bundle of 10 to our shop in Eugene,
direct from Finland..
Quoted: 685 Post(s)
Liked 55 Times
I still treasure a set of Nokian Freddies Revenze tires, the versions with crazy-long studs that I believe originally were meant not for snow and ice, but for downhill racing in dirt. They are completely impractical unless we get a major damaging ice storm, but they hang on my wall and make for great conversation starters.
Quoted: 1221 Post(s)
Liked 629 Times
I look forward to your opinion on these Continental's, I was considering purchasing them as well but was thrown off by the e-bike endorsement. Does this mean they're overkill for the 12-20mph I'd ride them at?
Quoted: 4806 Post(s)
Liked 3,928 Times
I have a pair of Top Contacts. Only ridden them once as they havce worked too well. (This is Portland, OR and Murphy operates here too. Since I purchased those "rim in anything" tires, the "anything" weather hasn't happened but once. (Well, we did have a run of ice but chancing riding with Portlanders driving is asking for a very bad outcome.)
The Top Controls really soft and grippy. Sheer ice is quite ridable. It is still ice and you need to be smooth but they are the most forgiving non-studded tires I have ridden (save perhaps the diamond point, near matte thread cyclocross tubulars I used to ride in the '70s. Hard to compare tires 40 years apart. I was also young, crazy, the bike was a fix gear and I rode it well and hard.)
If it were me, I'd have either a separate set of wheel or a second bike set up with those tires and run much faster rolling Paselas the rest of the time. The Paselas, at half the price, will be far cheaper over the winter when you don't need the grip. (I am guessing the Contacts wear relatively fast, being so soft and on the days I want that slow tread, I REALLY want it!
Ben
Ben
Quoted: 685 Post(s)
Liked 55 Times
Ben, you have my curiosity raised big time now. I'll be waiting for some good, glare ice to try them on.
FWIW, only 2 rows 160 studs, that are not long, in the Suomi Nokian Mount & Ground W tires,
Center has no studs , so it's great on the mixed bare and Icy Roads Here.
It's my understanding the Continental has an extra soft compound
that may wear very quickly when warmer,
but does OK at 1~2C, because it's firmer when cold.
hence they write :
hence they write :
special winter tire compound for grip on snow - covered roads and on wet and slippery surfaces
Quoted: 4227 Post(s)
Liked 2,488 Times
Do they actually provide any grip on icy surfaces ??...How do they work in deeper snow and slush ??
one way to find out..
Down here, winter, I have mostly rain to deal with , Ice a short term occasion,
Then I drag the Old MTB out with the Suomi Nokian Studded tires on it,
When that melts, it's back to the rain-gear, The MTB back in the basement..
Liked 2,488 Times
Quoted: 840 Post(s)
Liked 336 Times
Yes, but it is limited. They work better than regular tires, giving you some breathing space for correction, but not as well as spiked tires.
For deeper snow you need knobs and they lack those. On mild snow they are OK.
One thing that happened for me that I would jump back and forth between Contact Winter and Nokian/Suomi 240, skipping Nokian 106. The 106s turned out to be a worse compromise than Contact Winter.
Quoted: 685 Post(s)
Liked 55 Times
I can't speak for the Contis yet, but last winter I tried a set of Michelin StarGrip tires. Those are also non-studded. The StarGrips had nothing to offer on wet, glare ice at the 32/33 F mark. They were tolerable on glare ice that was dry, as in well below freezing, so long as you kept rolling smoothly and the distance was short. They were decent on the thin white ice that you get after roads are scraped clean, and they were quite good on packed snow like we often have on roads where I live. The StarGrips have a lot of tightly-spaced knobs that will do a fair job of digging in to a surface that's amenable to being dug in to. The tread also picks up lots of little bits of gravel, which I took note of but it never bothered me too much. I expect somewhat similar results from the Contis.
Quoted: 840 Post(s)
Liked 336 Times
The latter, I believe, is intentional - the gravel acts as low level studs. The very first version of TopContact Winter had shards of glass integrated with the rubber. After they adopted fine thread in Winter II they dropped the shards.
Quoted: 685 Post(s)
Liked 55 Times
That's interesting about the glass in the Top Contact. The gravel though, didn't do me any good. It didn't do me any harm either.
Quoted: 685 Post(s)
Liked 55 Times
Found this video comparison last night. The guy does a good job on it:
I love his answer to the "what does this tell us?" question at the end. I like his style.
Quoted: 5224 Post(s)
Liked 3,581 Times
