Grandpa's 1980's Vitus 788 steel road bike
Hi all!
I'd like to share my vintage road bike restauration here, it's a 1980's Fangio with Vitus 788 steel that I got from my grandpa.
It came with Campa Nuovo Record front/rear derailleur and shifters, Cinelli stem and bars, Ofmega crankset, Mavic GP4 with Ofmega hub frontwheel, Mavic unknown rim with Shimano 600 hub rearwheel, Diacompe aero levers.
Ibtook a small ride to have an idea about all the issues it might have. The tubs were starting to separate, the gear cables were very hard etc etc... All the things you'd expect from a 35 years oldish bike.
I had been searching for a project for some time before my grandparents told me they wanted to get rid of that bike sitting in the garage for the last 20 years so it was definitely rusty, but the parts where actually in very good condition.
Plan is to completely get it back to perfect condition, new paint etc.
After stripping down everything I went to remove all the paint and stickers with a paintstripper.
I bought a 2k epoxy primer, 2 colours of Montana metallic, and a 2k high gloss clear coat to paint the frame. Pictures later.
Cheers,
Max
Cheers,
Max
Likes For MaxDB:
Started with removing all the rust from every part, incl all the bolts and nuts but more on that later.
Needed lots of TLC
Sanding first
Buffed and polished, like new
Needed lots of TLC
Sanding first
Likes For MaxDB:
Quoted: 5888 Post(s)
Liked 3,471 Times
This a terrific job on this bike. This is clearly a high quality bike. Info on Vitus tubing is somewhat scarce but my there will clearly be more info available in French than English.
Likes For bikemig:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3884 Post(s)
Liked 6,478 Times
Those model 65 bars are used more for track applications. For most folks, they don't work very well for road. You may wish to seek the more popular model 64 or the deeper 66. Be sure to get the right clamp diameter for your stem, in this case, either 26 or 26.4mm. Nice job so far.
Quoted: 1106 Post(s)
Liked 1,326 Times
I have almost the same frame - very nice workmanship. The one I have has 888 forks, they have a penny-farthing engraved in the crown. They BB cable guides are little curved bits of steel tube, just at the right spots. Lugs are a little different, mine has points, but the same cutouts.
Mine also has the rubbish decals that have started falling apart.
And thanks!
Likes For MaxDB:
Likes For oneclick:
Next was the crankset and brakes
One done, another to go
Had to sand the finish off first, until a 2500 grit, then 2 polishing compounds
Frame colour. 2k primer, base and 2k high gloss coat
Result
Result
Likes For MaxDB:
Quoted: 4510 Post(s)
Liked 6,377 Times
MaxDB
Fantastic, love it when this happens, no other cyclists in my family but my Dad helped make sure I had some good bikes growing up and he was a good mechanic so I inherited that and ran with it.
Wish I had a bike from my family, glad you are bringing this one back up to speed.
Likes For merziac:
Likes For Chombi1:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,600 Times
The Fangio brand was former pro Guido Reybrouck's. He opened a shop in Aartrijke after his cycling career, and named it (and his son) after Juan Manuel Fangio, the former F1 champion. The son now runs the shop.
Likes For big chainring:
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Wow! Looking forward to more pics !
"part timer"
Bikes: 1975 Raleigh Gran Sport, 1978 Bertin C35, 1982 Trek 614, 1983 Trek 620, 1984 Nishiki Seral, 1995 Mercian Ko’M, 1998 Fisher HKEK, 2000 Rivendell RS, 2001 Heron Touring, 2016 Nobilette Custom
Quoted: 114 Post(s)
Liked 160 Times
You obviously known what you’re doing - beautiful work! Polishing old aluminum bike parts is so rewarding. I can’t wait to see the finished bike!
Likes For SuperLJ:
Amazing project, I had to go find my sunglasses to look at the pictures . Do you use a machine to polish the parts? Really looking forward to more pics!
Likes For Hajo:
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
Lovely work here.
Can you provide a little more info on your specific method for restoring the chrome fork? Everyone seems to do it slightly differently. You mentioned sanding? Wet? Then what did you use for polishing compound and method? Likewise, I'd be curious to know the compound and method you used on the other parts (stem, brakes, cranks)?
Been around the block
Quoted: 102 Post(s)
Liked 231 Times
I'm sure Grandpa is proud of what you've done so far, now watch out, Grandpa may want to take it for a spin around the block, so you better set a curfew for him.
Likes For roundypndr:
Quoted: 1104 Post(s)
Liked 1,824 Times
And to the main point, BRAVO OP!!!!!
señor miembro
Liked 6,478 Times
Likes For SurferRosa:
Liked 1,326 Times
Just weighed and measured mine,
Completely bare frame - four and a half pounds.
Completely bare fork - one and a half pounds
56cm c-c seat tube
68mm wide BB, English threading.
22.2 steerer
26.6 seat post dia
26.5 crown race (the race that was on was extremely tight).
56cm c-c seat tube
22.2 steerer
26.6 seat post dia
Liked 1,326 Times
"Philippe" on the chainstay may be Philippe Deleye who rode for the Fangio team.
This post (in another place) has relevance:
https://www.lfgss.com/conversations/163006/
Can it be that all three of our frames were ridden by him - why else put the name there?
Edit: found this ad - also says Philippe:
https://www.gumtree.com/p/bicycles/b...80-/1372902883
Guess he was their best guy.
