loose cranks?
Old 09-23-10, 05:01 PM
calbob76
Bikes: big block
loose cranks?
i can feel it move when i trackstand, and i don't think it is my chain tension. and when i get down close and move the non driveside arm with my hand i can see it move just a little inside the bottom bracket. that is bad right? do i need to take it to my lbs and get it properly tighened?
calbob76 is offline
Old 09-23-10, 05:12 PM
Scrodzilla
Your cog is slipping.
Scrodzilla's Avatar
Quoted: 640 Post(s)
Liked 100 Times in 58 Posts
Yes and yes.
Scrodzilla is offline
Old 09-23-10, 06:07 PM
vw addict
vw addict's Avatar
Bikes: Specialized Tarmac Expert, Cannondale R700, Specialized Langster, Iron Horse Hollowpoint Team, Schwinn Homegrown
sounds like you should have the BB and cranks tightened.
vw addict is offline
Old 09-23-10, 06:37 PM
Kayce
Kayce's Avatar
More likely the square taper on the cranks has been rounded, making it move around on the bottom spindle, the other way around, or a combination of both. Depending on which it is you may need a new bottom bracket, cranks, or both.
Kayce is offline
Old 09-24-10, 03:00 AM
dbwoi
dbwoi's Avatar
Bikes: Peugeot U0-8 (Stolen), Motobecane Grand Record, 80's Diamondback BMX, Peugeot Monaco
Also, you can try undoing your lockring and screwing the floating cup in a TAD farther.
dbwoi is offline
Old 09-24-10, 10:25 AM
Higher Class
soft pedal zen
Higher Class's Avatar
Bikes: Absolutely
Liked 9 Times in 2 Posts
This probably isn't the case, but I know that when chainring bolts come loose it gives a feeling of a "loose crank." Just a thought.
Higher Class is offline
Old 09-24-10, 01:34 PM
ianjk
Bikes: '07 Pista, '09 Fantom Cross Uno, '8? Miyata, '67 Stingray, '0? Zoo mod trials, Tallbike, Chopper, '73 Schwinn Collegiate, '67 Triumph Chopper, '69 CB350, '58 BSA Spitfire, '73 CB450
Stop riding and bring it to a pro. You may have already hosed one or more components.
ianjk is offline
Old 09-24-10, 03:30 PM
calbob76
Bikes: big block
it was the loose bottom bracket as I though! Couldn't do it myself so I took it to the lbs and its allll gooood. new bike btw, i'll post pics
calbob76 is offline
JKPowell
Singlespeed & Fixed Gear
76
10-06-13 06:55 PM
mwandaw
Tandem Cycling
7
02-18-13 09:38 AM
natewarren
BMX
8
09-05-11 07:38 PM
smoothness
Bicycle Mechanics
16
07-09-11 08:01 PM
wmgreene85
8
06-23-10 10:24 PM
