Bicycle headset
Bicycle headset
Old 01-09-18, 12:45 AM
Aanurag
Bicycle headset
Do you know different type of bearing used in bicycle headset mechanism ?
Aanurag is offline
Old 01-09-18, 01:36 AM
Kontact
Kontact's Avatar
Quoted: 2146 Post(s)
Liked 4 Times in 4 Posts
Yes. Why do you ask?
Kontact is offline
Old 01-09-18, 06:27 AM
SJX426
SJX426's Avatar
Quoted: 502 Post(s)
Liked 14 Times in 14 Posts
Yes, roller and ball.
SJX426 is offline
Old 01-09-18, 06:36 AM
CliffordK
CliffordK's Avatar
Quoted: 9512 Post(s)
Liked 255 Times in 197 Posts
Above, plus a couple of types of sealed cartridge bearings. Standard headsets can come in different sizes, generally noted as 1", or 1 1/8", and sometimes 1 1/4" based on the steer tube outside diameter. Bearings may be proprietary to the headset, although there aren't that many sizes.
Ball bearings usually come in cages, but can be replaced with loose bearings of the same size if you wish.
CliffordK is online now
Old 01-09-18, 07:04 AM
Road Fan
Road Fan's Avatar
Quoted: 877 Post(s)
Liked 39 Times in 36 Posts
The mentioned sealed cartridge bearings all contain roller bearings or ball bearings. It's also possible to put both types in the same sealed (or should it be called modular?) bearing.
Road Fan is offline
Old 01-09-18, 08:42 AM
oddjob2
Still learning
oddjob2's Avatar
Bikes: Too many
Quoted: 824 Post(s)
Liked 8 Times in 7 Posts
https://www.sheldonbrown.com/headsets.html
You can buy loose balls, usual diameter of 5/32”, you’ll need about 24-28 per race, so say 60 total, as you drop and lose a few. Or buy them prest in a bearing race.
oddjob2 is offline
Old 01-09-18, 11:23 AM
Grand Bois
Grand Bois's Avatar
Quoted: 431 Post(s)
Pressed in a bearing cage?
Grand Bois is offline
Old 01-09-18, 12:04 PM
oddjob2
Still learning
oddjob2's Avatar
Bikes: Too many
Quoted: 824 Post(s)
thanks for the correction
oddjob2 is offline
rgvg
Bicycle Mechanics
11
09-09-17 11:18 PM
lopek77
Bicycle Mechanics
6
02-09-15 09:06 PM
pstock
Bicycle Mechanics
4
06-13-10 06:39 PM
gutsofgold
Bicycle Mechanics
2
04-04-10 09:30 AM
Airburst
Bicycle Mechanics
3
03-10-10 11:01 PM
