Continuous Squeal while Coasting.
Old 10-04-19, 09:08 PM
Joroz001
I just finished a new bike build and everything is working perfectly until on a trial run to bed the brakes the bike develops a very loud squeal when I am freewheeling. I have a video on you tube but the system will not let me post it I b will try to post it as a comment.
The disc brakes are no rubbing, they also make a different sound when they do rub.
I tried tightening the thru axles but that did not affect the sound.
I am running Reynolds Areo 65 wheels with industry 9 hubs.
Does anyone have c any idea what could be causing this.
Joroz001 is offline
Old 10-04-19, 10:34 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 1924 Post(s)
Liked 126 Times in 96 Posts
Try to describe again what's going on. Squeal when coasting and not applying brakes, which brake? When you pedal is quiet no matter what? Andy
AndrewRStewart
Andrew R Stewart is offline
Old 10-05-19, 04:18 AM
Soroz001
Squeal when coasting without applying the brake. Pedaling immediately stops the squeal no matter what, and braking immediately stops the squeal as well. It is coming from the rear.
I have a video on you tube but I canít post links. Look for this on YouTube it is the video unique identifier:
K5rNkr8NGK8
Soroz001 is offline
Old 10-05-19, 06:07 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 1845 Post(s)
Liked 166 Times in 121 Posts
That it only happens when coasting suggests to me that the issue is in the ratchet mechanism. Lubricate that and see if it helps.
JohnDThompson is offline
Old 10-05-19, 07:09 AM
JoeTBM
Droid on a mission
JoeTBM's Avatar
Quoted: 72 Post(s)
Liked 13 Times in 13 Posts
I have a video on you tube but I can’t post links. Look for this on YouTube it is the video unique identifier:
K5rNkr8NGK8
Why are you using too different names on BF? I just listened to your video, almost sounds like the tire is rubbing when coasting. Too much camera movement to verify that.
Check the cones on the axle, maybe too much play allowing the wheel to shift off center. Application of the brake may be re-centering the wheel.
Or I would service (clean and lubricate) the freewheel or ratchet mechanism as others have mentioned.
Here is the link to the video so others can see it easily.
JoeTBM (The Bike Man)
I'm a black & white type of guy, the only gray in my life is the hair on my head.
JoeTBM is offline
Old 10-05-19, 07:13 AM
mprince
Bikes: Steelman Stage Race, Dura-Ace 9s
Quoted: 7 Post(s)
Liked 11 Times in 5 Posts
Shot in the dark, could be a seal in the freehub rubbing while it is freewheeling. If the body is removable (I'm not as familiar with the newer hubs), I'd take it off and see if you can replicate the noise with it off the hub and do some inspecting to see if anything looks out of place.
mprince is offline
Old 10-06-19, 10:25 PM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 36 Post(s)
Liked 7 Times in 7 Posts
Can't believe someone got the diagnosis right
This is the ONLY thing that matches those symptoms.
operator is offline
