Ballpark price for how much to repair two cracks in seat tube lug area?
Old 09-08-19, 03:03 AM
bobotech
Bikes: Specialized Sequoia Elite/Motobecane Fantom Cross Team Ti/'85 Trek 520
I am looking for a 700c aluminum frame with canti posts and found a really nice BMC frame in my size. Issue is that it has two cracks by the top of the seat post area. It appears that someone overtightened the seat tube and crack appeared .
I could get the frame for like 50 dollars. How much more to have it repaired? I wish I had pics but I don't! I mean if I could get it repaired for 100 or so and then have it powder coated for 50, I think that would be fine for a high end repaired frame.
Specifically looking for cyclocross frame for 700c with canti posts and those are impossibe to find anymore. Heck I'd even settle for a good brand hybrid flatbar frame but can't find anything like that anymore.
bobotech is offline
Old 09-08-19, 05:27 AM
dsaul
Quoted: 296 Post(s)
Liked 72 Times in 56 Posts
If it is aluminum and it has a crack, its most likely trash. The most common alloys used for bicycle frames need to be heat treated after welding.
With that said, I welded a seat tube/top tube crack on a friends 6061 aluminum MTB frame last year and he says it hasn't broken yet.
dsaul is offline
Old 09-08-19, 12:31 PM
AnkleWork
Bikes: old clunker
Quoted: 608 Post(s)
Liked 47 Times in 33 Posts
Maybe just ride it and monitor the cracks. Mark the ends or stop-drill them.
First make sure the seatpost and clamp are the correct sizes.
AnkleWork is offline
Old 09-08-19, 07:22 PM
HerrKaLeun
Bikes: Giant Toughroad SLR1 and Motobecane Sturgis NX
Quoted: 704 Post(s)
Liked 41 Times in 36 Posts
Originally Posted by bobotech View Post
... really nice BMC frame .... it has two cracks by the top of the seat post area.
I'm curious how you would define a not so nice frame? Cut into pieces?
sounds like you are looking to buy that.. don't.
HerrKaLeun is offline
Old 09-09-19, 08:15 AM
Jicafold
Quoted: 128 Post(s)
Liked 8 Times in 7 Posts
Around here the rate for aluminum repair for that is $50.
Jicafold is online now
Old 09-09-19, 12:05 PM
bobotech
I was researching the BMC brand, it appears that they are higher end bike brand. So I would surmise that the frames that they sell are probably considered pretty decent.
Are they not a good brand?
bobotech is offline
Old 09-09-19, 12:38 PM
HerrKaLeun
Quoted: 704 Post(s)
A BMC frame in mint condition likely is good. But the one you consider buying has cracks, which I would consider not good.
When buying new, you can go by what their typical quality is. But used is individual and this one has cracks. And who knows what other hidden damage. Like a Honda Accord typically is a good car, but one that is totalled isn't.
Old 09-09-19, 01:03 PM
AnkleWork
Bikes: old clunker
Quoted: 608 Post(s)
Perfect good/bad - black/white thinking example for this forum. "It depends" is way too subtle here.
Old 09-09-19, 01:15 PM
Canker
Quoted: 176 Post(s)
Liked 9 Times in 8 Posts
Well if that cracks completely it won't kill you so if you really want it and it is only $50 go for it. Personally I'd skip even bothering to try fixing it. Go to a autoparts store and buy a hose clamp to put it around the crack on the seat tube and call it good.
Canker is offline
Likes For Canker:
Old 09-09-19, 01:29 PM
HerrKaLeun
Quoted: 704 Post(s)
If it were dents or other cosmetic issues, yes it would justify a more subtle judgment.
Cracked frame is black/white. Cracked frame is junk. Especially if OP hasn't bought it yet. Are we really discussing if buying a frame with known cracks is worth buying?
Old 09-09-19, 01:34 PM
AnkleWork
Bikes: old clunker
Quoted: 608 Post(s)
Another good example.
Are the supposed cracks reasonably repairable? Are they more than cosmetic? Do they even exist? Black/white thinking doesn't need answers to those questions.
Old 09-09-19, 04:41 PM
squirtdad
squirtdad's Avatar
Quoted: 922 Post(s)
Liked 127 Times in 100 Posts
a picture would certainly help evaluation
Personally I don't ride frames with cracks......even steel and especially wouldn't with aluminum. I don't like the odds.....maybe if fails, maybe it does not. If it does fail, aluminum fails pretty quickly, so if you are at speed to may be an ugly crash. I have good health insurance, buy would really prefer not to use it. And depending on the aluminum type, a repair may add more overall weakness.
squirtdad is offline
Old 09-10-19, 10:03 AM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 444 Post(s)
Liked 114 Times in 84 Posts
Avoid.
Any repair would further weaken the frame and it will likely fail again, but this time it will be your problem. Keep looking and another frame will be available soon that does not have cracks in it.
Wilfred Laurier is offline
Old 09-10-19, 07:28 PM
'02 nrs
royaloaker
'02 nrs's Avatar
Bikes: 1938 claud butler,1983 Basso,teledyne titan,teocali super,nrs,1993 stumpjumper fsr,Paramountain,Paramount Buell,4 banger,Zaskar LE,Colnago Master Ibex MTB,1987ish,.etc....
Quoted: 23 Post(s)
Liked 28 Times in 16 Posts
issue/
many crack in that are due to over extended seatposts,metal fatigue.if the seller is the org. owner ask them if they tried a warranty claim.or if you do go with it try asking BMC for a crash replacement discount.
'02 nrs is offline
Old 09-13-19, 09:16 AM
ljsense
ljsense's Avatar
Quoted: 149 Post(s)
Liked 27 Times in 15 Posts
Do the cracks reach to the top tube or into the welds?
If they start at the top of the seat tube and stay above where the seat tube joins the rest of the frame, just drill holes where they end, make sure you have the right diameter seat post, and sufficient seat post length so that its bottom extends well below the junction with the top tube. Aluminum is easy to drill. Any decently sharp bit that's around 1/8" will do the trick. Just make sure you hit the end of the crack with the hole you make.
In effect, bike frames already have a "crack" at the top of the seatpost with a stop crack hole so that the seat post collar can flex the frame and close it around the seat post.
If the cracks go into the weld, or below where the top of the top tube joins the seat tube, or there are more than two of them, you can probably find a better frame for what you're preparing to spend on this one.
A crack at the top of the seatpost isn't particularly dangerous. The racing bike I got when I was 16 eventually broke at the seat lug. It made a sound, and got real flexy. I had the seatpost up too high -- it wasn't inserted far enough into the frame and eventually the leverage cracked the seat tube clean in two, right at the lug below the seat tube. I rode home no problem.
Someone probably rode this bike with minimal seat post insertion, or put a seat post in that was too narrow and just kept going on the bolt, through the shattering sounds, wondering why it wasn't getting tight.
ljsense is offline
Old 09-13-19, 02:40 PM
wsteve464
Quoted: 101 Post(s)
Liked 18 Times in 17 Posts
Does the seat tube extend above the top tube by a good amount? If so cut the seat clamp off and buy a seat post collar for $20 or less
https://www.amazon.com/Best-Sellers-...-goods/3494301
If needed you can get one that has 2 different size clamps one to the seat tube and another for the seat post
wsteve464 is offline
El Gato27
Bicycle Mechanics
12
03-20-16 07:29 AM
Geosammy
Bicycle Mechanics
85
02-25-13 06:23 PM
dnomel
Bicycle Mechanics
21
12-02-10 08:39 AM
Barchettaman
Bicycle Mechanics
15
11-24-10 03:38 PM
plutonium83
Framebuilders
5
06-16-10 12:36 PM
