Got me a Nöll Pro frameset
Shifting is fun!
Bikes: Yes, please.
Quoted: 2193 Post(s)
Liked 4,586 Times
A Nöll Pro?
Yes. Apparently.
I was at a swap meet this morning and it was sitting there. For €40.
I had no idea what frame it was, but it looked rather nice. And it was my size. And it was cheap. And it included a Stronglight headset and a smooth bottom bracket of unknown origin (to me anyway).
I had promised mrs non-fixie not to buy anymore bikes or frames
But, hey, you know.
So, this is what I came home with:
Luckily mrs non-fixie has been immersed in the C&V scene long enough to understand.
What I've found out about Nöll so far:
Achim Nöll has been building frames in Fulda, Germany, since the early eighties, and he's still at it. Here's his website:
Nöll Fahrradbau - www.noellfahrradbau.de
Judging by the decal style, which seems to have changed in the early nineties, this is a late eighties frame.
The Mannesmann frame decal is intriguing. I know Mannesmann supplied the steel for Oria tubing, but beyond that it's a bit fuzzy. Some internet sources say that 34CrMo4 is the stuff Columbus SLX is made of. Anyway, I haven't weighed the frame yet, but it feels and sounds light. FWIW.
I have most of a Veloce gruppo somewhere, that might look nice.
Anyone else out there got a Nöll? Or know about the brand?
Yes. Apparently.
But, hey, you know.
Shifting is fun!
Bikes: Yes, please.
Liked 4,586 Times
Just removed the BB, and this is what came out. Italian!
Shifting is fun!
Bikes: Yes, please.
Liked 4,586 Times
It looks to be the house color: "nöll blau":
And I found a pic online of what looks to be the same frame, albeit with the later style decals:
Shifting is fun!
Bikes: Yes, please.
Liked 4,586 Times
Some measurements:
Seat tube: 61cm (C-T)
Top tube: 56cm (C-C)
Chain stays: ~ 43.5cm
Interesting. The short TT should suit me well. The long chain stays are surprising.
Oh, and the rear width is 126mm.
Quoted: 1361 Post(s)
Liked 423 Times
Never heard of Noll but appears a nice find. Condition looks great.
Curious of the top line frame tubing from Mannesmann.
The Mannesmann Group had a long and diverse history, other markets outside of cycling. Involved with and or owned other European cycling related manufactures, possibly at one time acquired Sachs and then spun off to Sram.
Quoted: 1627 Post(s)
Liked 630 Times
Red bikes may be faster, but bikes with umlauts are more "metal." \^^/
Likes For Lascauxcaveman:
Quoted: 1635 Post(s)
Liked 823 Times
I was going to say too that the umlaut on the name makes it really cool!
The lugs look very nice. Is the tubing OS?.
Quite a large frame, hope it fits you perfectly. Curious to know how this cool, understated German frame rides...
Bikes: A few too many
Quoted: 1363 Post(s)
Liked 2,178 Times
That's really a beauty and the price was super good...stack height on the for seems rather....
Good luck with the build, Ben
Shifting is fun!
Bikes: Yes, please.
Liked 4,586 Times
Thanks, Ben. WRT the stack height: this is a "trick" also employed by Giant, on the frames with the forward-sloping top tubes, which they introduced in the late eighties. Apparently to accommodate bars at a level that could be used by others than twenty-something professional riders.
My Cadex 980C:
Peloton Superlite, which was a little too big for me, and went to a taller coworker:
Shifting is fun!
Bikes: Yes, please.
Liked 4,586 Times
I made a quick mock-up based on my measurements, to see what it would look like. Looks promising, but what keeps puzzling me is the chain stay length. I'd have expected a shorter wheelbase on a model called "Pro".
Thoughts?
Thoughts?
Strong Walker
Nöll was quite prominent as a framebuilder for some time, his name popped up frequently in the magazines like "Tour". Very good quality stuff and wasn't cheap in his time. You might actually get more info whewn you contact him, he may have kept his order books around.
AFAIK he did custom jobs so the long rear half may be at first owners request.
Nice find, although the powder coat does not much for the aesthetics i daresay (its probably original though).
Mannesmann as the inventor of the seamless tube did supply bicycle tubesets for a long time, also Oria used them as basis for their custom products like Gilco, i heard. 34xxx was their best and it is claimed it was stronger than a similar Reynolds tube. Bit on the heavy side and it wasn't butted/thinned as much. I found a posting in a german bike forum where someone says his rather large Nöll (he had a 61,5) had a thinner tube brazed in the seattube to reinforce the BB section. (-> https://forum.tour-magazin.de/showth...04#post2804104)
Quoted: 1136 Post(s)
Liked 650 Times
Yes, as @martl said I would guess the chainstays were a request on a custom order. Perhaps the original owner lived in a mountainous region and wanted more stability for descending, or something.
Quoted: 4224 Post(s)
Liked 2,944 Times
Yeah, a little surprising given that it's called Pro and lacks eyelets/braze ons for rack or fenders.
Shifting is fun!
Bikes: Yes, please.
Liked 4,586 Times
I peeked into the BB shell (this frame is the same size, give or take a few mm), but I see no evidence of any reinforcements in any of the tubes.
I am not a fan of powder coating either, but I must say that it has held up rather well. None of the usual chips and scratches.
Strong Walker
Thanks, @martl. Yes, the whole geometry has a made-to-measure feel to it: the short top tube, the extra steerer length and the "sportif" stays. I don't think I'll be able to fit more than 25mm tires, let alone mudguards. It was clearly meant as a go-fast bike.
Shifting is fun!
Bikes: Yes, please.
Liked 4,586 Times
i'd call the tire clearance very normal for the era. friend of mine who is a tall guy (6ft3 around) had a made to measure 62cm Altinger which could only run 20mm on the rear wheel, and it had to be deflated for removal.
[img] https://www.oliverbaron.com/oliver_ba...inger_0024.jpg
That Altinger is very tight, but also very attractive! Thanks for bringing this maker to my attention, BTW. I wasn't aware of him, but followed your lead and ended op here. Wow!
Strong Walker
Yes, well, if I can fit a pair of decent 25mm tires I'll be perfectly happy.
That Altinger is very tight, but also very attractive! Thanks for bringing this maker to my attention, BTW. I wasn't aware of it, but followed your lead and ended op here. Wow!
Altinger is an insider legend, much like Rödl, his predecessor in spirit.
Shifting is fun!
Bikes: Yes, please.
Liked 4,586 Times
Can't seem to find anything on Rödl ...
Shifting is fun!
Bikes: Yes, please.
Liked 4,586 Times
Other bikes and life in general have gotten in the way, but I've finally built up the Nöll with the bits at hand. Campagnolo Veloce "old" 9-speed brifters matched to a SRAM 7-speed cassette via a hubbub. First time I've tried that combo, and it works rather nicely. Other parts are labelled "105", "Dura Ace" and "Triplex".
I've actually managed to cram a pair of 28C tires in there, too.
Likes For Clyde1820:
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,827 Times
Nice build from 'parts bin'.
Given the short tt (for 61cm st), stem looks a bit short for you.
With those 28s the ride should be cloud-like.
Agree with @Clyde1820 on great color.
Quoted: 237 Post(s)
Liked 83 Times
34crmo4 is is a higher carbon version of 25crmo4, and equivalent to 4135 instead of 4130, but basically it's a relative of 4130. It's probably not what SLX was made of since Columbus tended to use 25crmo4 and modified alloys that added elements in order to cause precipitation hardening to counter the weakening of the steel when brazed.
Shifting is fun!
Bikes: Yes, please.
Liked 4,586 Times
I am still playing with the saddle-bars-BB triangle. You'd think that after ten or so years I'd have worked that out, but no. Variables like saddle and bar shapes and angles, brake lever shapes and locations on the bars, crank lengths, Q factors and even my shape of the day keep messing up my readings.
I guess what I should do is ride all my bikes back-to-back on the same day in exactly the same configuration - and I have actually thought of doing that - but I don't see how I could make that work without a huge investment of time and money.
The tires are Vittoria Corsa Control Graphene 2.0's which I'd bought a while back out of curiosity. I rode them at ~80 PSI today, which felt like too few P's. I hope the weather allows a few more miles later this week, and I am looking forward to feeling them at 90 or a 100.
The color is a purple-ish blue, which I quite like, but is difficult to capture. Here's another try:
Likes For non-fixie:
Veteran, Pacifist
Liked 4,827 Times
....... I am still playing with the saddle-bars-BB triangle. You'd think that after ten or so years I'd have worked that out, but no. Variables like saddle and bar shapes and angles, brake lever shapes and locations on the bars, crank lengths, Q factors and even my shape of the day keep messing up my readings.
As for the Vittorias, the supple sidewall is nice. I run 27/28s a bit under 100psi.
