Phil bearing grease, good for bottom brackets?
Bikes: 1986 Miele Elite S, SunTour Sprint
I'm repacking a vintage SunTour Superbe Pro bottom bracket and I am wondering if the old tube of Phil ball and roller bearing grease that I have would be adequate for the job.
This grease has always worked well for me in hubs and headsets, but I was wondering if I should take anything else into consideration before comitting to using this grease in my BB.
Thanks in advance for all of your help!
Use it.
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
Quoted: 2588 Post(s)
Liked 4,823 Times
All I ever use on my BBs is Phil's grease - I can't afford a tub of that old-school Campy stuff!
DD
DD
sounds like a plan to me then.
Thanks for the speedy responses!
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
Liked 5 Times
The fun starts tonight when I start tearing the Norco apart, the BB is a cartridge so nothing to do there, but I need to look at the hubs and headset, and true up the wheels, to get it ready for spring...
Cottered Crank
Bikes: 1954 Raleigh Sports 1974 Raleigh Competition 1969 Raleigh Twenty 1964 Raleigh LTD-3
Quoted: 8 Post(s)
Liked 11 Times
Use it. Grease is grease for the most part. It's just a bicycle and even the bottom bracket is not under that much stress compared to an auto or motorcycle parts.
IMNO, when it comes to bicycle grease the brand/type isn't nearly as important as to purity/lack of contamination. Many bike wrenches are very lackidazical when it comes to contamination of their grease. You can have $1000/oz super-namebrand grease and if you dab a filthy/grubby finger into it and contaminate it with particles and metal filings then you have instant grinding compound.
Personally, I use Castrol Lithium grease in most bearing situations.
You can find it at any auto parts place for about $5-6 and it'll last you a lifetime of working on bikes as long as you don't contaminate it. I use a plastic disposable knife to dispense it. I never put it back into the tub without thoroughly cleaning it or getting a new disposable knife out of the package.
I use it on all the bearings on my motorcycle that call for lithium grease and have had it on the track at 150MPH on wheelbearings and head bearings I had repacked myself.
Seriously, the stakes are a whole lot lower on a bicycle with pithy and paltry bicycle bearing loads.
I'm sure Phil would tell you different when it comes to spending 10x more for his own grease. I'm not saying it is BAD grease -I'd use it up if I had some laying around and knew it was clean/uncontaminated. But I wouldn't spend my hard-earned money on it. The same goes for the Campy grease as well. I'm not impressed...
I agree with the advice above. Go to your local auto parts store and buy some grease, any grease - white, blue, green, black,... lithium, waterproof, marine, wheel bearing,... whatever. Fresh grease is better than no grease or old dirty grease any day of the week.
Quoted: 3803 Post(s)
Liked 6,634 Times
I use a Pennzoil marine/bearing grease I bought at the auto parts store, and it's green, just like Phil's!
Neal
Neal
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
All I ever used since the 80's on my bikes is Phil's Grease......but it is on the light side and I suspect you might want to go with heavier, industrial grade greases if you do not service your BB that regularly and/or if you ride in the rain much. The heavier stuff will resist getting washed away by water better than Phil's....but Phil's is good enough for most fair weather cyclists.
JMOs
Chombi
JMOs
Chombi
Bikes: Ruckelshaus Randonneur, Specialized Allez (early 90's, steel), Ruckelshaus Path Bomber currently being built
I used to be in the Navy and served on subs. I was hanging out with the knuckledraggers one afternoon when they were doing maintenance on torpedo tubes, and noticed the excess grease coming out of the zerk fittings looked really familiar. I knew that the design of the grease tube cartridges left a couple of ounces behind, so I asked them to give me the next tube they threw away. I took it home and compared it to the tube of Phil grease that I had, and it was identical in color, texture, and smell. From that point on, they would give me their spent tubes of grease, I'd cut open the other end and put the remnants into a clean paint can, and that's the grease I used for the next decade.
Good stuff.
Good stuff.
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 78 Post(s)
Liked 30 Times
Any good automotive wheel bearing grease will do. If it's good for a 3 ton vehicle traveling thru all kinds of weather. It's just fine for bicycles. It's also very important to set the correct preload.
Mike
Mike
i think i will end up going with the Phil stuff, it's still clean and i've got a lot of it. Thanks for all of the advise! I'm glad to know my BB shell has something in common with a submarine torpedo tube!
