Bridgestone RB-T - worth saving?
Bikes: Bike Friday PRP, Bike Friday NWT, Bromton M6R, 1991 Miyata 914, 1991 Miyata 1000, 1986 Raleigh Portage, many more frames
Quoted: 215 Post(s)
Liked 347 Times
Hello,
I was wondering if you could advise me on what to do with this poor Bridgestone frame. It's an RB-T from 1994. It's got a lot of issues, but the biggest issue is that the head tube is bent at a slight angle. It's kind of noticeable from afar, particularly from the top tube. There is also a bit of a wrinkle really close to the lugs, though I'm not sure if my camera can catch the defect.
I've always wanted a Bridgestone to tour/commute with that fit me, and I'm kind of sad that I've only just found this defect. So I guess I have several questions:
-should I just ignore the slightly bent head tube and build it up?
OR
-should I get the frame bent back with a head alignment tool and frame blocks?
OR
-should I get the tubes replaced, which will be really expensive?
OR
-should I just discard the frame?
Thanks all.
OR
OR
OR
Thanks all.
Quoted: 796 Post(s)
Liked 522 Times
IMHO there are plenty of great 80's steel touring frames out there without a compromised frame, I would keep looking. I found this article on rebuilding a vintage touring bike a great source of candidates and have found and ridden a few of them; Schwinn Passage, Nishiki Cresta GT, Trek 520. With some patience persistence and bit of luck you should be able to find a fine complete and undamaged 80s touring bike for a reasonable sum. I paid a bit north of a c note for the Passage and lucked into the 520 for $75 at a bike co-op. YMMV
87 Trek 520 $75 at the Co-op
Likes For ryansu:
Port
Quoted: 985 Post(s)
Liked 1,864 Times
Likes For Rocket-Sauce:
It has the beginning of a great lawn ornament.
Quoted: 964 Post(s)
Liked 1,451 Times
I would build it up as an "ugly commuter" and ride it, but I'm not normal.
Most people are probably going to tell you not to ride it, because you can see a bulge in both the top and down tubes. However, if you feel confident in your ability to keep an eye on it and stop riding it if cracks appear/propagate, and the altered geometry (low-trail with less wheel flop is maybe a blessing in disguise) doesn't bother you, I say go ahead. I highly doubt it's going to fall apart from under you, and I doubt even further that it would do so with no fair warning. My Claud Butler is a damaged frame that I keep torching back together - first the BB threads, then the lower head lug failed. Serves me great, works better than bikes five times its price, and I never worry about people stealing it because it's so ugly and obviously messed-with.
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
Perhaps this should be moved to either framebuilders forum or even mechanics? Might get the pros offering a cheap cure...
Quoted: 5888 Post(s)
Liked 3,471 Times
Even if it were safe to ride, why build it up? This sounds like a waste of time given how many really good frames there are out there that you can buy and build.
Quoted: 1949 Post(s)
Liked 2,010 Times
You say it has a bent head tube? Do you mean top tube?
If you have the fork and a bunch of parts, you should build it and ride it while you keep an eye out for a nicer RB-T.
spondylitis.org
Bikes: '84 Colnago Super; '90 Bridgestone MB-1; '81 Trek 930; '01 Cinelli Supercorsa; '62 Ideor Asso; '87 Tommasini Super Prestige; '13 Lynskey R2300; '84 Serotta Nova Special; '94 Litespeed Catalyst; etc.
Quoted: 121 Post(s)
Liked 97 Times
It's a Bridgestone from the Petersen era, and therefore somewhat collectible - but whether you decide to go that route depends on your interest in / commitment to restoration.
The bends don't look that bad. If it were in my possession I'd likely take it to a local frame builder for inspection and re-alignment (Bilenky or Spectrum in my area). The frame was made from Tange CrMo (probably MTB & therefore heavy gauge) without any heat-treating, so it should be relatively easy to get back into shape.
Odds are pretty poor that you'll find anything other than a unicrown fork to replace the original, though.
Likes For kunsunoke:
Quoted: 3810 Post(s)
Liked 6,695 Times
One of my regular commuters/errand runners is a '94 RB-T, and it's a great bike. You're in Portland, so I'd reach out to our own @gugie to take a closer look if he has the time.
Pic of my rig:
Pic of my rig:
Likes For nlerner:
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 417 Times
I rode a frame that was bent in this way for a while
Eventually i realised that while it was more or less fine, I just found it too disconcerting keeping an eye on it and being slightly concerned about it.
It's just not pleasant riding a frame that makes you worry a little.
It's gratuitous and avoidable anxiety. Whether it's founded or unfounded doesn't really matter.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,799 Times
Liked 5,799 Times
Pic of my rig:
Pic of my rig:
Quoted: 57 Post(s)
Liked 41 Times
Yellow Jersey (with some shipping expense, and some fees, could make this frame like new). Worth some consideration. Might be cheaper than a comparable Rivendell (Grant Peterson's successor company).
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I'm inclined to agree with @scarlson. None of the ripples look very severe, and you are currently in possession of a rare "low-trail" Peterson.
Maybe you could do a cheapo build, and see if it rides and tracks well at all before making your next move.
