Weird Breaking Sound - New Bike
Old 09-14-13, 10:28 PM
llleafff
Weird Sound When Applying Brakes - New Bike
So I got a Virtue Seven yesterday and when I got it home to ride, the back brakes made a really awful noise, sort of like a screeching sound. Also when I brake, the brake pads seem to leave a faint black mark on the rim, but it can easily be wiped away. If I'm moving the bike backwards and apply the rear brakes, it brakes smoothly and makes no sound, but if it's moving forward it makes the sound. I looked this up already but none of the solutions seem to apply to my type of brakes.
The bike comes with linear-pull brakes which don't allow me to fix the "toe in" at all. What could be causing this problem and how can I fix it?
llleafff is offline
Old 09-14-13, 10:38 PM
2 wheeler
Ancient Clydesdale
2 wheeler's Avatar
Bikes: Specialized Allez Elite
My guess would be brake shoe toe-in, as well.
Have you loosened the shoe bolt to see if you can adjust the toe-in?
2 wheeler is offline
Old 09-15-13, 01:22 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
Originally Posted by llleafff
..........The bike comes with linear-pull brakes which don't allow me to fix the "toe in" at all. What could be causing this problem and how can I fix it?
Sure you don't have matching beveled washers?
Bill Kapaun is online now
Old 09-15-13, 06:34 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
Problems like this are a reason to give a new bike a thorough test ride and close checking over BEFORE you accept delivery; the dealer is a lot more motivated to correct these problems before you sign on the line and hand over the bux.
I would take it back to the dealer and have them make it right if you cannot, as suggested by the above comments, adjust the toe-in to make it stop. If the toe-in cannot be adjusted with the supplied pads they might be able to substitute a different type of pads which either don't squeal or can be adjusted not to. Also, they are not expensive brakes ($10.99 MSRP) so cannot be expected to give the kind of performance that more costly and presumably more rigid brakes might. Finding this problem before accepting delivery may have put you into a better position to negotiate a discount on replacing the installed pads or brakes with better ones.
dsbrantjr is offline
Old 09-15-13, 06:50 AM
Blue Belly
Blue Belly's Avatar
Bikes: Pinarello Montello, Merckx MX Leader, Merckx Corsa Extra, Pinarello Prologo, Tredici Magia Nera, Tredici Cross
Liked 4 Times in 3 Posts
If your brake pads make contact on the back of the pad before the front of the pad, the air gets compressed in there & tries to fight the contact. Causes that dreadful sound. Usually just takes loosening the bolt, with the brakes applied, & retightening so that they make even contact.
Blue Belly is offline
Old 09-15-13, 09:54 AM
Bill Kapaun
That one made my day!
Old 09-15-13, 01:25 PM
woodcraft
woodcraft's Avatar
Quoted: 1814 Post(s)
Liked 923 Times in 569 Posts
I sometimes get that dreadful sound from compressed air,
But it seems like it's coming from the saddle area.
woodcraft is offline
Old 09-15-13, 01:52 PM
JanMM
rebmeM roineS
JanMM's Avatar
Quoted: 653 Post(s)
Liked 347 Times in 226 Posts
Try spraying the saddle with WD 40 or maybe air freshener.
JanMM is offline
Old 09-15-13, 02:47 PM
Looigi
Looigi's Avatar
Quoted: 14 Post(s)
Liked 13 Times in 12 Posts
It left me speechless.
Looigi is offline
RockiesDad
Bicycle Mechanics
7
06-04-16 10:08 PM
yayforebikes
General Cycling Discussion
17
02-24-16 08:45 AM
Bob Ross
Bicycle Mechanics
18
12-11-12 01:31 PM
dukeofdudes
Bicycle Mechanics
6
04-07-12 05:42 PM
awesomejack
Bicycle Mechanics
23
02-14-10 12:53 AM
