Riding technique tips?
I don’t live in Tampa
Bikes: 2014 Jamis Ventura Race, 2014 Cervelo P2, 2017 Raleigh Tamland 1, 2015 Jamis Trail X
Quoted: 151 Post(s)
Liked 42 Times
so generally speaking with road cycling I didn't think too much any sort of riding technique. the normal making sure you are in an easier gear before you reach a climb, getting a little more aero, etc. But nothing I thought about too much.
Recently, I had a bike fit on my gravel bike which worked out well. I have a fit with this person before and he has me go through the motions of riding at different power and incline. It's on a guru bike so he can adjust easily. and he does give me some general feedback on how I should be riding. A couple things he mentioned I hadn't heard before. Not sure if some of these are just his opinion or more common knowledge.
1) On a gravel bike to stay in the drops as much as possible as that puts the most pressure on the front wheel to maintain as good a tire contact/grip with the group. He wasn't saying always stay in the drops just try to work on getting comfortable being there more frequently. And of course he worked on the fit so I would be more comfortable there
2) when climbing have your hands positioned on top of the hoods. Not just on the hoods in your normal position but as far on top as possible obviously while maintaining control which going slower up a hill you're not making rapid fast movements. I'm assume this is maybe to get you as spread out across the bike as possible making sure both tires are in good contact as possible. idk There's a lot going on during a fit so I don't always think to ask a lot of questions.
None of these tips where phrased in a sort of absolute way or anything like that but these 2 in particular were new to me.
Anybody have additional tips or even just comments on these tips?
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I'm not sure what the difference between "on the hoods" and "on top of the hoods" is? Personally I find that being on the hoods with my elbows bent allows me to open up my chest cavity a bit allowing the lungs to expand and take in more air on a climb.
I do find, especially on single track, that being in the drops significantly lowers my center of gravity. But when doing a fast loose gravel turn I tend to shift my weigh back behind the seat (like a mtb going downhill) so that I get more weight on my rear wheel. Other wise my front wheel might wash out; could just be my bike though, others may be different.
Quoted: 1872 Post(s)
Liked 692 Times
I think both of those "tips" are absolutely bizarre and I've never heard either of them before. I can't even imagine how they make sense tbh.
2019 Salsa Warbird
2019 Salsa Warbird
Liked 415 Times
Just thinking about it more.
I like being on the drops on tight hard single track as that extra weight on the front gives me a little more bite, and a lower center of gravity. I do ride with less air in my front tire so that I have the same size contact patch front and rear.
But on the loose stuff, I don't want to understeer, and I'm gonna get my weigh back.
Likes For chas58:
Quoted: 151 Post(s)
Liked 42 Times
I will ride in the drops more frequently when it's windy so there's that or just to change my position for really long rides but I haven't done it with the thought of more control
Quoted: 151 Post(s)
Liked 42 Times
"on top of the hoods" meaning closer to and basically on top of shifters. he was strictly speaking during climbing so you're not going fast so not needing as much control. he mentioned the position of hoods with elbows bent and opening up the chest. many things you figure out what works for you as you ride of course. Maybe these are just things he's noticed help him.
Quoted: 151 Post(s)
Liked 42 Times
I hadn't heard them before. For gravel bikes which many times have the flared out drop bars I have heard riding there to help with control. I hadn't heard about that position putting more weight on the front wheel. I know riding up a steeper climb with loose gravel to stay seated to keep the rear tire from slipping.
Randomhead
Liked 3,696 Times
I'm not sure about either tip. I think the main thing to remember is the bike knows which way to go, so don't over-control it. That might be a variation on the advice to look where you want to go, but I'm not sure.
Liked 415 Times
Yeah, I haven't gotten on the flared handebar thing. generally, I'm in the drops when I need to be aero, not when I need control. At speed I want a narrow handle bar; going slower on technical terrain I might want a wider bar. Ideally I would want reversed flared bars (wide at the top, narrow at the bottom) but of course that wouldn't' work. Flared bottoms are the opposite of what I want.
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 151 Post(s)
Liked 42 Times
Sunshine
Quoted: 10962 Post(s)
Liked 7,488 Times
I can definitely see someone recommending riding in the drops more on gravel/monstercross drop bar bikes. It's kinda why flared bars became a thing. They are wider, so riding in the drops slows steering and stabilizes you, which is ideal for shaky surfaces(loose gravel).
Dirt drop bars were designed this way and the point was to then raise the bars up higher than a paved road bike to compensate for riding in the drops more. Stems were been designed to assist in accomplishing this setup.
Now the original intent/main design idea seems to get to the same end point as the fitter, but different reasons are used to get there. I havent noticed a lack of weight on the front end when riding in the drops or on the hoods. I get the concern of not wanting to slide out due to not enough front end weight, but that just isnt a concern for me, practically speaking.
If anything, when I do shift weight, I try to shift my weight back over the rear tire for better traction on climbs. So I move my weight the opposite way.
Hmm...maybe that's what has been wrong with me this whole time, poor weight placement! Podium finishes here I come!
Quoted: 151 Post(s)
Liked 42 Times
Sunshine
Liked 7,488 Times
For sure. It's a great way to extend overall comfort which let's you ride further. More positions means less fatigue on specific muscles since you stretch them or rest them depending on position.
Quoted: 151 Post(s)
Liked 42 Times
I had a 100 mile gravel race last month where I got in a good pace group of like 6-7 people and everybody was pulling anywhere between 2-5 minutes and it was so nice once I got to the back and I could just stretch for a few minutes. Made for a much less painful ride.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I certainly get the fitters overall point of good weight distribution to keep good balance and both tires keeping solid contact to the surface. How to get there obviously seems to have a variety of opinions. I certainly feel like the fitter was making the point of getting weight downwards on the front tire to make sure it’s gripping into the gravel as much as possible. But I guess when riding on flat road I don’t have that much trouble keeping control the front regardless of position on bars. idk I’m fine with working on riding in the drops more as I always like to change position for comfort.
Liked 2,568 Times
I'm not a pro fitter, but my experience thus far in deep gravel, mud, and snow is that too much weight on the front wheel makes it plow in and get harder to control. It's rare that my front wheel isn't making enough contact with the ground, usually that only happens on steep climbs.
Quoted: 151 Post(s)
Liked 42 Times
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
"Gravel" biking where I live is essentially mountain biking - it's all steep rutted fire roads and rocky gnarly singletrack. I go into the drops any time I'm tackling rough stuff with any kind of speed, not so much for the traction issue, but mainly because you can literally get bounced right off the hoods if your hands are up there. Plus, I want all the braking power at my disposal.
Likes For pbass:
If its traversing rocks and stumps and trying to get over/through stuff it's more of a "grab" on the horns to pull the front end up and over and around stuff if need be. It's hard to pull up on the front end from the drops. A shorter stem helps balance the weight as well. Typically 10-20mm shorter than on my road bike.
