Chain ring wear
Chain ring wear
Is this chain ring worn out? Right now I am still having issue getting into the big chain ring when switching gears and was wondering if this is my issue.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Quoted: 4194 Post(s)
Liked 3,837 Times
Ring wear isn't the usual shifting issue but chain wear can be. BTW that small ring is getting well worn. At some point the tooth erosion will be enough to cause the chain to slip over the teeth under power. Andy
AndrewRStewart
AndrewRStewart
Quoted: 3370 Post(s)
Liked 5,490 Times
What do the shift pins on the backside of the ring look like?
I have had to replace a chainring with perfectly fine teeth, just because the shift pins got rounded off by wear, and could no longer catch the chain to lift it up onto the ring.
Likes For Shimagnolo:
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
You might also check to make sure your FD mount hasn't moved on the frame. I accidentally hit mine with my heel one time while bouncing along on a trail and it turned it so slightly that you almost couldn't see it with your naked eye, but it really messed with the shifting. And like Shimagnolo said, sometimes those little bumps on the side will wear from dirt and grit faster than the teeth and that definitely effects shifting up because they no longer pull the chain up the side of the sprocket. Good luck
I tried adjusting everything and it sort of works but not perfectly all the time. I'm sort of living with it for now.
https://www.bikeforums.net/general-c...r-problem.html
So maybe a new outer chain ring might be the next thing to try. Will start looking around for one.
