Hybrid (dual sport) bike fitting question
I have a 2019 Dual Sport 2 (trek). I was told the easiest way to determine if my seat height is proper is that I should have my leg almost fully extended with a slight bend in my knee when in the lower position of the pedal. I notice I feel like I'm leaning too far forward, although my knee pain is now gone. What changes can I make? I feel like I'm leaning forward
Thanks
Thanks
Quoted: 6193 Post(s)
Liked 4,808 Times
Depends on what you want I suppose. The more upright you are the more weight that will be supported by your butt. Leaning your body forward, your arms share some of that to give your butt some relief.
If all you do are short rides, then it might not be an issue. However for longer rides you might get into that dreaded delimma of "which saddle should I get?" And the correct answer might not be a new saddle, but to adjust your position to lean forward.
However if you are leaning too much or just want to sit upright till some later date, then raise your bars or shorten your reach to them by getting a shorter stem, or change to a different type bar that shortens your reach.
Try adjusting the seat so it is flat, not tilted forward and raise the handle bars some. You may also be able to slide the seat back or forward on it's rails.
Liked 4,808 Times
How would I move my handlebars up more?
So I need a longer stem?
Can you link me parts?
I could always check my LBS for a different bar.
If you just got this bike, then you might could see if the bike shop will let you exchange it. If you are wanting to sit very upright, a beach cruiser type bike might be more your style. They are intended for an upright sitting position and therefore should be more comfortable.
