Drive Train Skipping Under Load
Old 10-18-19, 01:43 PM
SuperK
I am at a loss here and any help would be much appreciated! I am trying to work on a ~2002 9 speed Ultegra 6500. I have replaced all cables, cable housing, and barrel adjusters. I have replaced the entire drive train (chain, chain rings, cassette, jockey wheels, and bottom bracket), re-aligned rear derailleur hanger, reset limit screws, and seem to have cable tension where it should be. On the surface every thing seems to work smooth if. I ease into things everything is really smooth the system can take any load. However if I start pushing the torque the chain starts to skip on the cassette. Is there anything else I should take a look at?
Thanks!
SuperK is offline
Old 10-18-19, 03:00 PM
dsaul
Quoted: 299 Post(s)
Liked 72 Times in 56 Posts
Sounds like a freehub problem. What hub is on the rear wheel?
dsaul is offline
Old 10-18-19, 06:12 PM
nomadmax
Quoted: 471 Post(s)
Liked 352 Times in 198 Posts
Does it slip on one cog or all of them?
Usually:
One cog = a cassette/cog problem
All cogs = a chain problem
Slowly pedal the crank backwards with your hand. Look at the chain near the jockey wheels and look for a stiff link. There are other causes including a bent RD hanger but a stiff link is usually to blame.
nomadmax is offline
Old 10-18-19, 06:19 PM
Soody
Soody's Avatar
Bikes: Gunnar crosshairs, F Moser, Ken Evans, Pete Tansley, Rocky Mountain Summit, Cinelli mtb
Quoted: 58 Post(s)
Liked 19 Times in 16 Posts
It could also be skipping because of your shifting, if your indexing is not set correctly, your hanger is bent, or if there is some friction or something not seated correctly in the line acting like a clutch
Soody is offline
Old 10-18-19, 07:28 PM
Bigbus
Bigbus's Avatar
Bikes: In Flux
Quoted: 107 Post(s)
Liked 32 Times in 23 Posts
It appears that you've already thrown everything at it but the kitchen sink. My first guess is a sticky chain link. That'll cause precisely what you're experiencing if all else is in alignment. But you say you already replaced that too so I'll just scratch my head a little longer here. Oh, wait a minute, you don't mention swapping out the frame...
Bigbus is offline
Old 10-18-19, 07:32 PM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Bikes: Lots. Just...lots.
Quoted: 1107 Post(s)
Liked 85 Times in 63 Posts
I'd vote for a sticking link, or possibly cassette spacers too narrow Sure that's a 9 speed cassette? Sure it's not an 8 speed chain?
rccardr is offline
Old 10-19-19, 09:34 AM
frankenmike
mechanically sound
frankenmike's Avatar
Bikes: Indy Fab steel deluxe, Aventon cordoba, S-works stumpy fsr, Masi vincere, 92 Hardrock commuter, Dahon mu uno, Outcast 29
Quoted: 46 Post(s)
Liked 14 Times in 11 Posts
RD adjustment, broken free hub, or stiff chain links.
frankenmike is offline
Old 10-20-19, 01:34 PM
SuperK
Thanks All! I will take a closer look...
SuperK is offline
Old 10-21-19, 02:11 PM
SuperK
Don't want to celebrate to early, but going to take a look and hopefully rebuild this week (if not replace). Makes total sense and one of the few things I didn't check! Thanks so much!!! Will report back...
SuperK is offline
