Small Victory
Small Victory
We got sleet changing to heavy wet snow up here in Boston/Metro North. Because of the chance for sleet I whipped out the ski-goggles for their first ever run. They were dark because of their tint. Bottom line, though, no fog, and it saved my eyes 10 miles of sleet/snow
Quoted: 5222 Post(s)
Liked 3,575 Times
nice! how long is your ride & do you sweat much?
I recently removed the foam air filters from my goggles, so I will give them another try sometime this winter
My new ride is currently 21 miles round trip. Almost 100% back residential roads. The biggest challenge is waiting for the stopped school buses
I got the Scott Anti-Fog ski goggles from the local ski&board shop at the annual Spring clearance sale. So it was like 75% off the ticket price.
You're right, the real test will be the cold temps which haven't really hit Boston yet.
Liked 3,575 Times
Bikes: ...a few.
Quoted: 2010 Post(s)
Liked 408 Times
I've been using light ski goggles for the past couple of year when the temp dips below freezing. They don't fog up and they add protection to my face. Kinda dorky looking, but who cares.
One of these days I will have to get someone to snap my picture, with all the bike lights on as well
Quoted: 2361 Post(s)
Liked 1,745 Times
Goggles are somewhat commonplace among the winter cyclists here. They're nice even when it's dry, just because the cold air can make you tear up. I just got back to winter commuting this year, after a 10-ish-year hiatus. Tried the two old goggles I had from BITD (one tinted, one clear), and both were awful. The foam was deteriorating, the lenses were scratched up beyond hope, and talk about tunnel vision. Those not-so-old-school designs were very narrow. Hit the LBS and found a pair of OTG Giros for only $25, and WOW. MUCH better peripheral vision, and way more comfortable.
No fog issues either. When the Ironman was in town, one of the vendors was selling some gimmicky lens cleaning/treatment paste. I gave it a try and it's actually pretty good stuff. And it def keeps the goggle from fogging up. Breathing out through the balaclava, it's actually better with goggles; with just glasses, I do get some fogging.
Favorite winter cycle scene from last year - waiting at a corner bus stop, dude pulls up to the light on a hybrid all rigged for winter, balaclava, goggles, the whole kit, towing a trailer with a dog. Dog was having a BLAST. No goggles on the dog, however.
Now what I need are a pair of those thermal feet warmers. A bit of frost bite on the toes
Bikes: ...a few.
Liked 408 Times
Yep. Minus 11*C this morning with a head wind. Goggles are a must. I had the toe and hand warmers this morning as well. They do help.
Liked 3,575 Times
do you goggle ppl find that your helmet pushes down on the goggles? I retired mine with 1 helmet & not sure if the pressure with be bothersome on a ride, and/or if i need to try the goggles with a few of the helmets in my house to see which they fit best with?
I'm not sure I understand completely, R-R. My goggles are "stand-alone," so no helmet or anything to speak of. They wrap around my eyes under my bike helmet, over the nose, and they do have a small piece of insulating foam around the eyepiece. That's about it. They are kind of like the over-sized swimming goggles you might buy for the kids.
https://www.nyglass.com/products/sco...iABEgLPDvD_BwE
Again, "Scott-anti-fogg," almost generic looking, goggles. They were on retail for about $50. The store had discounted them to about 50% off, and then had a SECOND sale around Easter for another (approximately) 25-30% off, so I got them for (approximately), $16.25.
The guy who sold me these goggles says that he biked to work in the winter last year and wore them and they worked great.
Liked 1,745 Times
I have over-the-glasses MTB goggles, and a fairly large-coverage helmet (POC Tectal). The goggles directly abut the helmet, and they sit slightly low (maybe 5 mm lower than optimal) on my nose. But there's no downward pressure on the goggles from the helmet. And it's a full house up there - glasses, wool watch cap, balaclava, helmet, goggles, full head of hair with pony tail (haven't cut my hair since 1999), so real estate is tight, but again, no pressure or discomfort.
Per recommendation from a couple friends and a guy at the LBS, I hang the goggle around my neck, then put the helmet on, then pull the goggle up into place. So the strap is outside the helmet. Dunno if that makes a difference.
Liked 3,575 Times
I think my road bike helmet sits the highest on my head allowing for no touching between the two things. been a cpl years since I actually wore mine riding. was just trying them on the other day w a diff. helmet
Quoted: 18349 Post(s)
Liked 4,501 Times
I have low, under the brow glasses, and at times have been seen peering over the top of the frames.
Liked 3,575 Times
Liked 4,501 Times
The glasses will still keep most of the rain off of the eyeballs, but the crack above is just enough to see out.... Or, so one thinks.
Quoted: 800 Post(s)
Liked 218 Times
…for eye protection is a pair of simple, wide, plastic industrial goggles that I suspend from my cycling cap using Velcro around the nosepiece. The goggles sit very comfortably on my face securely in place even though my ears are covered.
The earpieces then provide a secure mount for my eyeglass-mounted Take-a-Look mirror. The goggles allow sufficient room for my prescription eyeglasses, and are widely ventilated to carry away the exhaled moisture preventing fogging.
Liked 3,575 Times
great pics showing the layering! thanks Jim. impressed you can wear the mirror with all that stuff!
not to hijack, but also interesting to me is how you have your mirror oriented (vertical & directly in front). haven't used mine in some time cuz I've mostly been off-road or on paved trails. but looking at how you have yours set up, I wonder if I'm doing something wrong. I should try your setup on my next road ride. going to save & print these pics of you so I can do that
this is how mine is being used (horizontal & bent outward). I also got the smaller unit (shorter arm I think) but haven't used it yet
I wonder if I lean over more than you cuz I remember having to accommodate looking over my shoulder, which would be less of a problem if I was more upright
Quoted: 800 Post(s)
Liked 218 Times
Actually since I posted those pictures, I have adopted wearing both right and left hand Take-a-Look mirrors.
I use both left and right rearview mirrors, in my case Take-a-Look eyeglass mounted ones. I got the idea from a cycling companion who used only a right hand mirror.
The additional right hand mirror affords a pretty good rearward view, but is particularly useful [for]…:
I needed a replacement for the left hand one, and all I could find is an apparent new model that's a narrow rectangle, 3.5 x1.5 inches. The narrow mirror does works well, especially when mounted just on my on my eyeglasses.
The goggle-mounted mirrors do require more manipulation to reflect properly with minimal head motion, essentially just a sideward glance of the eyes.
What is the name brand / model of these eye pieces you have? How much are they?
A big problem I am having WITHOUT goggles is my eyes freezing while biking in temps below 15F. Do your goggles protect against such cold temps?
Liked 1,745 Times
^^^^^^ +1; inquring minds want to know....
Liked 3,575 Times
Liked 3,575 Times
2 yrs ago I tried goggles
for several years I've used safety glasses
this year I'm experimenting with a helmet w 1/2 face shield
I recently removed the foam filters on my goggles so I'm hoping they won't fog now
but yes, covering the eyes absolutely helps!
Quoted: 800 Post(s)
Liked 218 Times
I perennially post about my winter eyewear for my 14 mile year-round commute, from about 35° down to as low as 0°. I must wear my prescription eyeglasses, and fogging is one of the worst dangers of winter riding. I am entirely satisfied with my system:
I have also often suggested that any recommendations for winter riding include description of the conditions in which they are employed, i.e. lowest temperature and distance…
I realize now that my goggles and face mask are actually an integrated system of heating and ventilation that keeps my face warm and my vision unencumbered by fogging. The windscreen of the goggles is so effective in keeping my eyes warm that my eyelids actually perspired because my central core body was so warm, and my eyes never got cold, even on those fast windswept downhill runs…
Finally, last Monday I rode in a sleety, wintry mix, and wore a billed baseball cap under my helmet. My prescription eyeglasses stayed dry and clear, and my vision was good with occasional swipes of the goggles with a gloved finger.
IME, and from reading numerous posts on the subject, there are three basic methods for preventing fogging, caused by exhaled moist air onto the cold surface of the eyeglasses and goggles:
1. Provide ventilation for the exhaled air, as described in my post; an advantage to the exhaled air is that it keeps the face warm.
2. Prevent the exhaled air from reaching the goggles:
I have tried typical, and expensive, double-paned ski goggles, and it seems difficult to keep that exhaled air from entering the seal, especially when forcefully exhaling as when riding uphill. If moisture does get into the tightly sealeld goggles, it can’t get out.
It seems a tight headband would also be uncomfortable. An added benefit to safety glasses is I can mount my Take-a-Look mirror on the rigid earpieces.
3. Antifogging agents, like Cat Crap, soap, spit etc.: I find that when exhaling forcefully, and colder temperatures, say under 20° F, those agents can be overcome.
I'm not trying to be contrarian about any methods used, but I am zealous because fogging is a difficult and dangerous challenge to winter riding, and would keep me off the bike for about 3 to 4 months during the year. Every year there are many threads on about the problem.
FYA, I was most impressed by this system by @TuckamoreDew of Edmonton, AB:
Liked 3,575 Times
